Anyone get their Color Viewstat Yet?
                                  in AMX Hardware
                    Greetings,
After about a year of waiting, it seems like my Color Viewstat may have shipped. I'm out of town for another week yet and I am curious if anyone actually got one.
Anyone got one yet? What's in the box?
I received 3 of the new color viewstats. Only one of the three worked. The other two are completely dead. AMX does not have any more to replace the dead units so I have to wait again. The Duet module is not available yet. Still a little frustrating.
Thanks.
Aside from the potential power problem, I am very happy with the product. It is very attractive and easy to program. There are still a few things that need attention at a firmware level, but I'm sure that they will be dealt with in due time.
There are some other nit-picks, but they're minor and I'll give them some time.
I've already modified the original Netlinx iWeather module to support the VST-C with forceasting. The protocol is very easy to deal with.
It's very nice. It creates a structure containing all elements of the weather forecast.
The protocol of the VST-C is very easy to deal with as well.
We did get ours, but we had to return them for their firmware update. We now have 30 thermostats for a job that we will be returning after the "good ones come out"
LCD: looks good in color. I wish we had similar house audio keypads looking like this.
INTERFACE: To change modes (Auto, Cool, Heat, Off) hold the MODE/SELECT button while in the main display, keep pushing the MODE/SELECT button to toggle through the Fan settings and under Heat or Cool use the arrows keys to select (Auto, Cool, Heat, Off). You can also access this menu from the settings display. I think they could have done a better job here, like listing the modes instead of toggling all over. This maybe confusing for the end user if they are working with the thermostat. If they are using a touch panel, then you can make discrete buttons to change the modes. Preset changing is very easy. FRom the main display press any of the arrow keys to acces the presets for Cool and Heat.
SCHEDULE PROGRAMMING: It is very easy to program the 4 available modes (Wake, Leave, Return and Sleep) in the thermostat. You can also Enable and Disable the schedule.
DUET MODULE: Needs improvement. It covers just the basics. Modes, Fan control, presets, etc. It is lacking the most important thing: The ability to schedule from a touch panel. In the past, I have used a module written by VAV Vining for the Enerzone/AMX VST-Stats, which provides the touch panels the ability to set up schedules for the VST-Stats. Vining did a great job here. After a few adjustments on Vinings module I was able to implement ICSNet control as well. WE NEED AMX to implement a similar approach to the color thermostat (ENV-VST-C). Maybe Vining will adapt his module for the ENV-VST-C as well. I wish AMX would take the next step and polish their modules so we could spend more time selling AMX stuff than trying to implement them. I have a job with 36 thermostats and I am still considering using the older module and thermostats. I wish AMX would get in touch with a guy like VAV Vining, who problem spent a lot of time creating the scheduler and implement something similar on their modules. I am just sick of the start up AMX modules. In this case, a scheduler is a must. I will contact AMX and VAV Vining and see if they could exchange some info and bring the scheduler to the ENV-VST-C Duet module. Overall, the product has great potential.
iSchedule stores all parameters on the flash as well.
I've never seen the VAV module, but I'm sure it's nice. I'm a roll-my-own type.
