stupid problem with "if" and "else"
siegburger
Hi @all,
i need a solution to send the time to my ******** system.
Normaly no problem to do it mayby 2 times a minute. But the variable "Zaehler" stays with the value 20 (seen in debugger)
What the hell is wrong?
It seems so easy....
thanks
Martin
Here parts of the code:
Seite
UseWeckzeit
UseRollozeit
Zaehler
DEFINE_PROGRAM
(* + + + + Impulsgeber + + + + + + + + + + + + + + + + + + + + + + *)
IF(Zaehler>=20)
SEND_STRING ********,"'12345'""__TIME__,$0D"
Zaehler=1
ELSE
Zaehler=Zaehler+1
thanks
Martin
Seite
UseWeckzeit
UseRollozeit
Zaehler
DEFINE_PROGRAM
IF(Zaehler>=20)
Zaehler=1
ELSE
Zaehler=Zaehler+1
Because you have the statement in DEFINE_PROGRAM, it is running very often (I would guess at least 300 times per second). Also, the time you are sending is the time when you compiled your program, not the current time. By putting everything in a wait statement, the program tracks the wait and will only create a single SEND_STRING every 2 minutes.
@a_riot42
This way works, but why?
IF(Zaehler=400)
Zaehler=1
ELSE
Zaehler=Zaehler+1
IF(Zaehler=2)
SEND_STRING ********,"'AMX-Zeit ',time,$0D"
@Spire_Jeff
Thanks for thr hint 'bout __Time__ and Time....
The "wait" will be maybee one of the final solutions but I will find out what's wrong? In Basic (1981) I've had no problems....
Regards
Martin
I would think you'd see other numbers ocassionally in the debugger but it's counting so fast debugger can't keep up and if it could then your eyes couldn't.
This code is dependant of how often your processor runs through the main line and it will vary depending on what's going on in your system so it's really not a proper way of timing at all if that is indeed what you're trying to accomplish. If you actually want to count main line passess then this should be fine but if you actually want to send a string every minute or two the wait is the simple and likely the most efficient way to go.
Now if your master actually does run through the main line around 300 x per second which I think is probably a good estimate then you are going to be sending your string every 1.25 second or there abouts which is another burden your system could do with out. Your 1st version was so fast I'm suprised it didn't bring your system to a crawl trying to send strings 15 times per second.
