Simple UDP communication
Hi there.
I would send UDP packets from my Netlinx controller to a PC (with IP address 192.16.0.10).
My Netlinx source looks something like this in the DEFNE_START section:
IP_CLIENT_OPEN (12345, '192.16.0.10', 54321, 2) (*open the communication*)
instead the DEFINE_EVENT contains:
SEND_STRING 0:12345:0, 'UDP test!'
I cannot receive anything on my PC but I'm sure the listener is ok.
Could someone suggest me how to achieve this simple communication?
Thanks a lot in advance!
Stefano
Stefano
Not Much to UDP.
DEFINE_DEVICE dvTP = 10001:1:0 dvSocket = 0:2:0; DEFINE_EVENT BUTTON_EVENT[dvTP,1] { PUSH: { // was this the actual IP address of the PC???? Maybe 192.168.0.10???? IP_CLIENT_OPEN (dvSocket.Port, '192.16.0.10', 54321, IP_UDP) (*open the communication*) // Unlike TCP, UDP opens immediately SEND_STRING dvSocket, 'UDP test!' IP_CLIENT_CLOSE(dvSocket.Port); } }// Little UDP Test Program, May help to explain UDP Communications
DEFINE_DEVICE dvMaster = 0:1:0; dvServer = 0:2:0; dvServerClient = 0:3:0; dvClient = 0:4:0; dvTP = 10001:1:0; DEFINE_CONSTANT SERVER_PORT = 50000; DEFINE_VARIABLE IP_ADDRESS_STRUCT uMyIPStuff; DEFINE_START GET_IP_ADDRESS(dvMaster, uMyIPStuff); WAIT 100 'START UDP SERVER' { IP_SERVER_OPEN(dvServer.Port, SERVER_PORT, IP_UDP); } DEFINE_EVENT BUTTON_EVENT[dvTP,1] { PUSH: { IP_CLIENT_OPEN(dvClient.PORT, uMyIPStuff.IPADDRESS, SERVER_PORT, IP_UDP_2WAY); SEND_STRING dvClient,"'Hello, World!'" } } DATA_EVENT[dvClient] { ONLINE: { SEND_STRING 0,"'CLIENT OPEN!'"; } STRING: { SEND_STRING 0,"'SERVER SAID: ',DATA.TEXT"; IP_CLIENT_CLOSE(dvClient.PORT); } } DATA_EVENT[dvServer] { STRING: { SEND_STRING 0,"'CLIENT SAID: ',DATA.TEXT"; IP_CLIENT_OPEN(dvServerClient.PORT, DATA.SOURCEIP, DATA.SOURCEPORT, IP_UDP); SEND_STRING dvServerClient,'GOT IT!'; IP_CLIENT_CLOSE(dvServerClient.PORT); } OFFLINE: { SEND_STRING 0,"'SERVER CLOSED!'"; IP_SERVER_OPEN(dvServer.Port, SERVER_PORT, IP_UDP); } ONLINE: { SEND_STRING 0,"'SERVER OPEN!'"; } }I've tried the following code:
PROGRAM_NAME='UDPTest'
SERIAL= 5001:1:0
dvSocket = 0:2:0
LONG TL_ARRAY[] = {1000, 1000}
TIMELINE_CREATE (1, TL_ARRAY, 2, TIMELINE_RELATIVE, TIMELINE_REPEAT)
DATA_EVENT [SERIAL]
ONLINE:
SEND_COMMAND DATA.DEVICE, 'SET BAUD 9600,N,8,1'
SEND_STRING SERIAL, 'Online'
TIMELINE_EVENT[1]
SWITCH(TIMELINE.SEQUENCE)
CASE 1: SEND_STRING SERIAL, 'Serial Test'
FOR (CONT=1; CONT<=10; CONT++)
OFF [Relay, 1]
WAIT 1
ON [Relay, 1]
IP_CLIENT_OPEN (dvSocket.Port, '192.16.0.10', 54321, IP_UDP) //IP address is 192.16.0.10 ;-)
CASE 2: SEND_STRING SERIAL, 'Serial Test 2'
OFF [Relay, 1]
DEFINE_PROGRAM
but the listener still doesn't receive anything.
The listener is on port 54321 on the PC and the serial data is shown correctly on my PC using HyperTerminal.
Can you help me a little more?
CLIENT SAID: Hello, World!
SERVER SAID: GOT IT!
After some attempts I've made it works! Now I can receive packets from a PC and send to another using UDP protocol!
Thanks thanks thanks!
