iPort v3.21 module - NO R4
Hello (my first hello around here)
Quite new in the AMX, getting drawn in by my company's switch-over from C*.* to A*.*
I am busy programming a system which, amongst others, integrates an iPort. Any help would be highly appreciated in guiding me through the module utilization, but with 2 MVP52001 and two AXD-C4's (no R4)
Long story short, the provided UI interface with this module has provisions for R4's, and I was just wandering if I have to add a "dummy" one, or edit all the references to R4 out from the UI module.
Many thanks.
Many thanks.
Since there are only a total of 4 references, I took them out of the UI module.
Am I correct then in saying that the header of my UI module will be showing:
plus also removing the four references to the R4's in the module body?
line 1365 to 1381
and line 1545 to 1555
I am surprised you say "no problems", or maybe I am doing something wrong...
I could not get a decent feedback from the module vdviPort with v3.21. For some odd reason, the strings were "delivered" only like every other second, the fastest. The current time count would only update at 2 - 3 seconds, not to mention that the song title, the total track time and so forth would have to be lucky to get parsed and delivered.
When watching the actual serial port, the strings were having a pace of 4-5 updates per second, which makes me believe that the module itself does not make an OUT for every IN.
Never the less, when I overwrote the "iPort COMM" file with v3.0 beta, everything started to become alive and every input string had a parsed value at the exit from the module...
I would be curious if I might have overlooked something, and I am interested in finding a way to give a chance to v3.21, as it seems to be addressing some bugs as well.
