R4 zigbee gateway on ICnet
Hi,
Ok the 4ch volumecontrol one connect to the icnet bus of ni2000 master.
In the manual of the R4 zigbee gateway it says icnet protocol implemented on tcp/ip with POI. Can the gateway be connected to the icnet of ni2000?
Nick
    Jimweir192Jimweir192 Posts: 502
    The R4 Zigbee Gateway needs to connect to the Ni2000 via ethernet, ideally using a Network Switch.
    The NXC-VOL4 Card (and others) connect to the NI2000 using the ISCNET ports
    nick_bnick_b Posts: 15
    Thanks for the answer
    Nick from the Netherlands
