Keeping my module clean
I made a module for a sensor that tells how far away something is. When something gets too close, I want to trigger something; I don't know what yet, but it will be in a different module.
What are some nice ways to trigger something in another module? Right now thinking about using a virtual device.
You can pass it a virtual device and use SEND_STRINGs/COMMANDs to pass info back and forth.
You can pass it a virtual device and track channels or levels.
You can use unused channels and levels on the real device.
Something where the value changes quickly and you want constant real time updates I'd just pass it a variable or a variable array and be done with it.
what kind of SEND_COMMANDS do you send? Smoething easy to parse...
Like POWER=1, and that way if you have to add some RMS code into the mix, your virtual device will work seamlessly with their compiled modules.
//in module DEFINE_CALL 'SEND_STRING_FEEDBACK'(DEV vDev, CHAR cCommand[], CHAR cParameter[]) { SEND_STRING vDev,"cCommand,'=',cParameter"; } CALL 'SEND_STRING_FEEDBACK'(vdvPLASMA,'POWER',ITOA(iPlasmaPower));Whatever you like; like David T does, I mimic the format AMX uses in many of their modules, something on the order of COMMAND=ZONE:PARAMETER .
One approach you could consider is using channel events on the virtual device for the module (or level events). This means that when you want to sound the alarm, you could either Pulse channel 1 (as an example) or simply turn it on. Then in your main code, you create a channel_event[dvVirtual,1] and in the ON: handler, you sound the alarm (This could mean either a send_command to another module, or simply turning on a channel on the virtual device associated with the alarm sounder)
Given that you are tracking distance, you could also use a level event on the virtual device and then in the level handler use a switch..case or a select..active routine to play different audio files depending on the distance.
That's how I would start to approach it. As of late, I've been moving away from sending commands and parsing them and transitioning to channel and level events when possible. Not only is it faster to execute for the processor, it's easier to code (if you have a standard you use for channels).
My 5 cents (the value of the dollar is down, so I didn't want my opinion returned due to insufficient payment
How do I go about triggering Level Events?
To trigger a channel event I'm using:
PULSE [virtualDevice, channelNumber]
whoops, edit: i'm guessing it has something to do with SEND_LEVEL.
Pass arrays of button channel numbers to the module, or just define them in the module?
It's kind of annoying that you can't pass a constant, so you need to make the array a variable. Going into the module and changing things per project is also annoying.
Any other clever ways for the module to know what to do with a button press?
I personally pass button arrays. For me it's nicer to have the stuff that changes in the main code so I can just do all my editing in one spot. I like to change the modules as little as possible once they're written. Just define and go. I like JJames' way of using DEFINE_VARIABLE multiple times so you can open and close them in the NS2 -- I never used to do that before but I find it very convenient now and it keeps things nicely organized (thanks Jeremiah).
--John
Or if I need to reference the button channel array outside of the module I'll declare it outside and pass it in.
It comes, I suppose, of having started my programming career with having to jam every last bit of resource into a 64K memory footprint. I still find myself using bit fields (sometimes
