Sharp Displays: unexpected string from it
Grinding away at my big project, and ran across something unexpected. When I power up the display (RSPW1 , then POWR1 ), I always get the OK$0D response from the POWR command, but then I usually get another $00 from the display about a second later. When I get that $00 from the display, the next command I send it (doesn't matter what), I always get an ERR$0D response and the command fails. Commands only fail after I've gotten that $00, and I only get that on the POWR1 command.
Has anyone else run into this? Why is it sending a $00? What's the fix? Do I just need to send another command (maybe POWR?) after I get that goofy $00 response?
Then I disconnected the AC power from the display for a few seconds. FIXED! Now, I'm not getting the ERR response from the RSPW1 command, and not the $00 after the POWR1 command, either. So there's my answer: Cut power. Not impressed. I hope they aren't all this unreliable - I've got 25 of these things I'm controlling, and this one started going goofy after just a few days of testing.
Possibly compounding the issue is the fact that other people have been using a remote to control this display. I wonder if that has anything to do with it.
NOTE: on this particular model (LC52D64U), the RSPW1 command actually powers up the display. Wasn't expecting that, either.
If energy saving mode was on, the RS232 port isn't going to be listening for anything - even an RSPW1 command. Energy saving on equals RS232 being turned off, plain & simple.
The one I've been testing so far does, I'm not having any problem with that. But I will be changing the power-up sequence to try just the POWR1 first, then the RSPW1 if I don't get a positive response from the POWR1.
I think an earlier poster was right - it's all a matter of which firmware is on them, and no two sets appear to have the same firmware. I'm sure to run into problems with some of the others; it sounds like Sharp changes firmware and thus functionality as often as most people change underwear. I've got almost 30 of them to control. Who bets I'll be talking to at least 2 different versions of firmware? 3? Should we set up a techie pool and bet on it? :-)
