Serial / IP Converters
MattSmith
Has anyone used any good 232/IP converters you would like to recommend?
I have a sample of a Xantech Xtralink IP. Has anyone tried this unit? If so what were your thoughts? I have also been looking at the ILP series from Extron.
I like this device: http://www.siteplayer.com/telnet/index.html
It's relatively inexpensive, has a POE option, is simple to configure and operate, and works well. They also have what appears to be pretty responsive support/help via an online forum.
The Extron devices seem to me to work OK but some people have had problems with the device timing out. This can be controlled. The manual for the Extron devices is available online. Look it over. In my opinion, these devices have more features and are more complicated than necessary -- perhaps to a fault.
PoE is nice because it reduces the clutter behind the TV and it means the unit is protected by the battery backup as well
Appreciate the suggestions. I'l try a few of these.
http://www.wut.de/e-58631-ww-daus-000.php.
But a bit expensive.
