Novara DCS?
I may be blind or going carzy, but can someone tell me where this program is hiding?
    KennyKenny Posts: 209
    AMX tech support should be able to get the program to you.
    Jimweir192Jimweir192 Posts: 502
    goto www.procon.co.uk and download the Prosoft 7 software installer.
    The Procon stuff is the AMX Novara range - I suspect the software will be being rebranded shortly... I'm assuming that AMX hasn't changed too much on the firmware just yet...
    As a thought I wonder what the plan is with the IR database as it is a different format to the AMX IR db - I would hope to see this combined into one IR db - prehaps an opportunity to resolve IREdit and the IRIS!!??!!
    mcottonmcotton Posts: 38
    The download link doesn't work any more. Here is the actual link: http://www.procon.co.uk/downloads/prosoft.zip
    matt95gsrmatt95gsr Posts: 165
    Jimweir192 wrote: »
    I hadn't even thought about that yet. I sure hope we don't have to deal with another set of IR data long-term. At least a good set of conversion utilities to go back and forth between the two formats?
    Ir files
    A third party IR file manager would be nice with export for all the major control systems. It gets painfull trying to maintain all the different data bases.
    Novara DCS1000 has the possibility to import .IRL files or HEX codes.
    On the homepage, you'll find the software in
    Tech Center -> Application Files -> Category Controlpad Design Tools
