R4 - Enable front setup
                                  in AMX Hardware
                    Hi!
I have disabled front Button Setup Access from the Mio R4. So I can't enter in the setup mode. How can I re -enable it?
Connect to your master via Telnet, and do a a SEND_COMMAND <R4 device name here>, "'SETUP'" .
1) remove battery
2) press and keep pressed the display, put R4 in charging cradle
3) while still pressed, R4 boots, shows user page, and 2-3 seconds later it goes into the setup page
Worked here with my R4 on the desk.
Remember to close the back cover. Thanks a lot!!!
Alex
