How do you handle displays that won't change input w/o vid signal?
I am currently coding a project in which a client has supplied a Samsung HL61A750A1F DLP television. This display will not switch to the proper input unless there is a video signal present.
Without purchasing a video sync sensor for this small project, are there any tricks you have found to get around this annoyance?
I presume we could turn the source on first, pause a second, and then power on the display, but what do you do?
This "feature" is poorly thought out and annoying in the extreme...
I'm afraid I'm returning to a job this week, completed the week before last to re-code the 5 LCD's for an alternative manufacturer...
The Samsung products are crap, there are many strange "features" and they can keep them all!
Sorry
A TBC at the output of the switcher would be the only other way - it remains synchronous with no input, which would fool the 'cleverness' of the screen. It's an expensive bit of kit though.
<rant>
The dollars the sales guys saved by using this screen are far out weighed by the time and/or bits required to make it work.
You'd have to ask why on earth any manufacturer would ever do this...they've had to write code to make it do that! Who cares where the users send the input!! Bah!
<end rant>
Apatrt from what others have said about making sure it has a signal... sometimes there is a setting in one of the menus to turn off "power save" or whatever they call it. I've only ever used the "professional" displays from Samsung, and they have this feature - no problems once it's set correctly.
HTH.
:P
Manufacturers really have to pull their heads out the sand (or whatever other dark place they have stuck them) and realize that many of these features designed to make the set easier for the end user, in the end make them harder. If you have to have an option like that, it has got to be able to be turned off.
