Combining Wired and wireless TP
I am new to programming and I have made combine device wired TP and wireless TP (NXD 7000 and Modero 8400). The issue was it does not follow each other once you push any button. I define Virtual TP to combine two touch panel as one. Is there other method to combine TP..
I would recommend using a DEV array. This doesn't tie the devices together in a strict sense. It's just a convenient way to group several things together for sending / recieving stuff.
It looks something like this..
DEFINE_DEVICE dvTP_1 = 10001:01:0 dvTP_2 = 10002:01:0 dvTP_3 = 10003:01:0 DEFINE_VARIABLE volatile DEV dev_TP[]= { dvTP_1, dvTP_2, dvTP_3 } volatile integer dev_TP_Buttons[]= {1,2,3,4,5,6,7,8,9,10} DEFINE_EVENT BUTTON_EVENT[dev_TP , dev_TP_Buttons] { PUSH: { TP_DEVICE=Button.Input.Device.Number // This will tell you wich real device was pushed. TP_PORT=Button.Input.Device.Port // which port TP_SYSTEM=Button.Input.Device.System // from which system TP_BUTTON_PUSHED=BUTTON.INPUT.CHANNEL which button // DO SOMETHING. send_command dev_TP, *some command* // this will send the command to all devices in the array. send_command TP_DEVICE:TP_PORT:TP_SYSTEM, * some command * // This sends the command to just the one that really pushed the button. } }Hope that helps
