Parasound zTuner
I writing a program to handle the Parasound zTuner. I am having an issue tyring to use the system keypad for direct station entry.
The keypad will return the following
92.7
-or-
100.7
But the zTuner's command to go to a direct frequency is the following
W 1 6 92 70
-or-
W 1 6 100 70
Here is what I have so far but could really use some help getting it to parse correctly
PROGRAM_NAME='zTuner'
(*  FILE_LAST_MODIFIED_ON: 04/05/2006  AT: 09:00:25        *)
(* System Type : NetLinx                                   *)
(* REV HISTORY:                                            *)
    $History: $
    200ms delay between commands or unit will lock up
    Version 1:
    Control of the device; Presets, Tune, Band & Feedback
    Version 2:
    Ability to push and hold Preset # and change the station
dvZtuner	=	5001:1:0
dvPanel		=	10024:1:0
(*               CONSTANT DEFINITIONS GO BELOW             *)
DEFINE_CONSTANT
Volatile Integer nZtuner_Preset_Buttons[]=
    500,	/// Preset 1
    501,	/// Preset 2
    502,	/// Preset 3
    503,	/// Preset 4
    504,	/// Preset 5
    505,	/// Preset 6
    506,	/// Preset 7
    507,	/// Preset 8
    508,	/// Preset 9
    509,	/// Preset 10
    510,	/// Preset 11
    511,	/// Preset 12
    512,	/// Preset 13
    513,	/// Preset 14
    514,	/// Preset 15
    515,	/// Preset 16
    516,	/// Preset 17
    517,	/// Preset 18
    518,	/// Preset 19
    519,	/// Preset 20
    520,	/// Preset 21
    521,	/// Preset 22
    522,	/// Preset 23
    523,	/// Preset 24
    524,	/// Preset 25
    525,	/// Preset 26
    526,	/// Preset 27
    527,	/// Preset 28
    528,	/// Preset 29
    529		/// Preset 30
Volatile Integer nZtuner_Tune_Buttons[]=
    530,	/// Auto Tune Up
    531,	/// Auto Tune Down
    532,	/// Manual Step Up
    533		/// Manual Step Down
Volatile Integer nZtuner_Band_Buttons[]=
    534,	/// FM
    535,	/// AM
    536		/// Band Toggle
Volatile Integer nZtuner_VText_Fields[]=
    1,		/// Display 1
    2,		/// Display 2
    3,		/// Display 3
    4		/// Display 4
Volatile Integer nZtuner_Preset_Control_Buttons[]=
    537,	/// Next Preset
    538		/// Previous Preset
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
Persistent Integer Debug_Status
(*               LATCHING DEFINITIONS GO BELOW             *)
DEFINE_LATCHING
(*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
DEFINE_MUTUALLY_EXCLUSIVE
(*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
Define_Function Char debug(Char sMsg[])
    If(Debug_Status)
	Send_String 0,"'Debug : ',' Line : ',Itoa(__Line__),' :: ',sMsg"
Define_Function SysKP_Parsing(Char sQue[100])
    Local_Var Char sWork[25]
    Local_Var Char sTrash[25]
    If(Debug_Status)
	debug("'SysKP_Parsing :: ','sQue : ',sQue")
    sFormat(sQue)
    If(Debug_Status)
    Send_String dvZtuner,"sQue,13"
Define_Function sFormat(Char sQue[100])
    Local_Var Char sWork_Temp_1[25]
    Local_Var Char sWork_Temp_2[25]
    Local_Var Char sNum_1[4]
    Local_Var Char sNum_2[2]
    If(Debug_Status)				/// Debug information
	debug("'sFormat :: ','Formatting data.'")
    Select
	Active(Find_String(sQue,'.',1)):
	    If(Debug_Status)
		debug("'sFormat :: ','Found a . in the data.'")
	Active(!(Find_String(sQue,'.',1))):
	    If(Debug_Status)
		debug("'sFormat :: ','Not a . in the data.'")
	    sNum_1 = Left_String(sQue,2)
	    If(Debug_Status)
		debug("'sFormat :: ','sNum_1 : ',sNum_1")
	    sNum_2 = Right_String(sQue,2)
		If(Debug_Status)
		    debug("'sFormat :: ','sNum_2 : ',sNum_2")
	    sQue = "sNum_1,' ',sNum_2"
		If(Debug_Status)
		    debug("'sFormat :: ','sQue : ',sQue")
(*                STARTUP CODE GOES BELOW                  *)
(*                THE EVENTS GO BELOW                      *)
Data_Event[dvZtuner]
    Online:
	Send_Command dvZtuner,"'SET BAUD 9600,N,8,1'"
	If(Debug_Status)
	    debug("'Device Online :: Setting Communication'")
    String:
	Local_Var Char sBuffer[500]
	Local_Var Char sTrash[500]
	Local_Var Char sTemp[500]
	Local_Var Char sStation[10]
	Local_Var Char sBand[2]
	sBuffer = Data.Text
Data_Event[dvPanel]
    String:
	Local_Var Char sQue[1000]
	Local_Var Char sTrash[100]
	Local_Var Char sResponse[100]
	sQue = Data.Text
	If(Debug_Status)
	    debug("'Data.Text : ',Data.Text")
	Select
	    Active(Find_String(sQue,'Radio-',1)):
		sTrash = Remove_String(sQue,'Radio-',1)
		If(Debug_Status)
		    debug("'Keypad Detection :: ','Set the keypad to Radio mode.'")
	    Active(Find_String(sQue,'KEYP-',1)):
		sTrash = Remove_String(sQue,'KEYP-',1)
		sResponse = Remove_String(sQue,sQue,1)
		If(Debug_Status)
		    debug("'Keypad Detection :: ','Send the keypad string to the function.',' sResponse : ',sResponse")
		SysKP_Parsing(sResponse)
	    Active(Find_String(sQue,'KEYB-',1)):
		sTrash = Remove_String(sQue,'KEYB-',1)
		If(Debug_Status)
		    debug("'Keypad Detection :: ','Send the keyboard string to the function.',' sResponse : ',sResponse")
Button_Event[dvPanel,nZtuner_Preset_Buttons]
    Push:
	/// Do Nothing :)
    Release:
	Local_Var Integer nButton
	Local_Var Char sCmd[15]
	nButton = Get_Last(nZtuner_Preset_Buttons)
	sCmd = "'W 1 3 1 ',ITOA(nButton)"
	If(Debug_Status)
	    debug("'Radio Presets :: ','sCmd : ',sCmd")
	Send_String dvZtuner,"sCmd,13"
    Hold[20]:
	sCmd = "'W 1 3 2 ',Itoa(nButton)"
	If(Debug_Status)
	    debug("'Memorizing Channel into preset :: ','sCmd : ',sCmd")
Button_Event[dvPanel,nZtuner_Tune_Buttons]
    Push:
	nButton = Get_Last(nZtuner_Tune_Buttons)
	sCmd = "'W 1 7 ',ITOA(nButton)"
	If(Debug_Status)
	    debug("'Radio Tune :: ','sCmd : ',sCmd")
Button_Event[dvPanel,nZtuner_Band_Buttons]
    Push:
	nButton = Get_Last(nZtuner_Band_Buttons)
	If(nButton == 3)
	    nButton = 10
	sCmd = "'W 1 8 ',Itoa(nButton)"
	If(Debug_Status)
	    debug("'Radio Band :: ','sCmd : ',sCmd")
Button_Event[dvPanel,nZtuner_Preset_Control_Buttons]
    Push:
	nButton = Get_Last(nZtuner_Preset_Control_Buttons) + 2
	sCmd = "'W 1 3 ',Itoa(nButton)"
	If(Debug_Status)
	    debug("'Radio Preset Control :: ','sCmd : ',sCmd")
(*            THE ACTUAL PROGRAM GOES BELOW                *)
DEFINE_PROGRAM
(*                     END OF PROGRAM                      *)
(*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
  • Is the 92.7 coming from the turner or is tat the buttons pressed on the touch panel? If its just buttons pressed you could skip the step of formating the string one way just to reformat it later. Just keep track of the buttons pressed and build the string on the fly. Nothing says you can't build the human readable 92.7 string for the feedback and the rs-232 command at the same time from the same button presses. :D
  • ondrovicondrovic Posts: 217
    Buttons pressed on the touch panel ( im using the system keypad )
    But never mind I just worked it out
  • ondrovic wrote: »
    If it works great, but I think you did more work then you needed to. Good practice though. :D
    I have finished everything with the code but I am having an issue displaying the feedback on the panel. I will upload the full workspace with panel. Here is the issue I am having:
    The feedback is correctly updating if I use the following code :
    Send_Command dvPanel,"'^TXT-',Itoa(nZtuner_VText_Fields[5]),',0,',sRadio_Data.sBand" ;
    It will display a
    1
    for FM and a
    2
    for AM
    However it will not work when trying to do this :
    Switch(sRadio_Data.sBand)
    	Case 1:	{Send_Command dvPanel,"'^TXT-',Itoa(nZtuner_VText_Fields[5]),',0,','FM'"	Break}
    	Case 2:	{Send_Command dvPanel,"'^TXT-',Itoa(nZtuner_VText_Fields[5]),',0,','AM'"	Break}
    What am I doing wrong?
    Thanks for the advice / help
    It looks like the 1 and 2 are ascii versions. Try this:
    Switch(ATOI(sRadio_Data.sBand))
    Or, you could do this:
    	Case '1':	{Send_Command dvPanel,"'^TXT-',Itoa(nZtuner_VText_Fields[5]),',0,','FM'"	Break}
    	Case '2':	{Send_Command dvPanel,"'^TXT-',Itoa(nZtuner_VText_Fields[5]),',0,','AM'"	Break}
    You could also add a default condition that alerts you to the fact that there was a problem.
    I will give that a try and let you know thanks Jeff
    Just as an aside, the BREAK statements are not necessary in NetLinx. I suppose it doesn't hurt, but NetLinx won't drop through to the next case ever anyway. The same goes for SELECT...ACTIVE statements.
    Spire_Jeff wrote: »
    Worked like a charm thanks again
    Having an issue with the am tuning when done from a keypad. It only works on some of the am channels, any adive based on the code i have? Seems like it isn't working with 3-digit am stations works fine with 4-digits ones.
    *** EDIT : Fixed it :) ***
    Would really like to turn this into a module instead of a include file, but I haven't ever made a module before could someone who has experience with modules help me out?
    Chris Ondrovic
    Module Progress
    Here is as far as I have gotten. ( First attempt @ writing a module )
    I can successfully control the zTuner via the CP4 & MVP.
    The MVP I have control, debug statements & feedback.
    The CP4 controls the device but will not update the feedback, it will also not trigger the debug that is programmed into the code.
    Any ideas?
    Main Program
    (* REV HISTORY:                                            *)
        $History: $
        200ms delay between commands or unit will lock up [x]
        Version 1: - Done
        Control of the device; Presets, Tune, Band & Feedback [x]
        Version 2: - Still locks up tuner
        Ability to push and hold Preset # and change the station : Locks up tuner
        Version 3: - Still locks up tuner
        Add . to FM Stations for display []
        Add Preset stored notification to panel when new preset is stored [x] : not using because it locks up the tuner
        Version 4: - Done
        AM stations with only 3-digits aren't working so need from keypad parsing, need to enter 0, then station to getit
        to work properly [x]
        Version 5: - Still locks up tuner
        Need to get Preset Storing working correctly
    	a.> Push & Hold Sets Current Station to Preset
    	b.> Updates Panel Information
    	c.> Add vText that tells you the station has been added
        Version 6: - Done
        Rewritting string parsing to see if i can make it more efficent ( ztuner locks up and physically needs
        to be unplugged for 3 mins to clear everything : Its an issue with the ztuner itself, thats why they release new
        version of the protocol and firmware )
        Version 7: - Not Done; controling on cp4 but not updating feedback
        Add CP4 Panels, create a way to determine which panel is being used
        and only update that panel
        Version 8:
        Turning into a module
    dvZtuner	=	5001:1:0
    dvMVP		=	10024:1:0
    dvCP4_1a	=	128:1:1
    dvCP4_1b	=	129:1:1
    dvCP4_1c	=	130:1:1
    dvCP4_1d	=	131:1:1
    dvCP4_2a	=	132:1:1
    dvCP4_2b	=	133:1:1
    dvCP4_2c	=	134:1:1
    dvCP4_2d	=	135:1:1
    DEFINE_CONSTANT
        209,	/// Preset 1
        210,	/// Preset 2
        211,	/// Preset 3
        212,	/// Preset 4
        213,	/// Preset 5
        214,	/// Preset 6
        215,	/// Preset 7
        216,	/// Preset 8
        217,	/// Preset 9
        9999,	/// Preset 10
        9999,	/// Preset 11
        9999,	/// Preset 12
        9999,	/// Preset 13
        9999,	/// Preset 14
        9999,	/// Preset 15
        9999,	/// Preset 16
        9999,	/// Preset 17
        9999,	/// Preset 18
        9999,	/// Preset 19
        9999,	/// Preset 20
        9999,	/// Preset 21
        9999,	/// Preset 22
        9999,	/// Preset 23
        9999,	/// Preset 24
        9999,	/// Preset 25
        9999,	/// Preset 26
        9999,	/// Preset 27
        9999,	/// Preset 28
        9999,	/// Preset 29
        9999	/// Preset 30
        206,	/// Auto Tune Up
        207,	/// Auto Tune Down
        9999,	/// Manual Step Up
        9999	/// Manual Step Down
        9999,	/// FM
        9999,	/// AM
        208		/// Band Toggle
        1,		/// Power Status : Not used
        2,		/// Current Status
        3,		/// Current Preset #
        4,		/// Current Frequencey
        5,		/// Current Band
        6		/// Station Preset Info
        9999,	/// Next Preset
        9999	/// Previous Preset
    DEFINE_TYPE
    Dev dvPanel[]= {dvCP4_1a,dvCP4_2a,dvMVP}
    DEFINE_LATCHING
    DEFINE_MODULE 'Z-Tuner Mod' modTuner1(dvCP4_1a, dvZtuner, nZtuner_Preset_Buttons ,nZtuner_Tune_Buttons,nZtuner_Band_Buttons,nZtuner_VText_Fields,nZtuner_Preset_Control_Buttons)
    DEFINE_MODULE 'Z-Tuner Mod' modTuner2(dvCP4_2a, dvZtuner, nZtuner_Preset_Buttons ,nZtuner_Tune_Buttons,nZtuner_Band_Buttons,nZtuner_VText_Fields,nZtuner_Preset_Control_Buttons)
    DEFINE_MODULE 'Z-Tuner Mod' modTuner3(dvMVP, dvZtuner, nZtuner_Preset_Buttons ,nZtuner_Tune_Buttons,nZtuner_Band_Buttons,nZtuner_VText_Fields,nZtuner_Preset_Control_Buttons)
    DEFINE_PROGRAM
    Module
    MODULE_NAME='Z-Tuner Mod'	(Dev dvTP,
    				 Dev dvDevice,
    				 Integer nPreset_Buttons[],
    				 Integer nTune_Buttons[],
    				 Integer nBand_Buttons[],
    				 Integer nVText_Fields[],
    				 Integer nPreset_Control_Buttons[]
    (*  FILE_LAST_MODIFIED_ON: 04/04/2006  AT: 11:33:16        *)
    (* REV HISTORY:                                            *)
        $History: $
    //dvZtuner = 5001:1:1
    DEFINE_CONSTANT
    DEFINE_TYPE
    Structure _Radio_Information
        Char sPower[1]
        Char sPreset[2]
        Char sFrequency[12]
        Char sStatus[1]
        Char sBand[1]
    Integer nPanel
    Persistent _Radio_Information sRadio_Data
    DEFINE_LATCHING
        If(Debug_Status)
    	Send_String 0,"'Debug : ',sMsg"
        If(Debug_Status)
    	debug("':: Line : ',Itoa(__Line__),' SysKP_Parsing :: ','sQue : ',sQue")
        If(Length_String(sQue = 3))
    	sQue = "'0',sQue"
        sFormat(sQue)
        If(Debug_Status)
        Send_String dvDevice,"sQue,13"
    	debug("':: Line : ',Itoa(__Line__),' sFormat :: ','Formatting data.'")
        Select
    	    If(Debug_Status)
    		debug("':: Line : ',Itoa(__Line__),' sFormat :: ','Found a . in the data.'")
    	    sWork_Temp_1 = Remove_String(sQue,'.',1)
    	    If(Debug_Status)
    		debug("':: Line : ',Itoa(__Line__),' sFormat :: ','sWork_Temp_1 : ',sWork_Temp_1")
    	    sNum_1 = Left_String(sWork_Temp_1,Length_String(sWork_Temp_1) -1)
    	    If(Debug_Status)
    		debug("':: Line : ',Itoa(__Line__),' sFormat :: ','sNum_1 : ',sNum_1")
    	    sNum_2 = sQue
    	    If(Debug_Status)
    		debug("':: Line : ',Itoa(__Line__),' sFormat :: ','sNum_2 : ',sNum_2")
    	    sQue = "'W 1 6 ',sNum_1,' ',sNum_2,'0'"
    	    If(Debug_Status)
    		debug("':: Line : ',Itoa(__Line__),' sFormat :: ','Not a . in the data.'")
    	    If(Debug_Status)
    		If(Debug_Status)
    	    sQue = "'W 1 6 ',sNum_1,' ',sNum_2"
    		If(Debug_Status)
    		    debug("':: Line : ',Itoa(__Line__),' sFormat :: ','sQue : ',sQue")
    (* Read Commands
        'R 1 1',13		= Display Power Status : 0=Off; 1=On [X]
        'R 1 3 1',13	= Display Current Preset :  Preset Number 1 -30 [X]
        'R 1 6',13		= Display Current Frequency : Frequency Number [X]
        'R 1 9',13		= Display Current Stereo Status : 1=Stereo; 2=Mono [X]
        'R 1 8',13		= Display Current Band : 1=FM; 2=AM [X]
    Define_Function Update_Feedback_V2()
        If(Debug_Status)
    	debug("':: Line : ',Itoa(__Line__),' Updating Feedback on panel'")
        (* Send Preset Info to Panel *)
        Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[3]),',0,','P',sRadio_Data.sPreset" ;
        (* Send Frequency Info to Panel *)
        Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[4]),',0,',sRadio_Data.sFrequency" ;
        (* Send Band Info to Panel*)
    	Case '1':	{Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[5]),',0,','FM'"	Break}
    	Case '2':	{Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[5]),',0,','AM'"	Break}
        Switch(sRadio_Data.sStatus)
    	Case '1':	{Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[2]),',0,','STEREO'"	Break}
    	Case '2':	{Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[2]),',0,','MONO'"	Break}
        Switch(sRadio_Data.sPower)
    	Case '0':	{Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[1]),',0,','OFF'"	Break}
    	Case '1':	{Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[1]),',0,','ON'"	Break}
    Define_Function Char Poll ()
        If(Debug_Status)
    	debug("':: Line : ',Itoa(__Line__),' Poll :: ','Checking power status'")
        Send_String dvDevice,"'R 1 1',13"
        Wait 5
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Poll :: ','Checking current preset'")
    	Send_String dvDevice,"'R 1 3 1',13"
        Wait 10
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Poll :: ','Checking current frequency'")
    	Send_String dvDevice,"'R 1 6',13"
        Wait 15
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Poll :: ','Checking current mode'")
    	Send_String dvDevice,"'R 1 9',13"
        Wait 20
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Poll :: ','Checking current band'")
    	Send_String dvDevice,"'R 1 8',13"
        Wait 25
    Data_Event[dvDevice]
        Online:
    	Send_Command dvDevice,"'SET BAUD 9600,N,8,1'"
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Device Online :: Setting Communication'")
        String:
    	Local_Var Char sWork1[25]
    	Local_Var Char sWork2[25]
    	Local_Var Char sWork3[25]
    	Local_Var Char sWork4[25]
    	Local_Var Char sTrash1[25]
    	Local_Var Char sTrash2[25]
    	Local_Var Char sTrash3[25]
    	Local_Var Char sTrash4[25]
    	Local_Var Char sTmp1[25]
    	Local_Var Char sTmp2[25]
    	Local_Var Char sTmp3[25]
    	Local_Var Char sTmp4[25]
    	sWork1 = Remove_String(Data.Text,"13",1)
    	sRadio_Data.sPower = Left_String(sWork1,1)
    	sWork2 = Remove_String(Data.Text,"13",2)
    	sRadio_Data.sPreset = Left_String(sWork2,1)
    	sTrash1 = Remove_String(Data.Text,"13",2)
    	sTmp1 = Right_String(sTrash1,Length_String(sTrash1) - 1)
    	sTrash2 = Remove_String(Data.Text,"13",2)
    	sTmp2 = Right_String(sTrash2,Length_String(sTrash2) - 1)
    	sTmp3 = Left_String(sTmp1,Length_String(sTmp1) - 1)
    	sTmp4 = Left_String(sTmp2,Length_String(sTmp2) - 1)
    	sWork3 = Remove_String(Data.Text,"13",3)
    	sRadio_Data.sStatus = Left_String(sWork3,Length_String(sWork3) - 1)
    	sWork4 = Remove_String(Data.Text,"13",4)
    	sRadio_Data.sBand = Left_String(sWork4,Length_String(sWork4) - 1)
    	    Case '1': {sRadio_Data.sFrequency = "sTmp3,'.',sTmp4,' MHz'"	Break}
    	    Case '2': {sRadio_Data.sFrequency = "sTmp3,sTmp4,' kHz'"		Break}
    Data_Event[dvTP]
        Online:
    	Wait 25
    	    Poll()
        String:
    	sQue = Data.Text
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Data.Text : ',Data.Text")
    	Select
    		If(Debug_Status)
    		    debug("':: Line : ',Itoa(__Line__),' Keypad Detection :: ','Set the keypad to Radio mode.'")
    		Wait 5
    		    Poll()
    		If(Debug_Status)
    		    debug("':: Line : ',Itoa(__Line__),' Keypad Detection :: ','Send the keypad string to the function.',' sResponse : ',sResponse")
    		If(Debug_Status)
    		    debug("':: Line : ',Itoa(__Line__),' Keypad Detection :: ','Send the keyboard string to the function.',' sResponse : ',sResponse")
    Button_Event[dvTP,nPreset_Buttons]
        Push:
    	/// Do Nothing :)
        Release:
    	nButton = Get_Last(nPreset_Buttons)
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Radio Presets :: ','sCmd : ',sCmd")
    	Send_String dvDevice,"sCmd,13"
    	Wait 5
    	    Poll()
        Hold[10]:
    	If(Debug_Status)
    	     debug("':: Line : ',Itoa(__Line__),' Memorizing Channel into preset :: ','sCmd : ',sCmd")
    	Send_Command dvTP,"'@PPG-[Tuner] - Preset;Main Page'"
    	Send_Command dvTP,"'^TXT-',Itoa(nVText_Fields[6]),',0,','Station ',sRadio_Data.sFrequency,' stored into Preset # ',Itoa(nButton)"
    Button_Event[dvTP,nTune_Buttons]
        Push:
    	nButton = Get_Last(nTune_Buttons)
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Radio Tune :: ','sCmd : ',sCmd")
        Release:
    	Wait 5
    	  Poll()
    Button_Event[dvTP,nBand_Buttons]
        Push:
    	nButton = Get_Last(nBand_Buttons)
    	If(nButton == 3)
    	    nButton = 10
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Radio Band :: ','sCmd : ',sCmd")
        Release:
    	Wait 5
    	    Poll()
    Button_Event[dvTP,nPreset_Control_Buttons]
        Push:
    	nButton = Get_Last(nPreset_Control_Buttons) + 2
    	If(Debug_Status)
    	    debug("':: Line : ',Itoa(__Line__),' Radio Preset Control :: ','sCmd : ',sCmd")
        Release:
    	Wait 5
    	    Poll()
    Button_Event[dvTP,1000]
        Push:
    	Debug_Status = Debug_Status + 1
    	If(Debug_Status > 1)	{Debug_Status = 0}
    	Switch(Debug_Status)
    	    Case 0:	{Off[dvTP,1000]	Break}
    	    Case 1:	{On[dvTP,1000]	Break}
    DEFINE_PROGRAM
    Thanks for the help...... again :)
    Chris Ondrovic
    Never mind just figured it out :) hooray
