B&K 2 Way
How can i get data and states of my unit (BK AVR 505) over 232. The protocol is somewhat confusing to me. Once the receiver sends me a string of data how can i pull that data out of the string ?
Example If i need feedback for volume level.
Does anyone know the commands?
    davidv wrote: »
    That should have been covered in Programming I.
    You get the string data from a DATA_EVENT.
    If you go to the help menu and search for it, you'll see the syntax and whatnot.
    hope that helps
    As Eric says, you can use the string handler in the data_event or alternatively you can create a buffer and then parse the result to gain the information you need.
    It is well worth the time spent in learning how to parse a string using the tools available in Netlinx - there are many ways and very few are "wrong" - searching on these forums for parsing will give you many a pointer.
    Look at LEFT_STRING, MIDSTRING & REMOVE_STRING for starters
  • davidvdavidv Posts: 90
    CODE
    PROGRAM_NAME='AVR505 Sourve'
    Define_Device
    dvtp = 10001:1:1
    dvBK = 5001:1:1
    data_event [dvBK]
    String:
    What do i type here to get the data from the string?
  • dthorsondthorson Posts: 103
    DEFINE_EVENT ///////////////// Device Communication
    DATA_EVENT[dvPLASMA]
      ONLINE:
    	SEND_COMMAND dvPLASMA,'SET BAUD 9600,N,8,1 485 DISABLE';
    	SEND_COMMAND dvPLASMA,'HSOFF';
    	//lPowerTimeArray[1] = lPowerPollTime
    	//TIMELINE_CREATE(lPowerTimeLine,lPowerTimeArray,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT)
    	lStatusTimeArray[1] = lStatusPollTime
    	TIMELINE_CREATE(lStatusTimeline,lStatusTimeArray,1,TIMELINE_ABSOLUTE,TIMELINE_REPEAT)
      STRING:
    	CHAR cTrash[25];
    	cPlasmaRX = DATA.TEXT;
    	///////////////// Static Feedback Commands
    	IF(FIND_STRING(cPlasmaRX,"$AA,$FF,$FF,$03,$41,$11,$01,$54",1) > 0)
    		  iPlasmaPower = 1;
    		  CALL 'SEND_STRING_FEEDBACK'(vdvPLASMA,'POWER',ITOA(iPlasmaPower));
    	IF(FIND_STRING(cPlasmaRX,"$AA,$FF,$FF,$03,$41,$11,$00,$53",1) > 0)
    		  iPlasmaPower = 0;
    	IF(FIND_STRING(cPlasmaRX,"$AA,$FF,$FF,$03,$41,$11,$02,$55",1) > 0) //Unit in standby/no PC sync
    		  iPlasmaPower = 0;
