Multiple TP's and one master
tom.lammi
Hello all!
I dig this forum a lot and now I have a tricky project coming up so I thought I'd give it a shot here:
I'm looking at programming a game taking place in one large room. There are four wall-fixed TP's runnning a one-minute countdown with different questions to answer. There will be one multiple choice question at each of the panels - 4 correct out of 10 for example. The idea is that there is a group of kids at each panel, trying to answer as many times as they can to find the correct ones.
At this stage the plan is to have one NI4100 receiving input from all the panels, running the program and controlling lighting, music and so forth.
My question is: what happens when I get input from many panels at the same time or close to that? Will some of the button presses get ignored or do they get in a some kind of waiting line? Is it even possible to achieve a stable, reliable program to do this all? Or is it imperative to have multiple masters to reduce pressure?
Any thoughts - bearing in mind that I'm fairly new to programming
Thanks for your time!
Sounds like a fun project! Though I'd be scared they break the touch panels . . . hitting the buttons so hard just to get the next question - haha!
I do remember doing some testing on this. Buttons being pressed & released at the "same" time. I'm not sure how you're handling it in code, but this *might* be worth looking at. http://amxforums.com/showthread.php?t=1473
This is an older thread . . . I'm a little embarrassed to read it now but . . . I think the overall gist and point is still applicable. (BTW - I'm a big GET_LAST fan today . . . boy how we change.)
I'd suggest putting in hard buttons (plus a start button / Presence start) plus a small LCD screen driven from an MPEG player - there are several that will play seamlessly from clip to clip / loop until command etc and can be triggered from Serial IP or Contacts.
You could use a Netlinx backend - but again there are other options out there designed purely for the task, have a look at Gilderfluke and Alcorn McBride, on many recent jobs I've used a combination of both with AMX!
Enjoy
From experience it isn't just Kids that bang!!!
'tis true. I found one MVP-8400 obviously hurled across a floor. This by a 72 year old man who still thinks it's the height of stupidity that a touch panel should need to have it's batteries recharged on occasion.
This theory still needs a little work, and it may only apply to a certain subset of the population, but I think it's close
Sound's like a good working theory. You may have to add a 'sense of entitlment' constant as well as a 'new money vs. old money' metric to get the equation to work.
I'm not too concerned about the panels getting beat to death, though, for the game room is going to be under strict supervision and the atmosphere of the situation is going to be more mysterious than any disco-frenzy-type that would get them that hyped up.
The thing i'm a bit nervous about is wheter i can manage to make the code with the panels run smoothly and reliably with this setup or not.
I'm glad to hear about the event queue and the fact fact that even if two button events were to occur at the exact same one thousandths of seconds time, the netlinx will still process them both, one at a time.
Most of the programming techniques discussed in the threads linked are new to me at this point of my career, but i'll definately look into those, hopefully with the aid of a massive boost of information from the PII course next month
