R4 - Enable front setup
Hi!
I have disabled front Button Setup Access from the Mio R4. So I can't enter in the setup mode. How can I re -enable it?
    I haven't tried this with an R4, but I don't see why it wouldn't work:
    Connect to your master via Telnet, and do a a SEND_COMMAND <R4 device name here>, "'SETUP'" .
  • eddymouseeddymouse Posts: 67
    It is not connect with the master. It is setted to USB. So I can't connect to it by master
  • TworhythmsTworhythms Posts: 51
    You could try connecting to the remote via Virtual Master in studio and then sending the command for setup as in the previous post. I haven't tried it but let us know if that works.
  • The good old Reboot-with-Touchscreen-Pressed should work.
    1) remove battery
    2) press and keep pressed the display, put R4 in charging cradle
    3) while still pressed, R4 boots, shows user page, and 2-3 seconds later it goes into the setup page
    Worked here with my R4 on the desk.
    It Work!!!
    Remember to close the back cover. Thanks a lot!!!
    Alex
