System keypad?
Is there any way to change the port it outputs on? I copied one and it defaults to device 1. Any way to get it on a different device?
  • The strings from Keyboard, keypad, etc.. always come on port 1 of the panel. If you are using i.e. a keyboard copied from the panel template, you can rename the prefix of the keyboard string sent from the panel, to identify what keyboard it was. See screenshot.
    1) create your panel
    2) open the System Page Template from menu File- -> Open System Page Template
    3) from Popup Pages, copy "__keyboard" into your panel design, it will be renamed to "_keyboard", rename it for your needs, it's just a popup page.
    4) open the popup, and like in the screenshot, edit the "Name" of the text field. This is the prefix sent from thepanel when you push DONE on the keyboard
