Events Mirroring
Hello)
I have a newbie problem
There is a Virtual Device. I want the following:
PUSH(vdvButton) --> BUTTON_EVENT[vdv] ---> <Do something>
In vdv module I use DO_PUSH()/DO_RELEASE() for buttons and ON/OFF for channels, assuming buttons and channels can have IDs 1-255.
In mainline I write the following:
INTEGER BtnCodes[255]
DEFINE START
// Filling BtnCodes array...
// for (i=1;i<-255; i++) BtnCodes=i
BUTTON_EVENT[vdv, BtnCodes]
Send_String 0, "'Button #',ITOA(BUTTON.INPUT.Channel),' PUSH'"
RELEASE:
Send_String 0, "'Button #',ITOA(BUTTON.INPUT.Channel),' RELEASE'"
But this Button_Event never activates. I expected DO_PUSH/RELEASE would generate BUTTON_EVENT with same button code as in DO_PUSH/RELEASE.
Thanks in advance.
DEFINE START
RELEASE:
Thanks in advance.
HTH
for (cnt = 1; cnt<=255; cnt++)
BtnID[cnt]=cnt
ChlID[cnt]=cnt
SET_LENGTH_ARRAY(BtnID, 255)
SET_LENGTH_ARRAY(ChlID, 255)
BUTTON_EVENT[vdvSCTPServer, BtnID]
SEND_STRING 0, "'[!] SCTP to Mainline: Button PUSH: #',ITOA(BUTTON.INPUT.CHANNEL)"
RELEASE:
SEND_STRING 0, "'[!] SCTP to Mainline: Button RELEASE: #',ITOA(BUTTON.INPUT.CHANNEL)"
BUTTON_EVENT still never activates...
A part of vdv Module Code
MODULE_NAME='SCTP_Comm'( DEV vdvSCTPServer, DEV dvSCTPServer, INTEGER nSCTPPort)
DATA_EVENT[dvSCTPServer]
STRING:
// Parsing DATA.TEXT to get Button ID to push/release
DO_PUSH(vdvSCTPServer, Parsed_Button_ID)
A part of Mainline Code
RELEASE:
I call DO_PUSH when i get DATA_EVENT(vdv): STRING. It "pushes" a button on a Virtual Device. I want feedback for this event in mainline
1) How are the two DEVs defined?
2) Do you know a STRING is coming in at dvSCTPServer? You can verify that by doing a send_string 0 in the STRING handler for dvSCTPServer
3) How are you calculating Parsed_Button_ID? Are you sure it's an integer?
Diag says, virtual Button actually pushes so the trouble is in mainline BUTTON_EVENT.
Answers:
1)
vdvSCTPServer = 34999:1:0
dvSCTPServer = 0:2:0
2) Sure thing.
3) Absolutely sure.
DEFINE_DEVICE dvDev = 0:12:1; vdvDev = 33009:1:1; DEFINE_MODULE 'Module' mdl(vdvDev, dvDev) DEFINE_EVENT button_event[vdvDev,1] { push: { send_string 0,"'push'"; } release: { send_string 0,"'release'"; } }in the module i have somewhere
do_push(vdvDev,1);
turn messages on and i see the result
(0000132575) push
(0000133072) release
fire up Diag again and check that your variable BtnID has what you are expecting.
Enable Push message display so you can see whats going on.
Can I take a look at your code?)
Filpee:
The problem isn't to write BUTTON_EVENT(dv, StaticID), but BUTTON_EVENT(dv, Array_of_IDs) instead.
Main program code:
DEFINE_DEVICE dvComm = 5001:1:0 vdvTest = 33001:1:0 DEFINE_START DEFINE_MODULE 'TestMod' mdlTest(vdvTest, dvComm) DEFINE_EVENT BUTTON_EVENT[vdvTest,1] { PUSH: { SEND_STRING 0, 'Got push in main program' } RELEASE: { SEND_STRING 0, 'Got release in main program' } }Module code:
MODULE_NAME='TestMod' (DEV vdvTest, DEV dvTest) DEFINE_EVENT DATA_EVENT[dvTest] { STRING: { SEND_STRING 0, 'Got string in module' DO_PUSH(vdvTest,1) } }Output when I use Emulate a Device and send a string to dvComm:
BUTTON_EVENT with statically specified Button ID works for me, for you and for all.
I virtually 'push/release' buttons on vdv. I assume it can have a maximum of 255 buttons.
When I call DO_PUSH/RELEASE, I specify Button ID. I want only ONE BUTTON_EVENT in mainline that could process a PUSH/RELEASE of ANY of 255 virtual buttons
Main program:
DEFINE_DEVICE dvComm = 5001:1:0 vdvTest = 33001:1:0 DEFINE_CONSTANT INTEGER nSomeButtons[] = {11,12,13,14,15} DEFINE_START DEFINE_MODULE 'TestMod' mdlTest(vdvTest, dvComm) DEFINE_EVENT BUTTON_EVENT[vdvTest,nSomeButtons] { PUSH: { SEND_STRING 0, "'Got push for button ',ITOA(nSomeButtons[GET_LAST(nSomeButtons)]),' in main program'" } RELEASE: { SEND_STRING 0, "'Got release for button ',ITOA(nSomeButtons[GET_LAST(nSomeButtons)]),' in main program'" } }Module:
MODULE_NAME='TestMod' (DEV vdvTest, DEV dvTest) DEFINE_EVENT DATA_EVENT[dvTest] { STRING: { SEND_STRING 0, 'Got string in module' DO_PUSH(vdvTest,11) } }Output when using Emulate a Device to send a string to dvComm
But how to do the same thing with { 1, ... , 255 } ?
Sure, I don't want to write scary things like { 1,2,3,4,5,6,7,8,9,10,11,12 ... 100,101,102,103... 255}
When I try to fill array in loop, it doesn't work somehow
Like this:
DEFINE_VARIABLE INTEGER nSomeButtons[255] INTEGER x DEFINE_START FOR (x=1; x<=255; x++) { nSomeButtons[x] = x } SET_LENGTH_ARRAY(nSomeButtons,255) REBUILD_EVENT()As further explanation, the event table is built at compile time before your button array is initialized which is why the events weren't firing. That's why you need to use REBUILD_EVENT() so the event table can get reconstructed.
Also if you want to use more than 255 buttons just use SET_VIRTUAL_CHANNEL() in the ONLINE handler for the virtual device. For example if you want 1000 buttons you can do this:
SET_VIRTUAL_CHANNEL_COUNT(vdvSCTPServer,1000)
Have fun.
You almost got it. You want to use the REBUILD_EVENT() function.
Here is an example from NetLinx Help.
dvTP = 10001:1:0
INTEGER X // loop counter
INTEGER nBTNS[4000]
FOR (X = 1; X <= 4000; X++)
nBtns[X] = X
// the braces below enclose a variable update and
// rebuild_event statement in a single block
SET_LENGTH_ARRAY(nBtns,4000)
REBUILD_EVENT()
BUTTON_EVENT[dvTP,nBtns]
// end
