can this CAM SITE be cracked?
GSLogic
There is a new company that will be hosting almost all the traffic cameras around the US. Its designed with a timer and a registation key to limit the number of hits. Is there is an IP wiz out there that knows a way around this?
http://www.trafficland.com/
This is the TP dynamic address, but it only work for a limited time and a PC has to hit it first.
http://pub2.camera.trafficland.com
/image/live.jpg?system=mdot&webid=8440&
size=full&pubtoken=d83dfcef3ecd0033c58a5b0bafd4dfaa&1218979952578
If you wish to except this mission...
Just a thought
OR (* LIGHT BULB! *) Maybe AMX could workout a deal with them and offer the service to dealers???
$500 a month!!!!!!!!!!!!!!!!!!!
Ohh, and I'm sure that this just an exercise for academic purposes and you would never try to circumvent security measures in order to obtain the data in ways that are not approved by the content provider, but you may want to make sure this is clear. I would hate to see an attempt to gain knowledge in IP communications result in an experience to gain knowledge of court proceedings
I was challenged by the owner, he said it couldn't be done and of course it's only for fun!
So you first need to 'touch' the page to get the pubtoken en then you can request the image...
Pretty good idea to protect your content I must say:)
If you set it up like that, after a while it stops working. They have more going on then just the pubtoken. Every time you have to request the main site first then hold the unique id number and you have to repeat this every time... very cleaver $
If you determine how long the token lasts, I would try setting up a program that does an IP_CLIENT connection to the hosting page every so often, and scrape the image's URL from the data that comes back, then pass that URL on to your touch panel. They probably have some HTTP elements required that are normally supplied by a traditional browser, so you'd have to monitor the HTTP header sent by your browser and have your Netlinx program emulate that.
Or did I miss/gloss over something there?
That's what I was thinking but . . . I'm without a master right now, so I couldn't test the theory.
http://amxforums.com/showthread.php?t=4080&highlight=Ethernet+power+controller
maybe you could borrow some parts or some ideas. It sounds like you need to sit down with WireShark (Ethereal) and collect all the data going back and forth during a PC session. Set the filter to just the website. That's basically what I had to do in this module which has to retirieve a cookie. The username and password with MD5 encryption is not likely required but it does sound like you need to collect a cookie in your initial GET and use it in subsequent GETs or Posts.
I can see everything being sent over the connection but I can't figure it out... yet! I need to spend more time to analyze it all.
Thanks for the ideas!
I used php to mimic HTTP requests to the webserver, because it would only show the image if you connected with a webbrowser.
I could then display the image returned from the php script as a dynamic image. Worked pretty good, the only thing was, it had "static" image names. (page 101 had image name 101.gif or something)
I can't find the php script at the moment, but i used Curl commands (http://curl.haxx.se/) for the HTTP request mimicing.
Maybe this would be a nice start to actually retrieve the images from the webserver
