Trouble Receiving from Keypad
Hey all,
I'm using the following code to call a keypad:
Then here is my string handler for the panels:
Now I've placed breaks in the String event, but it's as if it's simply receiving nothing from the panel; the STRING event is never engaging, and therefore nothing is happening... I'm straight up confused, and certain there's likely something small or simple I'm forgetting. Please help.
Thanks all!
SEND_COMMAND dvTPANELS[nLAST_PANEL],"'@AKB-;Enter Name:'" WAIT_UNTIL (!nPROPERTY_WAITING_ON_INPUT[nLAST_PANEL]) { sTEMP_LUTRON_INFO[nLAST_PANEL].cTITLE_OFF = sUSER_INPUT[nLAST_PANEL] sTEMP_LUTRON_INFO[nLAST_PANEL].cTITLE_ON = sUSER_INPUT[nLAST_PANEL] } }
STRING: { STACK_VAR INTEGER nLAST_PANEL nLAST_PANEL = GET_LAST(dvTPANELS) IF(nPROPERTY_WAITING_ON_INPUT[nLAST_PANEL]) { sUSER_INPUT[nLAST_PANEL] = "sUSER_INPUT[nLAST_PANEL],DATA.TEXT" SELECT { ACTIVE(FIND_STRING(sUSER_INPUT[nLAST_PANEL],'KEYB-',1)): REMOVE_STRING(sUSER_INPUT[nLAST_PANEL],'KEYB-',1) ACTIVE(FIND_STRING(sUSER_INPUT[nLAST_PANEL],'KEYP-',1)): REMOVE_STRING(sUSER_INPUT[nLAST_PANEL],'KEYP-',1) } OFF[nPROPERTY_WAITING_ON_INPUT[nLAST_PANEL]] } }
Thanks all!
As part of my STRING events on panels, I do a "SEND_STRING 0, DATA.TEXT" while debugging just to see exactly what is coming in. If you get nothing, it's going to the wrong port. If you get something besides "KEYP-", the text field is misnamed.
It's quite frustrating, however, as I'm pretty sure the STRING event of DATA_EVENT[dvTPANELS] is not happening at all. I know the DATA_EVENT is fine, though, as the ONLINE events within the same DATA_EVENT are working just fine.
Any ideas on potential reasons why the keyboard would be displaying, yet nothing is getting to the Panel? I can show more code if it would help.
Is there a clever way to do a Data Event on the different port of the same device, without creating a whole new Device? For example, checking port 1 of a Device address of 10109:3:1?
If not, then suck. But thanks!
dvPanelBase.NUMBER = dvPanel.NUMBER
dvPanelBase.PORT = 1
dvPanelBase.SYSTEM = dvPanel.SYSTEM
Then trap the STRING event for dvPanelBase.
