Bathroom Audio Turns on Max Volume Randomly
                    I programmed an AMX control system for a company outside of Chicago and they have been seeing some strange behavior. The master bath audio zone has been turning on at the max volume at random times throughout the day. One time the homeowner left to go to the store and then came back and the bathroom audio was on at full volume. This particular zone has one AMX R-4 and one DMS Pinnacle keypad. The rest of the system is as follows:
AMX 4100
8 R-4's
14 DMS Pinnacle Keypads
Autopatch Optima Video Switcher
Autopatch Precis LT DSP Audio Switcher
LG Blu-Ray Player
3 DirectTV DVR's
Russound ST2XM Tuner
8 LG TV's
2 AUTON Lifts
1 Somfy Blinds
The one thing we are currently attempting to do is to monitor the system using the AMX Diagnostics and Notifications to see what, if anything, registers when this happens. Hopefully, this will be able to tell us if something in the program is making this happen or if there is some other cause for this behavior. Any suggestions or ideas you guys have as to why this might happen would be much appreciated.
Thanks in Advance!
Edit/Delete Message
                AMX 4100
8 R-4's
LG Blu-Ray Player
3 DirectTV DVR's
8 LG TV's
2 AUTON Lifts
1 Somfy Blinds
Thanks in Advance!
Edit/Delete Message
It has been a problem when someone turns up a quiet music server only to be blasted when they switch to XM radio.
We use lighting keypads to turn off the zones when someone leaves the area, pushes goodnight/away/etc.
This has reduced how often we have to deal with this.
You can adjust the input volume levels to try and balance the audio levels between different sources on most audio switchers. I know that AMX/Autopatch units support this. Sometimes, there is a big enough discrepancy
that you actually have to lower a bunch of the sources in addition to raising the volume of a really quiet source to get them close. On the autopatch, these settings really just adjust the output volume accordingly, if I recall correctly, so if you are playing at the far end of the volume spectrum, you will still have discrepancies.
