unexpected result HELPPP
somebody please help me with this block
[php]
(*Micz 1 - 8 Mute ON/OFF TOGGLE*)
case 87:(*Mics 1*)
case 88:(*Mics 2*)
case 89:(*Mics 3*)
case 90:(*Mics 4*)
case 91:(*Mics 5*)
case 92:(*Mics 6*)
case 93:(*Mics 7*)
case 94:(*Mics 8*)
local_var integer nChanID
local_var integer nMicMuteStatus[8]
local_var integer nMicStatLoop
nChanID = (button.input.channel - 183)
for(nMicStatLoop=1;nMicStatLoop<=8;nMicStatLoop++)
if (nMicMuteStatus[nMicStatLoop] = 0)
AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(nChanID),' ',itoa(nChanID),' ','1',$0A,$FF")
nMicMuteStatus[nChanID] = 1
else if (nMicMuteStatus[nMicStatLoop] = 1)
AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(nChanID),' ',itoa(nChanID),' ','0',$0A,$FF")
nMicMuteStatus[nChanID] = 0
[/php]
it runs through all 8 I only need 1 if event happened, what am i over looking?
[php]
case 87:(*Mics 1*)
case 88:(*Mics 2*)
case 89:(*Mics 3*)
case 90:(*Mics 4*)
case 91:(*Mics 5*)
case 92:(*Mics 6*)
case 93:(*Mics 7*)
case 94:(*Mics 8*)
[/php]
(*Micz 1 - 8 Mute ON/OFF TOGGLE*) case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) case 94:(*Mics 8*) { local_var integer nChanID nChanID = (button.input.channel - 183) if (nMicMuteStatus[nChanID ] = 0) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(nChanID),' ',itoa(nChanID),' ','1',$0A,$FF") nMicMuteStatus[nChanID] = 1 } else if (nMicMuteStatus[nChanID] = 1) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(nChanID),' ',itoa(nChanID),' ','0',$0A,$FF") nMicMuteStatus[nChanID] = 0 } } }if lets say nchanID = 3 like so:-(*Micz 1 - 8 Mute ON/OFF TOGGLE*) case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) case 94:(*Mics 8*) { if (nMicMuteStatus[3] = 0) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(3),' ',itoa(3),' ','1',$0A,$FF") nMicMuteStatus[3] = 1 } else if (nMicMuteStatus[3] = 1) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(3),' ',itoa(3),' ','0',$0A,$FF") nMicMuteStatus[3] = 0 } } }same ending result.....The only other thing I can see is that you are talking about the first Case statements. If you don't want mics 1-7 to hit the code, you need to either remove them from the code, or make them do nothing like such:
case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) { //Add this code Later } case 94:(*Mics 8*) . . .This is actually a feature that it lets you declare multiple cases for the same block of code.
(*Polycom Remote Simulation*) case 1://{pulse[vdvPolycomVSX,10]}//Keypad 0 // DO NOT DELETE !! case 2://{pulse[vdvPolycomVSX,11]}//Keypad 1 // case 3://{pulse[vdvPolycomVSX,12]}//Keypad 2 // case 4://{pulse[vdvPolycomVSX,13]}//Keypad 3 // case 5://{pulse[vdvPolycomVSX,14]}//Keypad 4 // REMOTE EMULATION WITHOUT TOUCHPANEL FEEDBACK COMMENT LINEZ case 6://{pulse[vdvPolycomVSX,15]}//Keypad 5 // AS NEEDED IF YOU ONLY NEED THIS FEATURE!!!!! case 7://{pulse[vdvPolycomVSX,16]}//Keypad 6 // case 8://{pulse[vdvPolycomVSX,17]}//Keypad 7 // case 9://{pulse[vdvPolycomVSX,18]}//Keypad 8 // case 10://{pulse[vdvPolycomVSX,19]}//Keypad 9 // DO NOT DELETE !! case 11://Keypad Asterick case 12://Keypad Pound case 13://Keypad Period/Star ( . ) (* Keypad with touchpanel feedback*) { select { active((button.input.channel >=1)&&(button.input.channel <=10)): { cPolycom_key = itoa(button.input.channel - 1) } active(1): { select { active(button.input.channel = 13):{cPolycom_key = '*'} active(button.input.channel = 12):{cPolycom_key = '#'} active(button.input.channel = 11):{cPolycom_key = ','} } } } cPolycom_Num = "cPolycom_Num,cPolycom_key" //append to key to string //send_command vdvPolycomVSX,"'DIALNUMBER-',itoa(cPolycom_Num)" //send string to module send_command dvTP_VTC,"'^TXT-18,0, ',cPolycom_Num" //send string to panel }so thinking would apply the same concept on the last modified but put that on the table and send it not all the grimlins.(*Micz 1 - 8 Mute ON/OFF TOGGLE*) case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) case 94:(*Mics 8*) { send_string 0, "'button.input.channel=', button.input.channel" if (nMicMuteStatus[3] = 0) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(3),' ',itoa(3),' ','1',$0A,$FF") nMicMuteStatus[3] = 1 } else if (nMicMuteStatus[3] = 1) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(3),' ',itoa(3),' ','0',$0A,$FF") nMicMuteStatus[3] = 0 } } }Is your entire switch/case in a FOR loop? Can you give more details on exactly what is happening 8 times?
I agree that the CASE: stack (and other stacks available for us to use) are bizzare. But, I hope they keep them. I do use them all the time. I wish they were allowable in some other languages I have to peck through.
Unless I'm misunderstanding he actually wants all of the cases to trigger the same code block.
I agree, I hope they keep this "feature" as I use it quite often.
if mic 5
(*Micz 1 - 8 Mute ON/OFF TOGGLE*) case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) case 94:(*Mics 8*) { if (nMicMuteStatus[(*Mics 5*) ] = 0) //element 5 = 0 { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa((*Mics 5*) ),' ',itoa((*Mics 5*) ),' ','1',$0A,$FF") //fdr 5 channel 5 nMicMuteStatus[(*Mics 5*) ] = 1 } else if (nMicMuteStatus[(*Mics 5*) ] = 1) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa((*Mics 5*) ),' ',itoa((*Mics 5*) ),' ','0',$0A,$FF") //fdr 5 channel 5 nMicMuteStatus[(*Mics 5*) ] = 0 //element 5 = 0 } } }or the longer way I gave up grrrrrr
(*Micz 1 - 8 Mute ON/OFF TOGGLE*) case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) case 94:(*Mics 8*) { local_var integer nMicMuteStatus[8] select { active((nMicMuteStatus[1] = 0)&&(button.input.channel = 87)): { AddtoNexiaQue("'SET 1 FDRMUTE 1 1 1',$0A,$FF")nMicMuteStatus[1] = 1 } active((nMicMuteStatus[2] = 0)&&(button.input.channel = 88)): { AddtoNexiaQue("'SET 1 FDRMUTE 2 2 1',$0A,$FF")nMicMuteStatus[2] = 1 } active((nMicMuteStatus[3] = 0)&&(button.input.channel = 89)): { AddtoNexiaQue("'SET 1 FDRMUTE 3 3 1',$0A,$FF")nMicMuteStatus[3] = 1 } active((nMicMuteStatus[4] = 0)&&(button.input.channel = 90)): { AddtoNexiaQue("'SET 1 FDRMUTE 4 4 1',$0A,$FF")nMicMuteStatus[4] = 1 } active((nMicMuteStatus[5] = 0)&&(button.input.channel = 91)): { AddtoNexiaQue("'SET 1 FDRMUTE 5 5 1',$0A,$FF")nMicMuteStatus[5] = 1 } active((nMicMuteStatus[6] = 0)&&(button.input.channel = 92)): { AddtoNexiaQue("'SET 1 FDRMUTE 6 6 1',$0A,$FF")nMicMuteStatus[6] = 1 } active((nMicMuteStatus[7] = 0)&&(button.input.channel = 93)): { AddtoNexiaQue("'SET 1 FDRMUTE 7 7 1',$0A,$FF")nMicMuteStatus[7] = 1 } active((nMicMuteStatus[8] = 0)&&(button.input.channel = 94)): { AddtoNexiaQue("'SET 1 FDRMUTE 8 8 1',$0A,$FF")nMicMuteStatus[8] = 1 } active((nMicMuteStatus[1] = 1)&&(button.input.channel = 87)): { AddtoNexiaQue("'SET 1 FDRMUTE 1 1 0',$0A,$FF")nMicMuteStatus[1] = 0 } active((nMicMuteStatus[2] = 1)&&(button.input.channel = 88)): { AddtoNexiaQue("'SET 1 FDRMUTE 2 2 0',$0A,$FF")nMicMuteStatus[2] = 0 } active((nMicMuteStatus[3] = 1)&&(button.input.channel = 89)): { AddtoNexiaQue("'SET 1 FDRMUTE 3 3 0',$0A,$FF")nMicMuteStatus[3] = 0 } active((nMicMuteStatus[4] = 1)&&(button.input.channel = 90)): { AddtoNexiaQue("'SET 1 FDRMUTE 4 4 0',$0A,$FF")nMicMuteStatus[4] = 0 } active((nMicMuteStatus[5] = 1)&&(button.input.channel = 91)): { AddtoNexiaQue("'SET 1 FDRMUTE 5 5 0',$0A,$FF")nMicMuteStatus[5] = 0 } active((nMicMuteStatus[6] = 1)&&(button.input.channel = 92)): { AddtoNexiaQue("'SET 1 FDRMUTE 6 6 0',$0A,$FF")nMicMuteStatus[6] = 0 } active((nMicMuteStatus[7] = 1)&&(button.input.channel = 93)): { AddtoNexiaQue("'SET 1 FDRMUTE 7 7 0',$0A,$FF")nMicMuteStatus[7] = 0 } active((nMicMuteStatus[8] = 1)&&(button.input.channel = 94)): { AddtoNexiaQue("'SET 1 FDRMUTE 8 8 0',$0A,$FF")nMicMuteStatus[8] = 0 }BUTTON_EVENT [dvMics,nMicBtnArry] { PUSH: { STACK_VAR INTEGER nMicBtn ; nMicBtn = GET_LAST(nMicBtnArry) ; SELECT { ACTIVE(nMicBtn >= 1 && nMicBtn <= 86): { //stuff } ACTIVE(nMicBtn >= 87 && nMicBtn <= 94): { SWITCH(nMicBtn) { case 87:(*Mics 1*) case 88:(*Mics 2*) case 89:(*Mics 3*) case 90:(*Mics 4*) case 91:(*Mics 5*) case 92:(*Mics 6*) case 93:(*Mics 7*) case 94:(*Mics 8*) { STACK_VAR INTEGER nMic ; nMic = nMicBtn - 86 ; if (nMicMuteStatus[nMic] == 0) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(nMic),' ',itoa((nMic),' ','1',$0A,$FF") //fdr 5 channel 5 nMicMuteStatus[nMic] = 1 } else if (nMicMuteStatus[nMic] == 1) { AddtoNexiaQue("'SET 1 FDRMUTE',' ',itoa(nMic),' ',itoa(nMic),' ','0',$0A,$FF") //fdr 5 channel 5 nMicMuteStatus[nMic] = 0 } } } } ACTIVE(nMicBtn >= 95 && nMicBtn <= 120): { //stuff } } } }And don't put comments in your braces cuz that really messed with my head!
I have never had an issue using = where == is technically correct. Anyone else?
I've started trying to use == because it is the proper way, and it can also make the code easier to read - especially with things like
