Program Info is Blank
I've got an NI-3100 that's been running fine for about 2 years, the last programming update to it was done 14 months ago. All of the sudden, after having unplugged the unit for about 10 minutes, the master is no longer functioning properly. Here are the symptoms:
The unit is online, device number, system number, everything is fine. I can telnet into it, the touchpanel connects to it, it's in a master-master network and it can see and be seen by the other masters. Diagnostics, Notifications all work -- BUT, it appears as though there's no program loaded in it anymore. When I telnet in and execute the 'program info' command, I get a response as though nothing's in there. I loaded a small 2 line program to send a diagnostic message every 10 seconds and that loads and functions fine. Executing a 'program info' command returns the program name. When I load the program that's been in there for 2 years, we're back to the original symptoms as though there's no program loaded.
I've issued clean disk commands, reloaded firmware, changed the name of the program, boosted the duet memory up, commented out the duet modules that were in there... any ideas what to check next? One thing too is that I think the CMOS battery may be bad, since we've been having issues with the time and date falling behind lately.
Thanks for reading this long post.
--John
    Are you disabling the running program when you issue the 'Clean Disk' command? (flip the first DIP switch to disable the running program - reboot) Even though the thing seems empty, there could be some kind of fouled up program running that is messing it up.
  • Just had a technician flip the switch to try it. Same issues. Threw it into PRD, rebooted, clean disk, rebooted, load program, rebooted, telnet in, program info is blank.
    Format Disk doesn't seem to work either by the way, only clean disk. Is that command still supported?
    --John
    After a reboot, telnet in and do a show log all. Scroll down to the bottom and see if you can find any clues in the startup routine. Maybe you are out of memory?
    Was this code recompiled or is it the original .tkn file you're trying to download?
  • Thanks for helping me out guys.
    I don't see any obvious errors in the startup logs. Memory seems to be o.k., and using a get mem command it shows plenty of space too.
    When I reloaded the program, I first reloaded the original .tkn, then I recompiled it and loaded the new .tkn, then I saved the program as a different name, recompiled and loaded that .tkn. Same issue occurred with all of those files -- no program info. The only one that showed up and functioned correctly was my little 2 line program.
    Here's a copy of the log in case I didn't see something. I have to admit, I don't understand a lot of what the logs indicate unless it's glaringly obvious.
    --John
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2008.07.31 09:40:06 =~=~=~=~=~=~=~=~=~=~=~=
    >program info
    -- Program Name Info
    >show mem
    Volatile Free   : 23993312 (largest free block in bytes)
    NonVolatile Free:  1047536 (bytes free)
    Disk Free       :120139776 (bytes of free space)
    Duet Memory Free :  6990848 (bytes)
     Partition 1 -   6990848 (bytes)
     Partition 2 - <UNKNOWN>
    >show log all
    Message Log for System 3 Version: v3.30.371
    Entry        Date/Time       Object
         Text
      1: 06-06-2008 FRI 01:12:55 TelnetSvr
         Accepted Telnet connection:socket=31 addr=192.168.110.79 port=3351
      2: 06-06-2008 FRI 01:11:40 TelnetSvr
         Accepted Telnet connection:socket=31 addr=192.168.110.79 port=3348
      3: 06-06-2008 FRI 01:11:37 Unknown
         DDD.handleDynamicDevice(): new DPD - 192.168.110.23
      4: 06-06-2008 FRI 01:10:56 ConnectionManager
         Memory Available = 23998408 <25232>
      5: 06-06-2008 FRI 01:10:56 Unknown
         IPDeviceDetector.run(): joined multicast group
      6: 06-06-2008 FRI 01:10:10 ConnectionManager
         Memory Available = 24023640 <81248>
      7: 06-06-2008 FRI 01:10:10 TelnetSvr
         Accepted Telnet connection:socket=31 addr=192.168.110.79 port=3343
      8: 06-06-2008 FRI 01:09:47 Unknown
         (Reader=(null) writer=tDeviceMgr)- CMessagePipe::Max = 75
      9: 06-06-2008 FRI 01:09:47 Unknown
         (Reader=(null) writer=tDeviceMgr)- CMessagePipe::Max = 50
     10: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 11 Online: Route 1 Metric 2
     11: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 10 Online: Route 1 Metric 2
     12: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 7 Online: Route 1 Metric 2
     13: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 5 Online: Route 1 Metric 2
     14: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 4 Online: Route 1 Metric 2
     15: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 2 Online: Route 1 Metric 2
     16: 06-06-2008 FRI 01:09:37 RouteManager
         Remote System 1 Online: Route 1 Metric 1
     17: 06-06-2008 FRI 01:09:37 ConnectionManager
         Memory Available = 24104888 <38168>
     18: 06-06-2008 FRI 01:09:36 ConnectionManager
         Memory Available = 24143056 <44160>
     19: 06-06-2008 FRI 01:09:36 ConnectionManager
         Memory Available = 24187216 <69184>
     20: 06-06-2008 FRI 01:09:36 Unknown
         (Reader=tDeviceMgr writer=tConnectMgr)- CMessagePipe::Max = 50
     21: 06-06-2008 FRI 01:09:36 ConnectionManager
         Memory Available = 24256400 <82328>
     22: 06-06-2008 FRI 01:09:36 Unknown
         (Reader=tConnectMgr writer=ICSPTCPRx29)- CMessagePipe::Max = 50
     23: 06-06-2008 FRI 01:09:36 Unknown
         (Reader=(null) writer=tDeviceMgr)- CMessagePipe::Max = 25
     24: 06-06-2008 FRI 01:09:36 Unknown
         (Reader=tDeviceMgr writer=tConnectMgr)- CMessagePipe::Max = 25
     25: 06-06-2008 FRI 01:09:36 Unknown
         (Reader=tConnectMgr writer=ICSPTCPRx29)- CMessagePipe::Max = 25
     26: 06-06-2008 FRI 01:09:36 ConnectionManager
         Memory Available = 24338728 <38224>
     27: 06-06-2008 FRI 01:09:33 ConnectionManager
         Memory Available = 24376952 <251080>
     28: 06-06-2008 FRI 01:09:33 Unknown
         01:09:33.299 EVENT  Started org.mortbay.jetty.Server@7943b6
     29: 06-06-2008 FRI 01:09:33 Unknown
         01:09:33.299 EVENT  Started SocketListener on 0.0.0.0:443
     30: 06-06-2008 FRI 01:09:32 ConnectionManager
         Memory Available = 24628032 <246304>
     31: 06-06-2008 FRI 01:09:32 Unknown
         01:09:32.449 EVENT  Started SocketListener on 0.0.0.0:83
     32: 06-06-2008 FRI 01:09:32 Unknown
         01:09:32.233 EVENT  Starting Jetty/4.2.x
     33: 06-06-2008 FRI 01:09:32 Unknown
         DynamicServlet 0.0.1 has been started
     34: 06-06-2008 FRI 01:09:32 Unknown
         01:09:32.183 EVENT  Started ServletHttpContext[/]
     35: 06-06-2008 FRI 01:09:31 ConnectionManager
         Memory Available = 24874336 <90240>
     36: 06-06-2008 FRI 01:09:31 Unknown
         SecurityServlet 0.0.1 has been started
     37: 06-06-2008 FRI 01:09:31 Unknown
         01:09:31.699 EVENT  Started ServletHttpContext[/]
     38: 06-06-2008 FRI 01:09:31 Unknown
         ConfigServlet 0.0.1 has been started
     39: 06-06-2008 FRI 01:09:31 Unknown
         01:09:31.033 EVENT  Started ServletHttpContext[/]
     40: 06-06-2008 FRI 01:09:30 ConnectionManager
         Memory Available = 24964576 <193632>
     41: 06-06-2008 FRI 01:09:30 ConnectionManager
         Memory Available = 25158208 <156416>
     42: 06-06-2008 FRI 01:09:30 Unknown
         DeviceServlet 0.0.1 has been started
     43: 06-06-2008 FRI 01:09:30 Unknown
         01:09:30.499 EVENT  Started ServletHttpContext[/]
     44: 06-06-2008 FRI 01:09:30 Unknown
         RootServlet 0.0.1 has been started
     45: 06-06-2008 FRI 01:09:30 Unknown
         01:09:30.049 EVENT  Started ServletHttpContext[/]
     46: 06-06-2008 FRI 01:09:29 ConnectionManager
         Memory Available = 25314624 <130416>
     47: 06-06-2008 FRI 01:09:29 Unknown
         01:09:29.533 EVENT  Started ServletHttpContext[/]
     48: 06-06-2008 FRI 01:09:29 Unknown
         01:09:28.866 EVENT  Started ServletHttpContext[/]
     49: 06-06-2008 FRI 01:09:28 ConnectionManager
         Memory Available = 25445040 <158888>
     50: 06-06-2008 FRI 01:09:27 ConnectionManager
         Memory Available = 25603928 <79424>
     51: 06-06-2008 FRI 01:09:26 ConnectionManager
         Memory Available = 25683352 <111472>
     52: 06-06-2008 FRI 01:09:26 Unknown
         DynamicDeviceDetector 0.0.1 has been started
     53: 06-06-2008 FRI 01:09:25 ConnectionManager
         Memory Available = 25794824 <65016>
     54: 06-06-2008 FRI 01:09:25 ConnectionManager
         Memory Available = 25859840 <14080>
     55: 06-06-2008 FRI 01:09:25 ConnectionManager
         Memory Available = 25873920 <79096>
     56: 06-06-2008 FRI 01:09:25 ConnectionManager
         Memory Available = 25953016 <98640>
     57: 06-06-2008 FRI 01:09:24 ConnectionManager
         Memory Available = 26051656 <130456>
     58: 06-06-2008 FRI 01:09:24 Unknown
         DeviceAccess 0.0.1 has been started
     59: 06-06-2008 FRI 01:09:23 ConnectionManager
         Memory Available = 26182112 <54680>
     60: 06-06-2008 FRI 01:09:22 Unknown
         DeviceManager 0.0.1 has been started
     61: 06-06-2008 FRI 01:09:22 ConnectionManager
         Memory Available = 26236792 <238392>
     62: 06-06-2008 FRI 01:09:21 ConnectionManager
         Memory Available = 26475184 <93328>
     63: 06-06-2008 FRI 01:09:20 ConnectionManager
         Memory Available = 26568512 <190536>
     64: 06-06-2008 FRI 01:09:19 ConnectionManager
         Memory Available = 26759048 <27464>
     65: 06-06-2008 FRI 01:09:18 ConnectionManager
         Memory Available = 26786512 <138680>
     66: 06-06-2008 FRI 01:09:17 Unknown
         Create Jetty Web Server
     67: 06-06-2008 FRI 01:09:17 ConnectionManager
         Memory Available = 26925192 <85632>
     68: 06-06-2008 FRI 01:09:16 ConnectionManager
         Memory Available = 27010824 <146992>
     69: 06-06-2008 FRI 01:09:16 ConnectionManager
         Memory Available = 27157816 <96688>
     70: 06-06-2008 FRI 01:09:15 ConnectionManager
         Memory Available = 27254504 <138536>
     71: 06-06-2008 FRI 01:09:14 Unknown
     72: 06-06-2008 FRI 01:09:14 Unknown
         Welcome to Duet.
     73: 06-06-2008 FRI 01:09:14 ConnectionManager
         Memory Available = 27393040 <19952>
     74: 06-06-2008 FRI 01:09:14 ConnectionManager
         Memory Available = 27412992 <22348640>
     75: 06-06-2008 FRI 01:09:12 InternalMessageRouter
         Preparing to initialize java.lang.Thread
     76: 06-06-2008 FRI 01:09:12 Unknown
         (0000006275) Preparing to initialize java.lang.Thread
     77: 06-06-2008 FRI 01:09:12 InternalMessageRouter
         Preparing to initialize java.lang.ClassLoader$NativeLibrary
     78: 06-06-2008 FRI 01:09:12 Unknown
         (0000006274) Preparing to initialize java.lang.ClassLoader$NativeLibrary
     79: 06-06-2008 FRI 01:09:12 InternalMessageRouter
     80: 06-06-2008 FRI 01:09:12 Unknown
         (0000006273) Preparing to initialize java.lang.ClassLoader
     81: 06-06-2008 FRI 01:09:12 InternalMessageRouter
         Preparing to initialize java.lang.Shutdown
     82: 06-06-2008 FRI 01:09:12 Unknown
         (0000006273) Preparing to initialize java.lang.Shutdown
     83: 06-06-2008 FRI 01:09:12 InternalMessageRouter
         Preparing to initialize sun.misc.ThreadRegistry
     84: 06-06-2008 FRI 01:09:12 Unknown
         (0000006272) Preparing to initialize sun.misc.ThreadRegistry
     85: 06-06-2008 FRI 01:09:12 InternalMessageRouter
         Preparing to initialize java.lang.String
     86: 06-06-2008 FRI 01:09:12 Unknown
         (0000006272) Preparing to initialize java.lang.String
     87: 06-06-2008 FRI 01:09:12 InternalMessageRouter
         Preparing to initialize java.lang.Float
     88: 06-06-2008 FRI 01:09:12 Unknown
         (0000006271) Preparing to initialize java.lang.Float
     89: 06-06-2008 FRI 01:09:12 InternalMessageRouter
     90: 06-06-2008 FRI 01:09:12 Unknown
         (0000006269) Preparing to initialize java.lang.Class
     91: 06-06-2008 FRI 01:09:12 Unknown
         JVM Logger Thread Started
     92: 06-06-2008 FRI 01:09:12 Interpreter
         CIpPersistent::SaveOldVariable
     93: 06-06-2008 FRI 01:09:12 Interpreter
         CIpListMan::LoadVolatile                       6168    1
     94: 06-06-2008 FRI 01:09:12 Interpreter
         CIpCodeMan::LoadCode                          13178    1
     95: 06-06-2008 FRI 01:09:12 Interpreter
         CIpUffHandler::Module Header
     96: 06-06-2008 FRI 01:09:12 Interpreter
         CIpUffHandler::Project Name=New
     97: 06-06-2008 FRI 01:09:12 Interpreter
         CIpUffHandler::Root
     98: 06-06-2008 FRI 01:09:12 Interpreter
         CIpUffHandler::Load - Begin...doc:PROG.TKN
     99: 06-06-2008 FRI 01:09:12 Interpreter
         CIpNvMemory::NvInitalize NvRam Tested OK  Used=1047536  Available=0
    100: 06-06-2008 FRI 01:09:12 ConnectionManager
         Memory Available = 49761632 <231160>
    101: 06-06-2008 FRI 01:09:12 Interpreter
         CIpInterpreter::Run - Unlocking Interpreter Mutex Early (Device Hold off is off)
    102: 06-06-2008 FRI 01:09:14 ConnectionManager
         Memory Available = 49883768
    103: 06-06-2008 FRI 01:09:09 ConfigurationManager
         JVMStartParam(2): -Djava.security.manager -Doscar.profile.name=Duet org.ungoverned.oscar.Main
    104: 06-06-2008 FRI 01:09:09 ConfigurationManager
         JVMStartParam(1): v1.1 runJava -XsafeExit -Xms20M -Dpath.separator=; -Djava.class.path=doc:/lib;doc:/lib/Oscar.jar
    105: 06-06-2008 FRI 01:09:09 ConfigurationManager
         UDP Blink Message Time = 5 seconds (0=off)
    106: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Log Entry Count        = 1000
    107: 06-06-2008 FRI 01:09:09 ConfigurationManager
         TCP Timeout            = 45000mS
    108: 06-06-2008 FRI 01:09:09 ConfigurationManager
         NetLinx Sockets Message Queue Size               = 50
    109: 06-06-2008 FRI 01:09:09 ConfigurationManager
         PhastLink Receive Message Queue Size             = 500
    110: 06-06-2008 FRI 01:09:09 ConfigurationManager
         ICSNet Receive Message Queue Size                = 200
    111: 06-06-2008 FRI 01:09:09 ConfigurationManager
         LontalkHost Message Queue Size                   = 500
    112: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Lontalk Message Queue Size                       = 500
    113: 06-06-2008 FRI 01:09:09 ConfigurationManager
         UDP Transmit Message Queue Size                  = 500
    114: 06-06-2008 FRI 01:09:09 ConfigurationManager
         ICSP 232 Transmit Message Queue Size             = 500
    115: 06-06-2008 FRI 01:09:09 ConfigurationManager
         ICSNet Transmit Message Queue Size               = 500
    116: 06-06-2008 FRI 01:09:09 ConfigurationManager
         PhastLink Transmit Message Queue Size            = 500
    117: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Axlink Transmit Message Queue Size               = 800
    118: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Message Dispatcher Message Queue Size            = 1000
    119: 06-06-2008 FRI 01:09:09 ConfigurationManager
         IP Connection Manager Message Queue Size         = 800
    120: 06-06-2008 FRI 01:09:09 ConfigurationManager
         TCP Transmit Threads Message Queue Size          = 600
    121: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Diagnostic Manager Message Queue Size            = 500
    122: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Device Manager Message Queue Size                = 1500
    123: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Route Manager Message Queue Size                 = 400
    124: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Connection Manager Message Queue Size            = 2000
    125: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Notification Manager Message Queue Size          = 2000
    126: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Interpreter Message Queue Size                   = 2000
    127: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Routing Flags          = $0
    128: 06-06-2008 FRI 01:09:09 ConfigurationManager
         AMX URL               = www.amx.com
    129: 06-06-2008 FRI 01:09:09 ConfigurationManager
         CRL Check level    = 0
    130: 06-06-2008 FRI 01:09:09 ConfigurationManager
         IPSec Enabled       = 0
    131: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Timeline Loopcnt   = 10
    132: 06-06-2008 FRI 01:09:09 ConfigurationManager
         IP Threshold           = 1500
    133: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Lontalk Threshold      = 50
    134: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Interpreter Threshold  = 1500
    135: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Device Holdoff         = 0
    136: 06-06-2008 FRI 01:09:09 ConfigurationManager
         URL Entry[0] = 192.168.110.81:1319 (TCP)
    137: 06-06-2008 FRI 01:09:09 ConfigurationManager
         URL Entry Count = 1
    138: 06-06-2008 FRI 01:09:09 ConfigurationManager
         DNS Entry[0] = 192.168.110.100
    139: 06-06-2008 FRI 01:09:09 ConfigurationManager
         DNS Entry Count = 1
    140: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Domain Name =
    141: 06-06-2008 FRI 01:09:09 ConfigurationManager
         Serial Number = '210505x4561069'
    142: 06-06-2008 FRI 01:09:09 ConfigurationManager
         System = 3
    143: 06-06-2008 FRI 01:09:09 ConfigurationManager
         LoadConfiguration Complete (26920).
  • AuserAuser Posts: 506
    When I've encountered this behaviour it's always been because I've inadvertently forgotten to declare a large variable as volatile and have run out of non-volatile memory on the controller. I suspect the same may happen if the program has variable declarations which would exceed the amount of available RAM.
    A "show mem" (I think, I can never remember terminal commands unless I'm in front of the box) should indicate if this is the case - check if any of the available memory sizes are negative.
    Even though this doesn't explain why the problem is occurring on a system that's been running for 14 months without any changes to the program...
    Edit: What's up with the event log you posted? I've never seen it garbled like that before.
    I agree that it looks like a non-volatile memory issue. You can have plenty of volatile memory left, but if you run out of non-volatile, the master just stops. No "crash," no run time error, just nothing works.
  • I re-entered the log info up above to get rid of the garbled characters.
    When I do a show mem, it still shows that I have memory available, but I tried commenting out the duet modules just to help reduce the size, and the problem was still there. The weird thing like Auser pointed out, is that the program has been stable and running fine for over a year. The only thing that we can tie to the problem is that we had to remove power at that location for about 10 minutes and the CMOS battery seems to be going bad since the time/date drifts now. I'll load the program onto another master later today, but I'm confident it will work o.k.
    Is there something else I should consider or can check on the software/setup side? I'll have one of our techs change out the CMOS battery too. If I recall correctly, when the CMOS battery is bad, that can cause issues with the BIOS and the memory pointers, etc..
    I can't say it enough, but thanks again for all the help too!
    --John
  • cwpartridgecwpartridge Posts: 120
    There is no non-volatile memory available. Look at variables that are not declared as VOLATILE. See if any can be set as VOLATILE.
    Also, disable any modules that you didn't write.
  • Look at variables that are not declared as VOLATILE.
    Hmmm. This particular program is fairly small. It doesn't have any variables declared as non_volatile or persistent. Just to make sure though (since I didn't see that line you quoted until you posted it!) I declared every variable and constant specifically as volatile.
    ericmedley wrote: »
    I commented those out too. And just for good measure I commented out the ones I wrote :)
    I reloaded the program with the variables declared volatile, all modules commented out and still the same issue. I ran a show log all again and it still says
    99: 07-31-2008 THU 11:47:43 Interpreter
    The time has also slipped over an hour since I reset it this morning (I'm feeling like a dog with a bone regarding the CMOS thing).
    --John
  • I had one like this where the switch 1 somehow got screwed up and always thought it was on.
    After we uninstalled it, replaced it, and took it to the shop to troubleshoot the problem it naturally went away. I'm sure the switch got toggled a few times in the shop and they may have slapped it around a bit, but it did start working again.
  • It doesn't have any variables declared as non_volatile or persistent
    FYI. You have to have at least one variable that is non_volatile or the code wont run.
    Don't know why the system would stop all of a sudden after a reboot though.
    I just sent in an older NI-2000 that came back from repair. The ICSNet card went bad on it. Upon returning I loaded the old program back in and it ran very sluggish or not at all.. After lots of cussing, swearing and a few calls to AMX TS, I found that any variable that was declared 'Persistent' was not working. It wouldn't show up in debug and any line of code that addressed produced a runtime error.
    It's going back for a new motherboard.
    Maybe you have a similar problem.
    I don't believe that's an accurate statement. The code should run fine without declaring any variables as non_volatile.
    As far as I know, the only reason you need to have one non-volatile variable is so that the debugger will function properly. The code will not have any problems other than those that are coded in if everything in volatile, you will just have problems monitoring variables in debug.
    That does appear to be the case!
    I have a test program running on a 2nd master w/o any vars and the code works fine. Doesn't do much but it does what is supposed to. Open debug and I get a warning stating the compiled tkn doesn't match the source code which is BS cuz it's what I just uploaded. If I continue and open debug and drop a defined dev in nothing happens, no D:P:S displayed.
    If I put in a VOLATILE var into the code the same thing happens and the var which was initiated to 1 shows nothing when dropped into the debug window. Now if I then change the VOLATILE var to NON_VOLATILE the warning pop up no longer appears, placing a defined dev into debug reveils its D:P:S and then placing the vars into debug show it has a value of 1.
    So basically you do need at least one NON_VOLATILE var for debug to work but the code appears to function properly regardless.
  • O.K. here's the update. I loaded a known working program into that messed up unit and we still had the same problem. I'm convinced that it's hardware related like Eric is suggesting. I replaced the unit and loaded the code that was functioning for 2 years and it's working flawlessly with the new NI-3100.
    Regarding the CMOS battery that I mentioned in every post, it doesn't seem to make any difference. As a matter of fact the NI-3100 that's been there for 2 years was shipped without the battery!
    At this point the unit is with me and I'll try different things to make it come back to life before I RMA it to AMX. I feel special since I noticed several of the respondents were registered in 2004 and earlier (I still don't know how Dan C. registered more than a year before all of us :)) and those that were registered later are really smart so at least I at least feel like I had a more "advanced" technical problem :).
    Thanks again everyone! I'll keep everyone apprised if I find out anything else new.
    --John
  • Regarding the CMOS battery that I mentioned in every post, it doesn't seem to make any difference. As a matter of fact the NI-3100 that's been there for 2 years was shipped without the battery!
    Oh, there is a battery, just not a CR2032 or similar that your used to seeing. It's the big yellow block below the CF slot. And from what you have described, I'd bet your best bet is to get an RMA.
  • Oh, there is a battery
    No, it really shipped without one. I pulled the yellow snaphat off of a 4100, then went into this 3100 and found that it was never installed. The timekeeper chip had the holes exposed where the snaphat was supposed to go. I know what I was looking for, and really - it wasn't there. Thanks for the RMA advice, I'll try a few more things this weekend before I send it back.
    --John
    Hmmm. This particular program is fairly small. It doesn't have any variables declared as non_volatile or persistent. [...]
    Just for the benefit of any folks out there who aren't aware, global variables in NetLinx code are non-volatile unless declared otherwise.
