how do you use IP_CLIENT_OPEN to get info from a website?
24
    a_riot42 wrote: »
    I don't follow what the problem with data.text is. It's a buffer like any other and its up to the programmer to manipulate it to function correctly isn't it? If it overflows and data is lost then that is the programmers fault.
    Someone said that create_buffer is a FIFO buffer. But data.text is as well if you read it as it comes in. The docs say use either data.text or create_buffer so I wonder if they are implemented exactly the same and create_buffer is just there for legacy reasons.
    It is not totally accurate to say CREATE_BUFFER is there for legacy. It does work and act differently and was left on purpose.
    And it is possible (and in the case of a web page, probable) to get a hunk of larger than 16K in DATA.TEXT before the event technically fires. In otherwords, DATA.TEXT could already have overrun by the time you get 'round to parsing the data. So, the hunk of data you're trying to retrieve from the website might already be lost before you have time to go sifting through it.
    I'd ran into this myself many times. I just did my own testing to determine that CREATE_BUFFER seems to work better for Web Page scraping. It was confirmed in our Prog II class a couple weeks back. I didn't know the size limit to DATA.TEXT nor the way it acted when full and that explained the problem.
    You are correct in saying that it's up to the programmer and situation. If the web page you're scraping is less than 16K you have no problems.
    To me CREATE_BUFFER has alway been kind of a creepy command. You have to put it in the START section and somehow that's never made much sense to me. :D
    ericmedley wrote: »
    I think the reason for this is that the START section isn't processed until all the memory allocations are made, but also is guaranteed to happen before mainline starts running. Anything else would leave you in a position of not being certain everything is in place that needs to be in place when stuff starts happening.
    a_riot42a_riot42 Posts: 1,624
    ericmedley wrote: »
    I don't see how this can happen if you are emptying the buffer at appropriate times. Of course if your code in the string event is while (find_string(data.text, '</html>', 1)) then yes you can overrun the buffer but that is true under any circumstances with any size buffer. If you don't read any buffer before new writes you will lose data.
    ericmedley wrote: »
    How did you determine this?
    ericmedley wrote: »
    How big is the buffer that create_buffer creates? Unless its infinite there will always be a webpage out there that is bigger and will cause problems if you try and slurp entire webpages at a time. I have written FTP programs that can transmit huge files, and done it all with a 256kb buffer so I don't see how a 16kb buffer limits you in any way.
    a_riot42 wrote: »
    I wrote a quick webpage on my server that was of known length and hit it using both methods.
    The buffer is created by you when you declare the buffer in DEFINE_VAR
    So, you can make it 100K if you want to or whatever.
    DATA.TEXT is not created by you. As I typed this I looked in the Netlinx.axi file and saw that in my case it was actually set to 2K, not even 16K. I suppose one could go in and modify the file and make it bigger. I don't know how this would effect operation at run time, but you could try it and see. If it didn't break it, you could set DATA.TEXT to be whatever you needed it to be as well. I'm not one of those who goes in and does a lot of mods on the Netlinx.axi file. I have my own .axi file for such things.
    I also seem to remember that since DATA.TEXT is in the Netlinx.axi it can be a little more 'processor spendy' than CREATE_BUFFER which happens outside the main runtime thread.
    I sound like I'm arguing. I'm not intending to. Both methods are just fine as far as I'm concerned. I guess I was just defending CREATE_BUFFER from the accusation that it is archaic and not to be used.
    One of the things I've seen over the years that NetLinx has been around is that when it started there seemed to be a general disdain for more Axcess type programming methods when migrating to NetLinx. You'd hear things like, "don't do that in NetLinx. The new method is way better." Well, over time we've seen that some of those legacy keywords were not as bad as we were told they were and are even a benefit over the more modern NetLinx counter parts. The difference in how the processor handles them was in many cases better overall than the newer method for certain applications.
    I just like to use them as they benefit performance. They each have their benefits and downsides. I like having both (or more in some cases) ways of getting from A to B. It offeres a lot more flexibility in programming, IMHO...
    viningvining Posts: 4,368
    It's not like a buffer, doesn't behave like a buffer and doesn't have the same capacity of a buffer. I was merely trying to state that since the max string size that DATA.TEXT can handle is only 2048 there's a chance that scapping a web page may return a single string in one or more string_events longer than DATA.TEXT can handle and the incoming data would be truncated.
    Well duh! That was the point and if you rely solely on DATA.TEXT w/o appending it to a large VAR or buffer that's one potential problem but even if you do there is the potential of loosing data if incoming string is longer than 2048 because of this DATA.TEXT limitation.
    This all may be moot since I ran tests on several different websites as follows:
    DEFINE_VARIABLE //
    VOLATILE CHAR cGoogleBuffer[40000] ;
    VOLATILE INTEGER nStrEvtCnt = 1 ;
    CREATE_BUFFER dvGoogle,cGoogleBuffer ;
    DATA_EVENT [dvGoogle]
         ONLINE:
    	  fnGetWeather() ;
    	  nGoogle_Online = 1 ;
         STRING:
    	  SEND_STRING 0,"'STRING_EVENT DATA.TEXT-',ITOA(nStrEvtCnt),', STRING LENGTH = ',ITOA(LENGTH_STRING(DATA.TEXT))" ;
    	  SEND_STRING 0,"'STRING_EVENT BUFFER-',ITOA(nStrEvtCnt),', STRING LENGTH = ',ITOA(LENGTH_STRING(cGoogleBuffer))" ;
    	  cGoogleBuffer = '' ;
    	  nStrEvtCnt ++ ;
         OFFLINE:
    	  nGoogle_Online = 0 ;
    I started off with Google weather, then RSSweather, then NOAA Weather, MSN.com Homepage and a few others.
    Line      4 (20:41:53):: STRING_EVENT DATA.TEXT-1, STRING LENGTH = 1418
    Line      5 (20:41:53):: STRING_EVENT BUFFER-1, STRING LENGTH = 1418
    Line      6 (20:41:53):: STRING_EVENT DATA.TEXT-2, STRING LENGTH = 1418
    Line      7 (20:41:53):: STRING_EVENT BUFFER-2, STRING LENGTH = 1418
    Line      8 (20:41:53):: STRING_EVENT DATA.TEXT-3, STRING LENGTH = 1418
    Line      9 (20:41:53):: STRING_EVENT BUFFER-3, STRING LENGTH = 1418
    Line     10 (20:41:53):: STRING_EVENT DATA.TEXT-4, STRING LENGTH = 1418
    Line     11 (20:41:53):: STRING_EVENT BUFFER-4, STRING LENGTH = 1418
    Line     12 (20:41:53):: STRING_EVENT DATA.TEXT-5, STRING LENGTH = 1418
    Line     13 (20:41:53):: STRING_EVENT BUFFER-5, STRING LENGTH = 1418
    Line     14 (20:41:53):: STRING_EVENT DATA.TEXT-6, STRING LENGTH = 1418
    Line     15 (20:41:53):: STRING_EVENT BUFFER-6, STRING LENGTH = 1418
    Line     16 (20:41:53):: STRING_EVENT DATA.TEXT-7, STRING LENGTH = 1418
    Line     17 (20:41:53):: STRING_EVENT BUFFER-7, STRING LENGTH = 1418
    Line     18 (20:41:53):: STRING_EVENT DATA.TEXT-8, STRING LENGTH = 1418
    Line     19 (20:41:53):: STRING_EVENT BUFFER-8, STRING LENGTH = 1418
    Line     20 (20:41:53):: STRING_EVENT DATA.TEXT-9, STRING LENGTH = 1418
    Line     21 (20:41:53):: STRING_EVENT BUFFER-9, STRING LENGTH = 1418
    Line     22 (20:41:53):: STRING_EVENT DATA.TEXT-10, STRING LENGTH = 1418
    Line     23 (20:41:53):: STRING_EVENT BUFFER-10, STRING LENGTH = 1418
    Line     24 (20:41:53):: STRING_EVENT DATA.TEXT-11, STRING LENGTH = 1418
    Line     25 (20:41:53):: STRING_EVENT BUFFER-11, STRING LENGTH = 1418
    Line     26 (20:41:53):: STRING_EVENT DATA.TEXT-12, STRING LENGTH = 1418
    Line     27 (20:41:53):: STRING_EVENT BUFFER-12, STRING LENGTH = 1418
    Line     28 (20:41:53):: STRING_EVENT DATA.TEXT-13, STRING LENGTH = 1418
    Line     29 (20:41:53):: STRING_EVENT BUFFER-13, STRING LENGTH = 1418
    Line     30 (20:41:53):: STRING_EVENT DATA.TEXT-14, STRING LENGTH = 1418
    Line     31 (20:41:53):: STRING_EVENT BUFFER-14, STRING LENGTH = 1418
    Line     32 (20:41:53):: STRING_EVENT DATA.TEXT-15, STRING LENGTH = 1418
    Line     33 (20:41:53):: STRING_EVENT BUFFER-15, STRING LENGTH = 1418
    Line     34 (20:41:53):: STRING_EVENT DATA.TEXT-16, STRING LENGTH = 1418
    Line     35 (20:41:53):: STRING_EVENT BUFFER-16, STRING LENGTH = 1418
    Line     36 (20:41:53):: STRING_EVENT DATA.TEXT-17, STRING LENGTH = 1418
    Line     37 (20:41:53):: STRING_EVENT BUFFER-17, STRING LENGTH = 1418
    Line     38 (20:41:53):: STRING_EVENT DATA.TEXT-18, STRING LENGTH = 1418
    Line     39 (20:41:53):: STRING_EVENT BUFFER-18, STRING LENGTH = 1418
    Line     40 (20:41:53):: STRING_EVENT DATA.TEXT-19, STRING LENGTH = 1418
    Line     41 (20:41:53):: STRING_EVENT BUFFER-19, STRING LENGTH = 1418
    Line     42 (20:41:53):: STRING_EVENT DATA.TEXT-20, STRING LENGTH = 1418
    Line     43 (20:41:53):: STRING_EVENT BUFFER-20, STRING LENGTH = 1418
    Line     44 (20:41:53):: STRING_EVENT DATA.TEXT-21, STRING LENGTH = 1418
    Line     45 (20:41:53):: STRING_EVENT BUFFER-21, STRING LENGTH = 1418
    Line     46 (20:41:53):: STRING_EVENT DATA.TEXT-22, STRING LENGTH = 1418
    Line     47 (20:41:53):: STRING_EVENT BUFFER-22, STRING LENGTH = 1418
    Line     48 (20:41:53):: STRING_EVENT DATA.TEXT-23, STRING LENGTH = 1418
    Line     49 (20:41:53):: STRING_EVENT BUFFER-23, STRING LENGTH = 1418
    Line     50 (20:41:53):: STRING_EVENT DATA.TEXT-24, STRING LENGTH = 1418
    Line     51 (20:41:53):: STRING_EVENT BUFFER-24, STRING LENGTH = 1418
    Line     52 (20:41:53):: STRING_EVENT DATA.TEXT-25, STRING LENGTH = 1418
    Line     53 (20:41:53):: STRING_EVENT BUFFER-25, STRING LENGTH = 1418
    Line     54 (20:41:53):: STRING_EVENT DATA.TEXT-26, STRING LENGTH = 1418
    Line     55 (20:41:53):: STRING_EVENT BUFFER-26, STRING LENGTH = 1418
    Line     56 (20:41:53):: STRING_EVENT DATA.TEXT-27, STRING LENGTH = 1418
    Line     57 (20:41:53):: STRING_EVENT BUFFER-27, STRING LENGTH = 1418
    Line     58 (20:41:53):: STRING_EVENT DATA.TEXT-28, STRING LENGTH = 1418
    Line     59 (20:41:53):: STRING_EVENT BUFFER-28, STRING LENGTH = 1418
    Line     60 (20:41:53):: STRING_EVENT DATA.TEXT-29, STRING LENGTH = 1418
    Line     61 (20:41:53):: STRING_EVENT BUFFER-29, STRING LENGTH = 1418
    Line     62 (20:41:53):: STRING_EVENT DATA.TEXT-30, STRING LENGTH = 1418
    Line     63 (20:41:53):: STRING_EVENT BUFFER-30, STRING LENGTH = 1418
    Line     64 (20:41:53):: STRING_EVENT DATA.TEXT-31, STRING LENGTH = 1418
    Line     65 (20:41:53):: STRING_EVENT BUFFER-31, STRING LENGTH = 1418
    Line     66 (20:41:53):: STRING_EVENT DATA.TEXT-32, STRING LENGTH = 1418
    Line     67 (20:41:53):: STRING_EVENT BUFFER-32, STRING LENGTH = 1418
    Line     68 (20:41:53):: STRING_EVENT DATA.TEXT-33, STRING LENGTH = 1418
    Line     69 (20:41:53):: STRING_EVENT BUFFER-33, STRING LENGTH = 1418
    Line     70 (20:41:53):: STRING_EVENT DATA.TEXT-34, STRING LENGTH = 1418
    Line     71 (20:41:53):: STRING_EVENT BUFFER-34, STRING LENGTH = 1418
    Line     72 (20:41:53):: STRING_EVENT DATA.TEXT-35, STRING LENGTH = 1418
    Line     73 (20:41:53):: STRING_EVENT BUFFER-35, STRING LENGTH = 1418
    Line     74 (20:41:53):: STRING_EVENT DATA.TEXT-36, STRING LENGTH = 1418
    Line     75 (20:41:53):: STRING_EVENT BUFFER-36, STRING LENGTH = 1418
    Line     76 (20:41:53):: STRING_EVENT DATA.TEXT-37, STRING LENGTH = 1045
    Line     77 (20:41:53):: STRING_EVENT BUFFER-37, STRING LENGTH = 1045
    Line      4 (20:23:13):: STRING_EVENT DATA.TEXT-1, STRING LENGTH = 1440
    Line      5 (20:23:13):: STRING_EVENT BUFFER-1, STRING LENGTH = 1440
    Line      6 (20:23:13):: STRING_EVENT DATA.TEXT-2, STRING LENGTH = 1440
    Line      7 (20:23:13):: STRING_EVENT BUFFER-2, STRING LENGTH = 1440
    Line      8 (20:23:13):: STRING_EVENT DATA.TEXT-3, STRING LENGTH = 1440
    Line      9 (20:23:13):: STRING_EVENT BUFFER-3, STRING LENGTH = 1440
    Line     10 (20:23:13):: STRING_EVENT DATA.TEXT-4, STRING LENGTH = 1440
    Line     11 (20:23:13):: STRING_EVENT BUFFER-4, STRING LENGTH = 1440
    Line     12 (20:23:13):: STRING_EVENT DATA.TEXT-5, STRING LENGTH = 1440
    Line     13 (20:23:13):: STRING_EVENT BUFFER-5, STRING LENGTH = 1440
    Line     14 (20:23:13):: STRING_EVENT DATA.TEXT-6, STRING LENGTH = 1440
    Line     15 (20:23:13):: STRING_EVENT BUFFER-6, STRING LENGTH = 1440
    Line     16 (20:23:13):: STRING_EVENT DATA.TEXT-7, STRING LENGTH = 1440
    Line     17 (20:23:13):: STRING_EVENT BUFFER-7, STRING LENGTH = 1440
    Line     18 (20:23:13):: STRING_EVENT DATA.TEXT-8, STRING LENGTH = 1440
    Line     19 (20:23:13):: STRING_EVENT BUFFER-8, STRING LENGTH = 1440
    Line     20 (20:23:13):: STRING_EVENT DATA.TEXT-9, STRING LENGTH = 1395
    Line     21 (20:23:13):: STRING_EVENT BUFFER-9, STRING LENGTH = 1395
    Line     22 (20:23:20):: Exiting TCP Read thread - closing this socket for local port 4
    Line      4 (20:19:25):: STRING_EVENT DATA.TEXT-1, STRING LENGTH = 1368
    Line      5 (20:19:25):: STRING_EVENT BUFFER-1, STRING LENGTH = 1368
    Line      6 (20:19:25):: STRING_EVENT DATA.TEXT-2, STRING LENGTH = 1368
    Line      7 (20:19:25):: STRING_EVENT BUFFER-2, STRING LENGTH = 1368
    Line      8 (20:19:25):: STRING_EVENT DATA.TEXT-3, STRING LENGTH = 1368
    Line      9 (20:19:25):: STRING_EVENT BUFFER-3, STRING LENGTH = 1368
    Line     10 (20:19:25):: STRING_EVENT DATA.TEXT-4, STRING LENGTH = 1368
    Line     11 (20:19:25):: STRING_EVENT BUFFER-4, STRING LENGTH = 1368
    Line     12 (20:19:25):: STRING_EVENT DATA.TEXT-5, STRING LENGTH = 1368
    Line     13 (20:19:25):: STRING_EVENT BUFFER-5, STRING LENGTH = 1368
    Line     14 (20:19:25):: STRING_EVENT DATA.TEXT-6, STRING LENGTH = 1368
    Line     15 (20:19:25):: STRING_EVENT BUFFER-6, STRING LENGTH = 1368
    Line     16 (20:19:25):: STRING_EVENT DATA.TEXT-7, STRING LENGTH = 1368
    Line     17 (20:19:25):: STRING_EVENT BUFFER-7, STRING LENGTH = 1368
    Line     18 (20:19:25):: STRING_EVENT DATA.TEXT-8, STRING LENGTH = 1368
    Line     19 (20:19:25):: STRING_EVENT BUFFER-8, STRING LENGTH = 1368
    Line     20 (20:19:26):: STRING_EVENT DATA.TEXT-9, STRING LENGTH = 1368
    Line     21 (20:19:26):: STRING_EVENT BUFFER-9, STRING LENGTH = 1368
    Line     22 (20:19:26):: STRING_EVENT DATA.TEXT-10, STRING LENGTH = 788
    Line     23 (20:19:26):: STRING_EVENT BUFFER-10, STRING LENGTH = 788
    Line     30 (20:11:32):: STRING_EVENT DATA.TEXT-1, STRING LENGTH = 1418
    Line     31 (20:11:32):: STRING_EVENT BUFFER-1, STRING LENGTH = 1418
    Line     32 (20:11:32):: STRING_EVENT DATA.TEXT-2, STRING LENGTH = 1418
    Line     33 (20:11:32):: STRING_EVENT BUFFER-2, STRING LENGTH = 1418
    Line     34 (20:11:32):: STRING_EVENT DATA.TEXT-3, STRING LENGTH = 1994
    Line     35 (20:11:32):: STRING_EVENT BUFFER-3, STRING LENGTH = 1994
    Line     36 (20:11:32):: STRING_EVENT DATA.TEXT-4, STRING LENGTH = 54
    Line     37 (20:11:32):: STRING_EVENT BUFFER-4, STRING LENGTH = 54
    Line     38 (20:11:32):: STRING_EVENT DATA.TEXT-5, STRING LENGTH = 1994
    Line     39 (20:11:32):: STRING_EVENT BUFFER-5, STRING LENGTH = 1994
    Line     40 (20:11:32):: STRING_EVENT DATA.TEXT-6, STRING LENGTH = 54
    Line     41 (20:11:32):: STRING_EVENT BUFFER-6, STRING LENGTH = 54
    Line     42 (20:11:32):: STRING_EVENT DATA.TEXT-7, STRING LENGTH = 1994
    Line     43 (20:11:32):: STRING_EVENT BUFFER-7, STRING LENGTH = 1994
    Line     44 (20:11:32):: STRING_EVENT DATA.TEXT-8, STRING LENGTH = 54
    Line     45 (20:11:32):: STRING_EVENT BUFFER-8, STRING LENGTH = 54
    Line     46 (20:11:32):: STRING_EVENT DATA.TEXT-9, STRING LENGTH = 339
    Line     47 (20:11:32):: STRING_EVENT BUFFER-9, STRING LENGTH = 339
    Line     48 (20:11:32):: STRING_EVENT DATA.TEXT-10, STRING LENGTH = 1418
    Line     49 (20:11:32):: STRING_EVENT BUFFER-10, STRING LENGTH = 1418
    Line     50 (20:11:32):: STRING_EVENT DATA.TEXT-11, STRING LENGTH = 1418
    Line     51 (20:11:32):: STRING_EVENT BUFFER-11, STRING LENGTH = 1418
    Line     52 (20:11:32):: STRING_EVENT DATA.TEXT-12, STRING LENGTH = 1418
    Line     53 (20:11:32):: STRING_EVENT BUFFER-12, STRING LENGTH = 1418
    Line     54 (20:11:32):: STRING_EVENT DATA.TEXT-13, STRING LENGTH = 1418
    Line     55 (20:11:32):: STRING_EVENT BUFFER-13, STRING LENGTH = 1418
    Line     56 (20:11:32):: STRING_EVENT DATA.TEXT-14, STRING LENGTH = 1418
    Line     57 (20:11:32):: STRING_EVENT BUFFER-14, STRING LENGTH = 1418
    Line     58 (20:11:32):: STRING_EVENT DATA.TEXT-15, STRING LENGTH = 1418
    Line     59 (20:11:32):: STRING_EVENT BUFFER-15, STRING LENGTH = 1418
    Line     60 (20:11:32):: STRING_EVENT DATA.TEXT-16, STRING LENGTH = 1418
    Line     61 (20:11:32):: STRING_EVENT BUFFER-16, STRING LENGTH = 1418
    Line     62 (20:11:32):: STRING_EVENT DATA.TEXT-17, STRING LENGTH = 1418
    Line     63 (20:11:32):: STRING_EVENT BUFFER-17, STRING LENGTH = 1418
    Line     64 (20:11:32):: STRING_EVENT DATA.TEXT-18, STRING LENGTH = 1418
    Line     65 (20:11:32):: STRING_EVENT BUFFER-18, STRING LENGTH = 1418
    Line     66 (20:11:32):: STRING_EVENT DATA.TEXT-19, STRING LENGTH = 1418
    Line     67 (20:11:32):: STRING_EVENT BUFFER-19, STRING LENGTH = 1418
    Line     68 (20:11:32):: STRING_EVENT DATA.TEXT-20, STRING LENGTH = 961
    Line     69 (20:11:32):: STRING_EVENT BUFFER-20, STRING LENGTH = 961
    As you can see at no time did an incoming string go over the length that DATA.TEXT can handle. So maybe as long as you append it to a large buffer or VAR you will never have any issues. Is it possible for something to return a single chunk of data bigger than 2048 in one triggered event, I don't know and the point was to try and find out.
    From Netlinx.axi
    STRUCTURE TDATA
      DEV      DEVICE;
      LONG     NUMBER;
      CHAR     TEXT[2048];
      CHAR     SOURCEIP[32];
      INTEGER  SOURCEPORT;
      DEV      SOURCEDEV;
    I didn't think about the possibility of tweaking the size if need be. Maybe they decided this was as big as it would ever need to be.
    Which brings up the question, has anyone ever been screwed by incoming data being truncated because of the DATA.TEXT initialized size?
    vining wrote: »
    Mysterious. It seemed like a buffer to me considering its declared like this CHAR TEXT[2048].
    vining wrote: »
    Sorry for being obvious. When I use data.text, it is only used as a buffer to transfer data from it to another device, another array, or some other data consumer. Since internet packets will be smaller than 2048 bytes, and the firmware likely doesn't send an ACK until the buffer is empty, and that over IP dropped packets are resent, I really can't see how you could lose data using data.text with all the flow control. If you can rig up an example I would love to see it.
    Chip MoodyChip Moody Posts: 727
    Based on VAV's testing - and knowing that a TCP/IP packet can't be larger than 1500 bytes - I'm guessing that the OS is doing a good amount of work for us - making sure that each TCP/IP packet that comes in generates an event. Since a packet will never be larger than 1500 byes, a 2k size for DATA.TEXT is fine. DATA.TEXT will never overflow - if it did it would mean that AMX screwed up some part of their OS. :)
    As far as buffers of any kind in Netlinx - while they are FIFO when you do things like REMOVE_STRING to them, if they fill with data and aren't cleared out, I've been told the same thing - new data coming in destined for a buffer that is already full gets chucked, unlike how it worked in Axcess.
    Since I wasn't sure if Chip's statement above was just an observation of the previous test or an actual fact so I googled "max TCP packet lenght".
    Result:
    Definition: The MTU is the maximum size of a single data unit (e.g., a frame) of digital communications. MTU sizes are inherent properties of physical network interfaces, normally measured in bytes. The MTU for Ethernet, for instance, is 1500 bytes. Some types of networks (like Token Ring) have larger MTUs, and some types have smaller MTUs, but the values are fixed for each physical technology.
    I also found this reference for TCP and other media MTU's.
    Below is a list of Default MTU size for different media.
       Network                  MTU(Bytes)
       16 Mbit/Sec Token Ring    17914
       4 Mbits/Sec Token Ring     4464
       FDDI                       4352
       Ethernet                   1500
       IEEE 802.3/802.2           1492
       X.25                        576
    *****Added for future reference (Cisco 2960 series switch):
    Configurable maximum transmission unit (MTU) of up to 9000 bytes, with a maximum Ethernet frame size of 9018 bytes (Jumbo frames)
    for bridging on Gigabit Ethernet ports, and up to 1998 bytes for bridging of Multiprotocol Label Switching (MPLS) tagged frames
    on both 10/100 and 10/100/1000 ports
    Now there were 3 instances in the tests where a string event recieved 1994 chars in the array.
    Actually an array but as an array there are certain limits and requirements to collecting data. First of all as an plain ordanary array you must concatenate data as the data comes in like:
    cArray = "cArray,DATA.TEXT" ;
    this will work fine unless you need to hold more that 15999 bytes of data. There's a work around function and further explanation here:
    http://amxforums.com/showthread.php?t=3410&highlight=15999
    Now if you took that same array and then created a buffer you wouldn't need to concatenate as that is auotmatically done for you and I believe it could then hold up to 65,535 bytes of data.
    So an array isn't a buffer but a buffer is an array with special properties.
    Since I have a new found respect of DATA.TEXT as a result of this thread I wrote some code for the DATA "STRING_EVENT" that I feel maximizes its potential. This code allows you to set a beginning search string and an ending search string and then collect only the data found between and including the two. Before using DATA.TEXT I would always create a buffer big enough to hold the entire return and then parse when the last of the data was received. I also chose to use a local var array to hold the collected data instead of a buffer just to minimize the scope and avoid the need to size the buffer big enough to contain the entire return since I usually only need a small portion of the return to do my parsing. In order to use the local var and still concantenate stings over the 15999 limit if required I modified the functon "ConcatString" posted by AMX_Jeff a while back to work in this code and it will automatically get used when the data in DATA.TEXT and the previous collected data will total more than 15999.
    There's alot of debug functions commented out in the code but when initially setting this up to work on a webpage they should be uncommented and the debug var set for testing.
    This will likely need additional flags depending on the webpage and the number of times identical strings are found.
    This code is complete so even if you haven't played with web scrapping or IP comms before you can have this set up and running on a master in no time at all.
    PROGRAM_NAME='IP_Socket'
    dvMaster		= 0:1:0 ;
    dvIPSocket      	= 0:4:0 ;
    dvTP			= 10001:1:0 ;
    (*               CONSTANT DEFINITIONS GO BELOW             *)
    DEFINE_CONSTANT
    TCP			 = 1 ;
    CRLF[2] 		 = {$0D,$0A} ;
    DEFINE_CONSTANT //SPECIFIC TO THIS SOCKET CONNECTION!!
    MAX_RCV_DATA_LENGTH      = 30000 ; //set to the max amount of data to be collected.
    CHAR SOCKET_IP_ADDRESS[] = 'www.google.com' ;
    CHAR BEGINNING_STRING[]  = '<!doctype html>' ;
    CHAR ENDING_STRING[]     = '>About Google<' ;
    DEFINE_VARIABLE //GENERAL VARS
    VOLATILE INTEGER nIPSocket_Online = 0 ;
    //VOLATILE INTEGER nStrEvtCnt = 1 ;       //required only when running debug send_string 0's .
    NON_VOLATILE INTEGER nIPSocket_DeBug = 0 ;//non volatile to allow debug to work!
    //VOLATILE CHAR cIPSocket_Buff[65535] ;   //use for testing .
    DEFINE_VARIABLE //CH ARRAY
    VOLATILE INTEGER nBtnArry[] =
         1,//open socket
         2,
         3,
         4,
         5
    DEFINE_FUNCTION fnCONNECT_IPSocket()
         if(!nIPSocket_Online)
    	  ip_client_open (dvIPSocket.Port,SOCKET_IP_ADDRESS,80,TCP) ;
    	  fnIPSocket_DeBug("'IP SOCKET "fnCONNECT_IPSocket" - *Opening IP Socket Port* -  line-<',ITOA(__LINE__),'>',crlf") ;
         RETURN ;
    DEFINE_FUNCTION fnCLOSE_IPSocket()
         if(nIPSocket_Online)
    	  ip_client_close (dvIPSocket.Port) ;
    	  fnIPSocket_DeBug("'IP SOCKET "fnCLOSE_IPSocket" - *Closing IP Socket Port* -  line-<',ITOA(__LINE__),'>',crlf") ;
         RETURN ;
    (*MODIFIED*)
    DEFINE_FUNCTION CHAR[MAX_RCV_DATA_LENGTH]fnConcatString(CHAR sConcatFinal[],CHAR sConcatNew[])
         //modified from original
         STACK_VAR CHAR sPieces[3];
         STACK_VAR CHAR sBuffer[MAX_RCV_DATA_LENGTH];
         STACK_VAR LONG lPos, lOldPos;
         lpos = 1;
         VARIABLE_TO_STRING(sConcatFinal,sBuffer,lPos);
         sPieces[1] = sBuffer[lPos-3];
         sPieces[2] = sBuffer[lPos-2];
         sPieces[3] = sBuffer[lPos-1];
         lOldPos = lpos;
         lpos = lpos - 3;
         VARIABLE_TO_STRING(sConcatNew,sBuffer,lPos);
         sBuffer[lOldPos-3] = sPieces[1];
         sBuffer[lOldPos-2] = sPieces[2];
         sBuffer[lOldPos-1] = sPieces[3];
         GET_BUFFER_STRING(sBuffer,3)
         RETURN sBuffer ;
    DEFINE_FUNCTION fnParseRcvdData(CHAR iData[])  //FUNCTION IS EMPTY!!  NEEDS CODE!!
         RETURN ;
    DEFINE_FUNCTION fnIPSocket_DeBug(CHAR iMsg[])
         if(nIPSocket_DeBug)
    	  SEND_STRING dvMaster,iMsg ;
    DEFINE_FUNCTION fnGetWebPage()
         SEND_STRING dvIPSocket,"'GET /search?hl=en&q=new+york%2C+ny+weather HTTP/1.1',CRLF" ;
         SEND_STRING dvIPSocket,"'Host: ',SOCKET_IP_ADDRESS,CRLF" ;
         SEND_STRING dvIPSocket,"CRLF" ;
         RETURN ;
    //CREATE_BUFFER dvIPSocket,cIPSocket_Buff ;
    DATA_EVENT [dvIPSocket]
         ONLINE:
    	  fnGetWebPage() ;
    	  nIPSocket_Online = 1 ;
    	  fnIPSocket_DeBug("'IP SOCKET ONLINE_EVENT - *ONLINE* -  line-<',ITOA(__LINE__),'>',crlf") ;
         STRING:
    	  LOCAL_VAR CHAR cRcvdData[MAX_RCV_DATA_LENGTH] ;
    	  LOCAL_VAR INTEGER nCollectData ;
    	  STACK_VAR INTEGER nCombStrLen ;
    	  //fnIPSocket_DeBug("'STRING_EVENT DATA.TEXT-',ITOA(nStrEvtCnt),', STRING LENGTH = ',ITOA(LENGTH_STRING(DATA.TEXT))") ;
    	  SELECT
    	       {(*may need further flags if multiple beginning strings are in the returned data!!*)
    	       ACTIVE(FIND_STRING(DATA.TEXT,BEGINNING_STRING,1) && !nCollectData)://just in case their are duplicate strings
    		    STACK_VAR INTEGER nFoundEndStr ;
    		    //fnIPSocket_DeBug("'IP SOCKET STRING_EVENT - *BEGINNING STRING FOUND* -  line-<',ITOA(__LINE__),'>',crlf") ;
    		    nCollectData = FIND_STRING(DATA.TEXT,BEGINNING_STRING,1) ;
    		    GET_BUFFER_STRING(DATA.TEXT,nCollectData - 1) ;//remove everything before the beginning string.
    		    cRcvdData = DATA.TEXT ;//add remaining data to array.
    		    (*should not execute unless it's a small section of the HTML being collected*)
    		    if(FIND_STRING(cRcvdData,ENDING_STRING,1)) //make sure you didn't the get the ending string too!
    			 //fnIPSocket_DeBug("'IP SOCKET STRING_EVENT - *ENDING STRING FOUND* -  line-<',ITOA(__LINE__),'>',crlf") ;
    			 cRcvdData = REMOVE_STRING(DATA.TEXT,ENDING_STRING,1) ;//just add up to and including the ending_string.
                     	 fnParseRcvdData(cRcvdData) ;//data collection complete, start parsing!
    			 fnCLOSE_IPSocket() ;//got what we need so close the port! could just wait for server side shutdown!
    			 nCollectData = 0 ; //were done so reset to prevent further collections!
    			 cRcvdData = '' ;//were done so empty and get ready for next time!
    			 nFoundEndStr = 1 ;
    		    if(!nFoundEndStr)(*just in case we already got the ending string, don't run*)
    			 (*just in case we don't find the ending string later*)
    			 WAIT 100 'RCV DATA TIMEOUT' //timeout in case ending string isn't found.
    			      nCollectData = 0 ;//didn't find ENDING_STRING so reset flag!
    			      cRcvdData = '' ;//didn't find last string so dump collected data!
    			      //fnIPSocket_DeBug("'IP SOCKET STRING_EVENT - *ENDING STRING NOT FOUND* -  line-<',ITOA(__LINE__),'>',crlf") ;
    			      //fnIPSocket_DeBug("'IP SOCKET STRING_EVENT - *FLAG RESET & COLLECTED DATA DUMPED* -  line-<',ITOA(__LINE__),'>',crlf") ;
    	       ACTIVE(FIND_STRING(DATA.TEXT,ENDING_STRING,1) && nCollectData):
    		    STACK_VAR CHAR cTmpStr[2048] ;//set above max TCP MTU size (1500). Same max size as DATA.TEXT!
    		    CANCEL_WAIT 'RCV DATA TIMEOUT' ;//ending string found so cancel timeout.
    		    cTmpStr = REMOVE_STRING(DATA.TEXT,ENDING_STRING,1) ;
    		    nCombStrLen = (length_string(cRcvdData) + length_string(cTmpStr)) ;
    		    if(nCombStrLen < 16000)
    			 cRcvdData = "cRcvdData,cTmpStr" ;//add up to and inlude the ending string to array.
    		    else
    			 cRcvdData = fnConcatString(cRcvdData,cTmpStr) ;
    	       ACTIVE(nCollectData)://collect data between beginning and ending found strings.
    		    nCombStrLen = (length_string(cRcvdData) + length_string(DATA.TEXT)) ;
    			 cRcvdData = "cRcvdData,DATA.TEXT" ;//continue adding to array.
    		    else
    			 cRcvdData = fnConcatString(cRcvdData,DATA.TEXT) ;
    	  //fnIPSocket_DeBug("'STRING_EVENT RCV''D DATA-',ITOA(nStrEvtCnt),', STRING LENGTH = ',ITOA(LENGTH_STRING(cRcvdData))") ;
    	  //nStrEvtCnt ++ ; //only required when running fnIPSocket_DeBug() function in this code block. uncomment in define_var also.
         OFFLINE:
    	  fnIPSocket_DeBug("'IP SOCKET OFFLINE_EVENT - *OFFLINE* -  line-<',ITOA(__LINE__),'>',crlf") ;
    BUTTON_EVENT[dvTP,nBtnArry]
    	  STACK_VAR INTEGER nBTN ;
    	  nBTN = GET_LAST(nBtnArry) ;
    	  SWITCH(nBTN)
    	       CASE 1:
    		    fnCONNECT_IPSocket() ;
    	       CASE 2:
    	       CASE 3:
    	       CASE 4:
    	       CASE 5:
    (*            THE ACTUAL PROGRAM GOES BELOW                *)
    DEFINE_PROGRAM
    (*                     END OF PROGRAM                      *)
    (*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
    JOHNBONZJOHNBONZ Posts: 99
    I started this post and I am glad of all the responses.I go after data from a website and the size of that site is 110K. How long do you think it should take to parse out a page of this size, 110K? Lets say I was searching for a string of data "The quick brown fox jumps over the lazy dog", and this string was in the middle of this 110K page. How long should it take to process this page finding this data. I tried many different buffer sizes, from 110K, to 65K, to 2K and the speed difference is negligible. How would you approach this? Here is how I do it:
    volatile char strWeatherBuff[16384]
    IP_CLIENT_OPEN(dvIP_Weather.PORT,'www.weather.com',80,IP_TCP);
    send_string dvIP_Weather,"'GET http://www.weather.com/weather/wxclimatology/monthly/graph/48316?from=36hr_bottomnav_undeclaredHTTP/1.0',13,10,13,10";
    DEFINE_FUNCTION parseWeather()
    nFindLoc = find_string(strTemp,'<title>',1);
    if(nFindLoc > 0)
    ... string found search completed
    STRING:
    if(length_string(strWeatherBuff) > 0)
    parseWeather();
    You created a buffer size of 110k and it compiled? I thought the cutoff was 65k...
    That's what I thought as well. In fact I believe that's what the instructor told be at P3 (NYC) a month or so ago but then I got an email for this tech note a few days ago:
    http://www.amx.com/techsupport/technote.asp?id=886
    which has a line that says:
    As long as you don't put it in double-quotes, a CHAR array is only limited
    by its maximum size and available memory
    So I'm just confused again!
    Create_Buffer vs Data.Text
    In my experience, I only use data.text and append the data to a variable if needed. I haven't used CREATE_BUFFER in years and I've not experienced loosing any data. I guess for some reason I feel better about having control on when to buffer and when to not buffer.
    samossamos Posts: 106
    ok hear is my code for just a connection
    i made it so if the connection fails it will retry. when the system starts up it fails like 15 times and then connects. Does anyone know why this is?
    PROGRAM_NAME='temp'
    (*  FILE_LAST_MODIFIED_ON: 09/08/2009  AT: 13:45:56        *)
    dvTwitter     = 0:3:0
    vdvTwitter    = 0:4:0
    dvTP          = 10001:1:0
    DEFINE_FUNCTION integer fnConnectToTwitter()
        SEND_STRING 0, 'GET TWITTER FEED'
        ip_client_close(dvTwitter.Port)
        wait 20
    	ip_client_open(dvTwitter.Port,'www.twitter.com',80,IP_TCP)
    (*                STARTUP CODE GOES BELOW                  *)
    send_string 0, 'START'
    (*                THE EVENTS GO BELOW                      *)
    BUTTON_EVENT[dvTP,1]
        push:
    DATA_EVENT[dvTwitter]
        onerror:
    	send_string 0,"'error: client=',ITOA(Data.Number)"
        online:
    	send_string 0,"'online: client'"
        offline:
    	send_string 0,"'offline: client'"
        string:
    	send_string 0,"'string: client=',Data.Text"
    DEFINE_PROGRAM
    Hear is my telnet log
    (0000053409) CIpEvent::OnError 0:3:1
    (0000053410) error: client=9
    (0000053410) GET TWITTER FEED
    (0000053411) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053412) CIpEvent::OnError 0:3:1
    (0000053413) error: client=9
    (0000053414) GET TWITTER FEED
    (0000053415) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053416) CIpEvent::OnError 0:3:1
    (0000053417) error: client=9
    (0000053418) GET TWITTER FEED
    (0000053419) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053422) CIpEvent::OnError 0:3:1
    (0000053423) error: client=9
    (0000053424) GET TWITTER FEED
    (0000053425) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053426) CIpEvent::OnError 0:3:1
    (0000053427) error: client=9
    (0000053427) GET TWITTER FEED
    (0000053428) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053429) CIpEvent::OnError 0:3:1
    (0000053430) error: client=9
    (0000053431) GET TWITTER FEED
    (0000053432) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053433) CIpEvent::OnError 0:3:1
    (0000053434) error: client=9
    (0000053435) GET TWITTER FEED
    (0000053436) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053437) CIpEvent::OnError 0:3:1
    (0000053438) error: client=9
    (0000053438) GET TWITTER FEED
    (0000053439) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053440) CIpEvent::OnError 0:3:1
    (0000053441) error: client=9
    (0000053442) GET TWITTER FEED
    (0000053443) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053444) CIpEvent::OnError 0:3:1
    (0000053445) error: client=9
    (0000053446) GET TWITTER FEED
    (0000053446) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053448) CIpEvent::OnError 0:3:1
    (0000053449) error: client=9
    (0000053449) GET TWITTER FEED
    (0000053450) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053451) CIpEvent::OnError 0:3:1
    (0000053452) error: client=9
    (0000053453) GET TWITTER FEED
    (0000053454) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053455) CIpEvent::OnError 0:3:1
    (0000053457) error: client=9
    (0000053458) GET TWITTER FEED
    (0000053459) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053460) CIpEvent::OnError 0:3:1
    (0000053461) error: client=9
    (0000053461) GET TWITTER FEED
    (0000053462) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053464) CIpEvent::OnError 0:3:1
    (0000053465) error: client=9
    (0000053465) GET TWITTER FEED
    (0000053466) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053467) CIpEvent::OnError 0:3:1
    (0000053468) error: client=9
    (0000053469) GET TWITTER FEED
    (0000053470) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053471) CIpEvent::OnError 0:3:1
    (0000053472) error: client=9
    (0000053472) GET TWITTER FEED
    (0000053473) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053474) CIpEvent::OnError 0:3:1
    (0000053475) error: client=9
    (0000053476) GET TWITTER FEED
    (0000053477) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053478) CIpEvent::OnError 0:3:1
    (0000053479) error: client=9
    (0000053480) GET TWITTER FEED
    (0000053481) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053482) CIpEvent::OnError 0:3:1
    (0000053483) error: client=9
    (0000053483) GET TWITTER FEED
    (0000053484) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053486) CIpEvent::OnError 0:3:1
    (0000053487) error: client=9
    (0000053488) GET TWITTER FEED
    (0000053489) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053490) CIpEvent::OnError 0:3:1
    (0000053491) error: client=9
    (0000053492) GET TWITTER FEED
    (0000053492) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053494) CIpEvent::OnError 0:3:1
    (0000053494) error: client=9
    (0000053495) GET TWITTER FEED
    (0000053496) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053497) CIpEvent::OnError 0:3:1
    (0000053498) error: client=9
    (0000053499) GET TWITTER FEED
    (0000053500) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053501) CIpEvent::OnError 0:3:1
    (0000053502) error: client=9
    (0000053503) GET TWITTER FEED
    (0000053503) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053505) CIpEvent::OnError 0:3:1
    (0000053506) error: client=9
    (0000053507) GET TWITTER FEED
    (0000053508) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053509) CIpEvent::OnError 0:3:1
    (0000053510) error: client=9
    (0000053511) GET TWITTER FEED
    (0000053512) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053513) CIpEvent::OnError 0:3:1
    (0000053514) error: client=9
    (0000053514) GET TWITTER FEED
    (0000053515) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053516) CIpEvent::OnError 0:3:1
    (0000053517) error: client=9
    (0000053518) GET TWITTER FEED
    (0000053519) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053520) CIpEvent::OnError 0:3:1
    (0000053521) error: client=9
    (0000053522) GET TWITTER FEED
    (0000053523) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053524) CIpEvent::OnError 0:3:1
    (0000053525) error: client=9
    (0000053525) GET TWITTER FEED
    (0000053526) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053527) CIpEvent::OnError 0:3:1
    (0000053528) error: client=9
    (0000053529) GET TWITTER FEED
    (0000053530) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053531) CIpEvent::OnError 0:3:1
    (0000053532) error: client=9
    (0000053533) GET TWITTER FEED
    (0000053534) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053535) CIpEvent::OnError 0:3:1
    (0000053536) error: client=9
    (0000053537) GET TWITTER FEED
    (0000053538) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053539) CIpEvent::OnError 0:3:1
    (0000053540) error: client=9
    (0000053541) GET TWITTER FEED
    (0000053542) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053543) CIpEvent::OnError 0:3:1
    (0000053544) error: client=9
    (0000053544) GET TWITTER FEED
    (0000053545) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053546) CIpEvent::OnError 0:3:1
    (0000053547) error: client=9
    (0000053548) GET TWITTER FEED
    (0000053549) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053550) CIpEvent::OnError 0:3:1
    (0000053551) error: client=9
    (0000053552) GET TWITTER FEED
    (0000053553) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053554) CIpEvent::OnError 0:3:1
    (0000053555) error: client=9
    (0000053556) GET TWITTER FEED
    (0000053556) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053558) CIpEvent::OnError 0:3:1
    (0000053559) error: client=9
    (0000053559) GET TWITTER FEED
    (0000053560) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053561) CIpEvent::OnError 0:3:1
    (0000053562) error: client=9
    (0000053563) GET TWITTER FEED
    (0000053564) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053565) CIpEvent::OnError 0:3:1
    (0000053566) error: client=9
    (0000053567) GET TWITTER FEED
    (0000053568) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053569) CIpEvent::OnError 0:3:1
    (0000053570) error: client=9
    (0000053571) GET TWITTER FEED
    (0000053572) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053573) CIpEvent::OnError 0:3:1
    (0000053574) error: client=9
    (0000053575) GET TWITTER FEED
    (0000053576) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053577) CIpEvent::OnError 0:3:1
    (0000053578) error: client=9
    (0000053579) GET TWITTER FEED
    (0000053580) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053581) CIpEvent::OnError 0:3:1
    (0000053582) error: client=9
    (0000053582) GET TWITTER FEED
    (0000053583) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053584) CIpEvent::OnError 0:3:1
    (0000053585) error: client=9
    (0000053586) GET TWITTER FEED
    (0000053587) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053588) CIpEvent::OnError 0:3:1
    (0000053589) error: client=9
    (0000053590) GET TWITTER FEED
    (0000053591) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053592) CIpEvent::OnError 0:3:1
    (0000053593) error: client=9
    (0000053594) GET TWITTER FEED
    (0000053595) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053596) CIpEvent::OnError 0:3:1
    (0000053597) error: client=9
    (0000053597) GET TWITTER FEED
    (0000053598) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053599) CIpEvent::OnError 0:3:1
    (0000053600) error: client=9
    (0000053601) GET TWITTER FEED
    (0000053602) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053604) CIpEvent::OnError 0:3:1
    (0000053605) error: client=9
    (0000053606) GET TWITTER FEED
    (0000053606) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053608) CIpEvent::OnError 0:3:1
    (0000053609) error: client=9
    (0000053609) GET TWITTER FEED
    (0000053610) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053611) CIpEvent::OnError 0:3:1
    (0000053612) error: client=9
    (0000053613) GET TWITTER FEED
    (0000053614) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053615) CIpEvent::OnError 0:3:1
    (0000053616) error: client=9
    (0000053617) GET TWITTER FEED
    (0000053618) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053619) CIpEvent::OnError 0:3:1
    (0000053620) error: client=9
    (0000053621) GET TWITTER FEED
    (0000053622) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053623) CIpEvent::OnError 0:3:1
    (0000053625) error: client=9
    (0000053625) GET TWITTER FEED
    (0000053626) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053627) CIpEvent::OnError 0:3:1
    (0000053628) error: client=9
    (0000053629) GET TWITTER FEED
    (0000053630) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053631) CIpEvent::OnError 0:3:1
    (0000053632) error: client=9
    (0000053633) GET TWITTER FEED
    (0000053634) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053635) CIpEvent::OnError 0:3:1
    (0000053636) error: client=9
    (0000053636) GET TWITTER FEED
    (0000053638) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053640) CIpEvent::OnError 0:3:1
    (0000053641) error: client=9
    (0000053641) GET TWITTER FEED
    (0000053642) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053643) CIpEvent::OnError 0:3:1
    (0000053644) error: client=9
    (0000053645) GET TWITTER FEED
    (0000053646) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053647) CIpEvent::OnError 0:3:1
    (0000053648) error: client=9
    (0000053649) GET TWITTER FEED
    (0000053650) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053651) CIpEvent::OnError 0:3:1
    (0000053652) error: client=9
    (0000053652) GET TWITTER FEED
    (0000053653) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053656) CIpEvent::OnError 0:3:1
    (0000053657) error: client=9
    (0000053658) GET TWITTER FEED
    (0000053665) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053717) CIpEvent::OnError 0:3:1
    (0000053727) error: client=9
    (0000053727) GET TWITTER FEED
    (0000053728) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053729) CIpEvent::OnError 0:3:1
    (0000053730) error: client=9
    (0000053743) GET TWITTER FEED
    (0000053744) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053745) CIpEvent::OnError 0:3:1
    (0000053746) error: client=9
    (0000053747) GET TWITTER FEED
    (0000053748) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053750) CIpEvent::OnError 0:3:1
    (0000053751) error: client=9
    (0000053752) GET TWITTER FEED
    (0000053753) CIpSocketMan::ProcessPLPacket - Socket Already Closed
    (0000053755) Connected Successfully
    (0000053757) CIpEvent::OnError 0:3:1
    (0000053758) error: client=9
    (0000053759) GET TWITTER FEED
    (0000053761) Exiting TCP Read thread - closing this socket for local port 3
    (0000053762) CIpEvent::OnLine 0:3:1
    (0000053764) online: client
    (0000053765) CIpEvent::OffLine 0:3:1
    (0000053767) offline: client
    (0000053914) IPDeviceDetector.run(): joined multicast group
    (0000054364) Memory Available = 5572148 <18812>
    (0000055764) Connected Successfully
    (0000055766) CIpEvent::OnLine 0:3:1
    (0000055767) online: client
    (0000056364) Memory Available = 5551284 <20864>
    (0000295650) Exiting TCP Read thread - closing this socket for local port 3
    (0000295651) CIpEvent::OffLine 0:3:1
    (0000295652) offline: client
    It's the IP_CLIENT_CLOSE in your function fnConnectToTwitter(). Calling the close function throws an error initially cuz it's already closed. Error 9 = "already closed". Having that there will definitely screw things up cuz you attempt to open by first closing which will throw the error while the connection is connecting but because it threw the error it's going to launch that function again which starts by closing the connection.
    I suppose after a certain amount of time you happen to call the function which calls the close while the port is still open and then its happy and doesn't throw an error and then has a chance to complete the opening.
    After another look at your code it looks like all those errors are being caused prior to you wait 20 executing to open the port. It's telling you it's closed and then you tell it to close again and again until the wait ecxecutes and opens the port. Then it's a matter of timing and hopefully it won't open right after an error.
    I would get rid of the wait 20 too but add a wait (2-3 minutes) in define_start to call the function maybe set a tracking variable in the online event and reset it in the offline event and then check the variable in the connect function. if not online connect type of thing.
    This is getting hard to track because you cross-posted it. Try to stay to one thread, it's just less confusing.
    Huh?
    I've been trying to follow this post and get my first web page scraping to work for the yahoo weather, but you guys are lightyears ahead of me! Can we back up a little bit (I mean all the way to the beginning...)? I am looking for the basic functions of an IP connection/web page scrape. This is what I believe I need:
    I need devices to be Identified:
    dvIPWeather   = 0:2:0     //Yahoo Weather API IP Connection
    dvTP = 10001:1:0
    I need variables:
    Optional - a var to set a flag indicating the status of my IP connection
    volatile integer nWeatherOnline
    Required - a var (buffer) to place the page scrapings into
    CONSTANT CHAR dvWeather[10000]
    A function or call to start the IP connection
    DEFINE_FUNCTION fcnWeather() //Weather polling function
    	IP_CLIENT_OPEN (dvIPWeather.PORT,'weather.yahooapis.com',80,1) ;//yahoo site
    A Data Event to handle the connect, disconnect, and strings:
    DATA_EVENT[dvIPWeather]  //data event to query yahoo weather
    	ONLINE:
    		SEND_STRING dvIPWeather, "'GET /forecastrss?p=89131 HTTP/1.0',13,10,13,10"
    		nWeatherOnline = 1
    	STRING:
    		SEND_STRING 0, "'STRING dvIPWeatherBuff----------',dvIPWeatherBuff"
    	OFFLINE:
    		nWeatherOnline = 0
    And a button press to initiate the function:
    BUTTON_EVENT[dvTP,53]
    		fcnWeather()
    After all this, I am getting an error in Netlinx;
    Starting NetLinx Compile - Version[2.5.2.20] [09-28-2009 22:42:38]
    C:\laptop backup\RobsAMXFiles\JVC\JVC LT37X898 Main.axs
    ERROR: C:\laptop backup\RobsAMXFiles\JVC\JVC LT37X898 Main.axs(581): C10540: Illegal expression, node type [-1]
    ERROR: C:\laptop backup\RobsAMXFiles\JVC\JVC LT37X898 Main.axs(0): C10541: Illegal operator in expression, node type [-1]
    ERROR: (0): C10580: Internal Error: Major system error occurred during code generation
    C:\laptop backup\RobsAMXFiles\JVC\JVC LT37X898 Main.axs - 3 error(s), 0 warning(s)
    NetLinx Compile Complete [09-28-2009 22:42:39]
    What am I missing? I have tried to drag my constant array into my debug window, but its length always stays at zero.
    Code:
    Is this in the define variable section?
    change to:
    volatile char dvWeather[10000] ;
    I'm not sure why I decided to put a constant variable under define_variable...I think I saw a previous post about doing this. That fixed the compiling errors, but is there a way for me to debug this step by step? I tried viewing the string char in the watch tab, but its length doesn't change from zero. Is there another item I can view in the watch bar for this?
    I need to specify the D:P:S in netlinx device notifications and then select the string to/from, online, offline, don't I?
    So what about my notifications/debug windows? Is there something I can do to see whether or not an IP connection is actually made/disconnected? When I execute the function I created to run the IP_client_open, I see no notifications other than the button press and release. I have added the DPS (0:2:0 to start, now at 0:3:0)to device notifications.
    I have started to figure out the telnet window in netlinx studio, and turned on extended diagnostics. (Man it sure makes it tough when everyone's eating dinner or enjoying themselves in the evening! ;-/ ) I see the following info when I run the IP_Client_Open:
    (0000390084) Connected Successfully
    (0000390087) CIpEvent::OnLine 0:3:1
    (0000390154) STRING dvIPWeatherBuff----------
    (0000390158) Exiting TCP Read thread - closing this socket for local port 3
    (0000390158) STRING dvIPWeatherBuff----------
    (0000390159) CIpEvent::OffLine 0:3:1
    What is 0:3:1? I specified 0:3:0 in my programming.
    It appears that my data event is partially running - I see the STRING portion, but not the ONLINE. If I add the send string data from my online event:
    	IP_CLIENT_OPEN (dvIPWeather.PORT,weather,80,1) //yahoo site
    	WAIT 5 'IP delay'
    I get the following result in my telnet window when executing:
    (0000100735) Connected Successfully
    (0000100737) CIpEvent::OnLine 0:3:1
    (0000100816) STRING dvIPWeatherBuff----------
    (0000100819) Exiting TCP Read thread - closing this socket for local port 3
    (0000100820) STRING dvIPWeatherBuff----------
    (0000100820) CIpEvent::OffLine 0:3:1
    (0000101170) SendString to socket-local port (3) invalid
    (0000101171) CIpEvent::OnError 0:3:1
    The OnError I added just to see the word error pop up on my touchscreen. I'm assuming that happened because the socked was already closed as I tried to send the string after the initial connection, probably from the double CRLFs.
    If I am off-base here and the online is indeed running, shouldn't I be able to print out the info in my buffer? I assume I need to set my buffer equal to data.text.
    0:3:0 is a loopback address of the master that runs the code... In your case, if the master ID is 1, it will translate to 0:3:1
    Have a look at this code, and then play around. You will be able to build up on this logic framework, and, maybe, spot your mistakes.
    dvRSS = 0:3:0
    CHAR xmldata[10000]
    DEFINE_CALL 'reload'
        xmldata = ''
        IP_CLIENT_OPEN(dvRSS.PORT,'xml.weather.yahoo.com', 80, 1)
        CREATE_BUFFER dvRSS, xmldata
    (* EVENTS GO BELOW *)
    DATA_EVENT [dvRSS]
        ONLINE:
    	SEND_STRING dvRSS, "'GET http://weather.yahooapis.com/forecastrss?p=SFXX0010&u=c HTTP/1.0', 13, 10, 'Connection: Close', 13, 10, 13, 10"
        OFFLINE:
    	SEND_STRING 0, xmldata
    Now just call "reload" at a button press or time based event... Of course, you will have to develop a parsing algorythm (I will leave that to you), and replace the city code (this is for Cape Town) with your own.
    vegastechvegastech Posts: 369
    Ok, so it appears that my GET request was incorrect, where I needed to include the full URL length. Is the only way to determine this going to be just "trying" different ways to connect to the website? Can I test this in the Netlinx telnet session at all?
    Now that I actually have a buffer full of data (1053 characters to be precise), I am trying to parse it. I have a select..active statement within my STRING: event:
    STRING:
    		dvIPWeatherBuff = data.text
    		SEND_STRING 0, "'STRING dvIPWeatherBuff--------',dvIPWeatherBuff";
    		SEND_COMMAND dvJVCLT37X898Tp,"'^TXT-10,0,',dvIPWeatherBuff"
    		//yweather:units
    		SELECT
    				ACTIVE (FIND_STRING(dvIPWeatherBuff,'temp="',1)):
    						SEND_COMMAND dvJVCLT37X898Tp,"'^TXT-10,0,temp'"
    And I want to print the resulting temperature number into my touchpanel's button. Once I have found the string I want (which I am successfully doing), I want to set another char variable (or in the case of temperature, I guess an integer would work better) to the text found. How can I do that without knowing the exact starting location in the string?
    PhreaKPhreaK Posts: 966
    vegastech wrote: »
    FIND_STRING will return an integer specifying the location of the first character of the sequence within the string you are searching you can then use that to do the rest of your logic.
    Ok, I still don't get it. Find_String is my friend. got it. I am able to do a find_string on the temp=, and set it equal to an integer variable:
    nTempStart = (FIND_STRING(dvIPWeatherBuff,'temp="',1))
    I
    n this case, I'm looking for temp=, and specifically the two or three numbers behind the equal sign. So if Find_String returns an integer (say 155) which is the start of the item temp=98, do I use Remove_String to then remove the 98? (that would put the string number starting at character 160, right?)
    Yep, you've got the FIND_STRING component sorted.
    You could do a remove string to get rid of everything before then and the grab a couple of characters or you could use MID_STRING to extract the characters you are interested in.
    I needed a quick break from what I was working on so here's a present:
     * Gets the value of the first instance of an XML element attribute within the
     * passed string.
     * @param		sString		the string to search
     * @param		sAttribute	a string specifying the attribute to look up
     * @return			a string containing the value of the attribute
    DEFINE_FUNCTION CHAR[32] fnGetXMLAttributeValue(CHAR sString[], CHAR sAttribute[]) {
        STACK_VAR INTEGER nAttrLocation
        STACK_VAR INTEGER nStartIndex
        STACK_VAR INTEGER nEndIndex
        STACK_VAR CHAR[32] sValue
        // Find the location of the attribute
        nAttrLocation = FIND_STRING(sString, "' ',sAttribute,'="'", 1)
        // Grab the bounding character indexes of the value
        nStartIndex = nAttrLocation + LENGTH_STRING(sAttribute) + 3
        nEndIndex = LENGTH_STRING(sString) - FIND_STRING(sString, "'"'", nStartIndex)
        // Extract the value
        sValue = MID_STRING(sString, nStartIndex, nEndIndex - nStartIndex)
        RETURN sValue
    It's completely untested but it should help you out. Just call it like so...
    nTemp = ATOI(fnGetXMLAttributeValue(sBuffer, "'temp'")
    Here's an example of find_string that uses the starting point number that's returned by the function call find_string. In this example the returned format is always the same so I use the pack man approach and gobble up & spit out the data as I parse through it.
    stack_var integer nFBS
         stack_var integer n
         stack_var integer i
         if (find_string(iRSSBuf,"'<title>',sCity.city",1))
    	  {// Kill the function around (time) if you prefer 24 hour time format
    	  sRSS.lastupdate = fn24TimeTo12(time)
    	  nFBS = find_string(iRSSBuf,"'<title>',sCity.city",1)
    	  if (nFBS)
    	       cRSSTrash = get_buffer_string(iRSSBuf, nFBS + 6)
    	       nFBS = find_string(iRSSBuf,'</title>',1)
    	       sRSS.title = get_buffer_string(iRSSBuf, nFBS - 1)
    	       i ++
    	  else
    	       sRSS.title = 'N/A'
    	  nFBS = find_string(iRSSBuf,'/zipcode/',1)
    	  if (nFBS)
    	       cRSSTrash = remove_string(iRSSBuf,'/zipcode/',1)
    	       nFBS = find_string(iRSSBuf,'/',1)
    	       sRSS.rcvdzip = get_buffer_string(iRSSBuf, nFBS - 1)
    	       i ++
    	  else
    	       sRSS.rcvdzip = 'N/A'
    	  if (nFBS)
    	       sRSS.overview = get_buffer_string(iRSSBuf, nFBS - 1)
    	       i ++
    	  else
    	       sRSS.overview = 'N/A'
    Here's another example using find_string that I use for returns whose order of info may vary depending on the browser used. Here I leave the return intact & copy out the desired data because data didn't always appear in the same order or didn't always contain all the same info. So if the data's there I'll get it, if not I clear the previous returned values and move on.
     nFBS = find_string(iHTML_Head,"' HTTP/'",1) ;
    	  if(nFBS)
    	       cFileName = GET_BUFFER_STRING(iHTML_Head,nFBS -1) ;
    	       nFBS = find_string(iHTML_Head,"CRLF",1) ;
    	       if(nFBS)
    		    cHTTPVersion = GET_BUFFER_STRING(iHTML_Head,nFBS -1) ;
    		    if(cHTTPVersion[1] == "' '")
    			 GET_BUFFER_CHAR(cHTTPVersion) ;
    		    ///  FROM HERE ON WE LEAVE THE STRING INTACT AND JUST COPY WHAT WE'RE LOOKING FOR SINCE THE ORDER //
    		    ///  OF THE ITEMS WE'RE LOOKING FOR MAY CHANGE DEPENDING ON BROWSER CONNECTED !!!!                //
    		    nFBS = find_string(iHTML_Head,"'User-Agent: '",1) ;
    		    if(nFBS)
    			 nFBS_2 = find_string(iHTML_Head,"CRLF",nFBS + 12) ;
    			 nWebAgent = fnFindUserAgent(MID_STRING(iHTML_Head,nFBS + 12,nFBS_2 - (nFBS + 12))) ;//add one
    		    else//leave in in case we set above variable to "LOCAL_VAR" for testing.
    			 nWebAgent = WINGENERIC ;//use as default
    		    nFBS = find_string(iHTML_Head,"'Referer: '",1) ;
    		    if(nFBS)
    			 nFBS_2 = find_string(iHTML_Head,"CRLF",nFBS + 9) ;
    			 cReferer = MID_STRING(iHTML_Head,nFBS + 9,nFBS_2 - (nFBS + 9)) ;//add one
    			 cReferer = '' ;
    		    nFBS = find_string(iHTML_Head,"'Content-Type: '",1) ;
    		    if(nFBS)
    			 nFBS_2 = find_string(iHTML_Head,"CRLF",nFBS + 14) ;
    			 cContentType = MID_STRING(iHTML_Head,nFBS + 14,nFBS_2 - (nFBS + 14)) ;//add one
    			 cContentType = '' ;
    		    nFBS = find_string(iHTML_Head,"'Connection: '",1) ;
    		    if(nFBS)
    			 cConnection = MID_STRING(iHTML_Head,nFBS + 12,nFBS_2 - (nFBS + 12)) ;//add one
    			 cConnection = '' ;
    		    nFBS = find_string(iHTML_Head,"'Cache-Control: '",1) ;
