PLK-SB2 Behaviour
Hi,
I'm not familiar with these and addinf one to a netlinx system using PLK-DMS keypads.
After defining the physical and virtual devices and module
DEFINE_MODULE 'SB1-SB2Mod' MDSB1(vdvSB1,dvSB1)
tested its function as follows
BUTTON_EVENT [vdvSB1, 1]
TO [dvAV_RELAY8, 1] // THE RELAY WILL TURN ON WHILE BUTTON HELD
Noticed that notifications are repeated in the notifications window (PUSH PUSH then RELEASE RELEASE).
Behaviour is erratic, ie
- hold and release button - it stays on after release for a while then goes off
- sometimes it doesnt respond
- delayed response
general craziness.
Am I missing anything? The module documentation is sparse.
TIA
  • I've established that duplicated notifications also occur with the working DMS keypads in the installation without problems.
    The issue seam related just to the PLK-PB2. Have swapped out for another unit and get the same result.
    Does anyone have some experince with these in a Netlinx install they'd care to share?
    TIA.
