Panel Offline
Hi i have a level that commands a light dimmer.
When the 8400 wiFi panel go offline ( I hate WiFi!!! ) the level raise up a level 0 event so the dimmer go off.
How can I know if the panel is online or offline?
Thank's a lot!!!
Alex
    Panels generate an online and offline event. Just make a DATA_EVENT for the panel with those handlers.
    However, to avoid the level being sent to zero, you will probably be better served by combining your panel with a virtual, and using the virtual instead. Virtuals never go off line unless the master shuts down.
  • Other way to prevent this:
    dvPANEL 		= 128:1:0
    INTEGER nBARGRAPHVALUE		// the active bargraph value
    // we will NOT use a CREATE_LEVEL to Bargraph 1,
    // because if the panel goes OFFLINE, the bragraph value goes to 0
    LEVEL_EVENT[dvPANEL,1] // Bargraph 1
    	IF(DEVICE_ID(dvPANEL)) // only if Panel Device is online
    		nBARGRAPHVALUE = LEVEL.VALUE // take Bargraph value
    		// send nBARGRAPHVALUE to any other device
    DATA_EVENT[dvPANEL]
    	ONLINE:
    		SEND_LEVEL dvPANEL,1,nBARGRAPHVALUE // resend latest value to the bargraph
    DEFINE_PROGRAM
    DATA_EVENT ONLINE/OFFLINE has a higher priority as a LEVEL_EVENT[]. Because of this, The DEVICE_ID(dvPANEL) fails and the LEVEL.VALUE, which falled to 0, is not executed.
