Duet Master Firmware & Non Duet Master Firmware
Sensiva
Hello all
I don't use duet modules, and not planning to do in the near future.
Do I still need to install Duet firmwares? or I can go with Non Duet firmwares?
in other words..
Is Duet firmware for duet modules only, or it is used for other purposes?
Sensiva
in other words..
Sensiva
Certainly looking at things in the last year or so, Duet F/W has been developed but non-duet has been minor fixes only
Having said that, I wish I could downgrade to non-duet firmware. While new features seem to be duet only, there are several bugs that drive me crazy:
1. Persistant variable are not always persistent. As such I save/load all my persistant variables in XML files.
2. The FTP server has changed the "group" attribute to "0" in the directory listings, which causes grief with some FTP clients.
Roger McLean
Swinburne University
That's gotta hurt!
I was thinking if I could use non duet firmware because Duet firmwares extends boot time very much.
So i thought non Duet will improve boot up performance
but since Non duet has such a bug... I am Happy with Duet now
thanks to you all for making things clear.
Sensiva
I would be interested in hearing about any other problems, but most of the persistent stuff I deal with is done in XML files so that I can move the data between processors (favorite info and similar stuff). This also comes in handy if a power surge blows up a processor.... you can just put in a new processor and send the most recent xml file you have
All PVs were dropped after:
1. Uploading a new program (with reboot).
2. Issuing the reboot command
3. After power failure.
Hmmm... Thinking about it, that sounds more like the PVs are not being reloaded from flash correctly, rather than being 'dropped' mid flight. However, it didn't happen every time in each of these cases. Unfortunatly it is one of those painful bugs that I can not consistently reproduce.
Perhaps I am a bit bold in claiming that it is a duet bug - the bug may not be spread across the whole duet scope, but may be pertinant to a particular model. I've noticed it on at least four of my NI-3100 masters running v3.21.254. What I DO remember is that this never happend in my pre-duet days. Needless to say, the pain was so great that I went the XML approach, ceased using the PERSISTENT keyword, and never looked back. I agree that the XML aproach is great for similar (yest slightly different) settings across a large number of venues.
Roger McLean
there are some rules to retain variables persistence after new program download, regarding reboot or power failure... I didn't experience anything wrong with persistent variable...
I thought you were saying these bugs are in Non duet..... that's why I took off using non duet out of mind.
Roger McLean
Roger McLean
We have been experiencing problems with MVP's falling off line and not being allowed to reconnect to the master. They remain online in the internet connection sense, but are not online with the master.
The project is fairly high profile and several top engineers from AMX came out to the site to assist us in resolving it. We were using the most current non-duet firmware and still having problems. Although we are not running duet modules, we were instructed to upgrade to the duet firmware. Apparently, there were multiple fixes for TCP/IP communication in the duet module firmware release. It seems that most of the engineering efforts are going into the duet firmware releases, and as a result, we will see a taper off of non-duet releases.
After a week of observing the panels, the connectivity problems have essentially gone away. We still miss blink messages on occation, but the firmware fixed an issue where the master would retry after x amount of missed messages. This allowed the panel to reconnect to the master.
So in short - even with a longer boot time, I think we are going to be installing the duet firmware moving forward. We will certainly do this when there are MVP's on the job.
Chris
I haven't had any problems where there shouldn't be any with persistent variables, but I don't really use them often.
Has anyone resolved the issue of uploading and waiting on Duet? I have a NI-2000 and it sits for 45 seconds which adds to the uload time.There has got to be a way to "turn it off".
