Setting Variable Fonts
Hello all,
I was hoping to change the font size of a button via a ^BMF command. I recalled, however, that you're only given a list of Font Codes to choose from, so I went to the list. None of the fonts satisfied what I was looking for, but I noticed at the bottom it had the line:
Any insight on this would be greatly appreciated.
Thanks!
This suggests to me that there's a range of font codes which you can set. But after hunting around PI and the TPD4 documentation, I couldn't for the life of me find anything that explained how to do this.Variable Fonts start at 32.
Thanks!
Generate a programmers report from TPD4 while you have the TP file open. In Product Information (PI) for any G4 touch panel is the note: "Font ID numbers are generated by the TPDesign4 programmers report."
