IR over Cat5
Pep_SD
I'm working on a project where Cat5 cables and other A/V cables are already installed in walls.
Is it possible to use one Cat5 cable for IR control? Runs are under 50 feet.
Any trap to avoid / special setting needed?
Thanks for your help.
We have run IR over cat5 close to 200 feet and it worked. I'm sure it has a lot to do with the wire and surroundings but, if you have a problem you can always use a converter like the component over cat5 devises.
