Lutron problems! again
Ok, I had enough with the Duet Module.
Current problem :
If I am sending command too fast ( pressing TP presets fast to change lights preset) the master hang on for some time and lost communication. after 2 - 10 - 15 minutes - he gets alive again.
When lost communication I can't connect via netlinx, but can telnet and ping.
Pressing the buttons in slow way, one by one with few seconds between them, and its working.
I have the max module on this master too, maybe 2 ip module cause the problem?
I isolated the code only to send the command to lutron, it only this command that getting the master to lose its connection after few fast button pressing.
Anyone is working ok with this module?
If I can't fix that , what is the other way to work with lutron?
I download RS232 module for homeworks interactive from AMX site, v2.3
Will it work with HomeWorks P5?
Thanks for all the answers
Ady.
Current problem :
Ady.
Please report all Module problems to Tech Support, Thank you!
1. Firmware update was needed to the last Duet (371)
2. Telnet to the Master and command "set duet memory" to 12 megs instead of 3 megs
Proplems solved!
I hope now that the lose of connection probIem I had is gone too.
http://amxforums.com/showthread.php?t=3941&highlight=lutron
