DEV Array of Multiple Ports of Same Device??
Greetings,
I am having trouble with a button event from a DEV array containing devices of the same number with different ports.
dvDevice1=[33001:1:0]
dvDevice2=[33001:2:0]
dvDevice3=[33001:3:0]
DEV dDevices[]={dvDevice1,dvDevice2,dvDevice3}
BUTTON_EVENT [dDevices,0]
  nDevice=BUTTON.INPUT.DEVICE.PORT
In the above example, a button event on occurs on the first device of the array, making nDevice=1. Am I doing something wrong in trying to return a value based on device port numbers?
Thanks!
  • mpullinmpullin Posts: 949
    You probably want BUTTON.INPUT.DEVICE.PORT
    mpullin wrote: »
    That is what is in my code. I wrote it wrong in the forum post. Thus I corrected the original forum post.
    It still doesn't work though. I only get a button event from the first device of the array.
    When something like this produces altogether unexpected results, I find if often helps to rethink the way I am doing it altogether.
    How about this on your PUSH:
    nDevice = dDevices[GET_LAST(dDevices)].PORT
    Thanks for the suggestion. However, my problem is that the button event is only triggering on the first device of the array.
    I failed to mention that the devices and array of devices are defined in a main program. The events are in a module that has the device array passed in.
  • HedbergHedberg Posts: 671
    I just tried this and it seems to work fine. Have you "set_virtual_port_count"?
    Well, I did it in a simple Netlinx program -- not in a module. Do you need "set_virtual_port_count" in both the module and in the main program? I'm guessing just the module.
    Hedberg wrote: »
    I did only in the module. I've since scrapped the idea of what I was doing and went to SEND_COMMANDS.
    Thanks for your suggestion! It may just have worked.
