Issue with dynamic images on an MVP 8400
I am having an issue with one set of dynamic images updating on a panel. The images are stored on the master under images/Weather.
I tested this on another system and it works fine but when I brought it to the master and touch panel in my office the images aren't updating correctly.
The only thing that differs are the following:
Test system:
NI 700 with latest duet firmware and device firmware
MVP 8400 with latest firmware
Office system:
NI 3100 with latest duet firmware and device firmware
The other dynamic images pulled from website are updating on both panels correctly. Any ideas?
TIA
Chris
Test system:
Send_Command dvPanel,"'^RMF-nav_weather_icon,%P1%U',sMasterUser,'%S',sMasterPass,'%H',sMaster,'%A',sMasterPath,'%F',sWeather.sIcon" sMaster[15] = '192.168.001.200' /// Change to correct master address sMasterPath[16] = '/images/Weather/' /// Change to correct image path sMasterUser[13]='NetLinx' /// Needed to update nav bar image sMasterPass[8]='password' /// Needed to update nav bar image sWeather.sIcon = '44d.png'
Office system:
Send_Command dvPanel,"'^RMF-nav_weather_icon,%P1%U',sMasterUser,'%S',sMasterPass,'%H',sMaster,'%A',sMasterPath,'%F',sWeather.sIcon" sMaster[15] = '192.168.042.200' /// Change to correct master address sMasterPath[16] = '/images/Weather/' /// Change to correct image path sMasterUser[13]='NetLinx' /// Needed to update nav bar image sMasterPass[8]='password' /// Needed to update nav bar image sWeather.sIcon = '44d.png'
TIA
Chris
wonder why
I will give that a try and report back
Good call on that one that was the problem go figure LOL
I've had a similar issue. I've found that systems with NI3000 units in work fine (as long as they dont have duet firmware) as do ME260 but 31/41 series seem to have an issue.
