Alarm Clock Examples
I am looking for creative alarm clock functions using a touchpanel in order to set the alarm time, different alarm methods (TP beeps, ties to other systems), along with ways to acknowledge the alarm.
E.
    QUOTE]
    If the user throws the Modero across the room smashing it against the wall and it goes offline, that should activate the SLEEP function.
  • yuriyuri Posts: 861
    just your luck, the new firmware has a builtin clock manager :p
    Make some buttons to change the beep, and set a time and you are done :)
  • DenisDenis Posts: 163
    Yuri
    Can you elaborate? I'm looking for to do same ting in MVP8400, new firmware of..... do you mean?
    We offer an alarm clock feature on our panels. (as well as an oven/ kitchen timer)
    The feature lets the client select either a beep-beeop from the panel or will turn on soemthing in the whole house audio or their room TV.
    Thanks Eric
    Only one thing, I don't have panel on hand, I have only a MVP8400 on hand,(I thing as it has new firmware) You told as the feature is accessible for customer, how the customer can access this page? By panel control? Module avaible?
    Denis wrote: »
    Thanks Eric
    It's a part of the program. It's not something native to the panel itself.
    Thanks, I will try to do that.
    I wrote a very elaborate module once that let the user set multiple alarms from any location in his house, and could have it either pop up on the local panel, or ring a phone extension. It worked really well, but I had some half-baked ideas about making it modular that wound up in fact adding so much bloat I can barely make sense of it any more. I'd start from scratch before re-using that mess.
    Hi
    I tried to wrote an alarm clock but i'm unable to do work it. The code to adjust time seem works fine ( except I don't get the ) in minute section ex: 01 min I get 1) but the rest of the code dosen't works. I goet no error from compiler.
    Some body can help me?
    ps DHawthorne if your module works fine and if is it avaible, where I can get it?
    Variables
    INTEGER nHH		// VARIABLE TO DETERMINE ALARM CLOCK
    INTEGER nMM		// VARIABLE TO DETERMINE ALARM CLOCK
    SINTEGER nTHH
    SINTEGER nTMM
    CHAR TimeStr [8]
    CHAR nAAHH [2]
    CHAR nAHHH [2]
    Start up section
    nHH = 0
    nMM = 00
    //SECTION ALARM CLOCK
    BUTTON_EVENT [dvTP_ALLARM_SET,51]
        IF (nHH < 23)
    	nHH = nHH +1
    	SEND_COMMAND dvTP_ALLARM_SET,"'@TXT',70,ITOA(nHH)"
        ELSE
    	IF (nHH = 23)
    	    nHH = 0
    BUTTON_EVENT [dvTP_ALLARM_SET,52]
        IF (nHH > 0)
    	nHH = nHH - 1
        ELSE
    	IF (nHH = 0)
    	    nHH = 23
    BUTTON_EVENT [dvTP_ALLARM_SET,53]
        IF (nMM < 59)
    	nMM = nMM +1
    	SEND_COMMAND dvTP_ALLARM_SET,"'@TXT',71,ITOA(nMM)"
        ELSE
    	IF (nMM = 59)
    	    nMM = 0
    BUTTON_EVENT [dvTP_ALLARM_SET,54]
        IF (nMM > 0)
    	nMM = nMM - 1
        ELSE
    	IF (nMM = 0)
    	    nMM = 59
    //END OF SECTION ALARM CLOCK
    (*            THE ACTUAL PROGRAM GOES BELOW                *)
    DEFINE_PROGRAM
    nAAHH = ITOA(nHH)
    nAAMM = ITOA(nMM)
    nTHH = TIME_TO_HOUR (TimeStr)
    nTMM = TIME_TO_MINUTE (TimeStr)
    IF ((nAAHH == nAHH)&&(nAAMM == nAMM))
    CALL 'CURTAINS_CLOSED'
  • I can see two items in your example.
    The first is TimeStr does not equal anything. So when you do your TIME_TO_HOUR (TimeStr)
    nothing is returned.
    If it were me I would use TIME_TO_HOUR (TIME) and not worry about TimeStr
    Second, your code is in main line so. once you get the TIME_TO_HOUR function to work right your call is going to happen a bunch of times.
    during the minute that nAAMM == nAMM the 'curtain closed' call will be called as many times as main line can run in a 60 second period.
    One thing I like to do is setup a repeating timeline that runs once a minute. In the time line I would put the code that you have written
    TIMELINE_EVENT[tl60_Second_Update]
      nAAHH = ITOA(nHH)
      nAAMM = ITOA(nMM)
      nTHH = TIME_TO_HOUR (TIME)
      nTMM = TIME_TO_MINUTE (TIME)
    Hope this helps.
    One thing I would highly suggest is to convert you time over to Julian. (or at least change it to some kind of 'minutes past some time in the past' ) It seems difficult at first but it makes the alarm time math much nicer and you can create multiple timers much easier.
    I'm not willing to share my module - it's nearly incomprehensible even to me, and I would be embarrassed to share it.
  • How do you make the scrolling code blocks?
  • mpullinmpullin Posts: 949
    ericmedley wrote: »
    Epoch time would be my preference.
    kbeattyAMX wrote: »
    Write enough code in your regular code blocks :p
    Seriously, [@CODE]DEFINE_PROGRAM wait 1 CALL 'foo'[/@CODE]
    (remove @s)
    No problem Dave I understand.
    Concerning my problem, I change the variable to by more comprehensive, I tried Time line suggest by Dan
    When I put this code in main line,I get an error from compiler
    "ERROR: F:\AMX Program files Rev 2.1\Brosseau Demo,Rev 2.axs(1827): C10201: Syntax error; Illegal or Invalid syntax in code
    F:\AMX Program files Rev 2.1\Brosseau Demo,Rev 2.axs - 1 error(s), 0 warning(s) "
    When I put in Define Event section the compiler don't return error but dosen't work.
    nT for Time nA for Allarm
    integer tl60_Second_Update
    SINTEGER nTHH
    SINTEGER nTMM
    CHAR nAHH [2]
    CHAR nAMM [2]
      nAHH = ITOA(nHH)
      nAMM = ITOA(nMM)
      IF ((nAHH == nTHH)&&(nAMM == nTMM))
        CALL 'CURTAINS_OPEN'
  • MODULE_NAME='AlarmClock COMM' (dev vdvAlarm)
    (*  FILE_LAST_MODIFIED_ON: 04/04/2006  AT: 11:33:16        *)
    (* System Type : NetLinx                                   *)
    (* REV HISTORY:                                            *)
        $History: $
    		Channels 1-10 are pulsed when the assiciated alarm is triggered
    		send_command vdvAlarm,'AlarmSet-1:12:00'
    		send_command vdvAlarm,'AlarmGet-1'
    (*               CONSTANT DEFINITIONS GO BELOW             *)
    DEFINE_CONSTANT
    MinuteTimeline = 1
    (*              DATA TYPE DEFINITIONS GO BELOW             *)
    DEFINE_TYPE
    integer curr_alarm_edit
    persistent char alarms[10][10]
    long MinuteTimelineTime[] = {60000} //1 minute
    DEFINE_CONSTANT
    DEFINE_TYPE
    (*               LATCHING DEFINITIONS GO BELOW             *)
    DEFINE_LATCHING
    (*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
    DEFINE_MUTUALLY_EXCLUSIVE
    (*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
    (*                STARTUP CODE GOES BELOW                  *)
    curr_alarm_edit = 1
    timeline_create(MinuteTimeline,MinuteTimelineTime,1,timeline_absolute,timeline_repeat)
    (*                THE EVENTS GO BELOW                      *)
    data_event[vdvAlarm]
      command:  // command format= SEND_COMMAND vdvAlarm,'AlarmSet-1:10:15' for 10:15am
    	  if (find_string(data.text,'AlarmSet-',1))
    		  remove_string(data.text,'AlarmSet-',1)
    			curr_alarm_edit = atoi(remove_string(data.text,':',1))
    			alarms[curr_alarm_edit] = data.text
    		if (find_string(data.text,'AlarmGet-',1))
    		  remove_string(data.text,'AlarmGet-',1)
    		  curr_alarm_edit = atoi(data.text)
    		  send_string vdvAlarm,"'AlarmSet-',itoa(curr_alarm_edit),':',alarms[curr_alarm_edit]"
    timeline_event[MinuteTimeline]
    	if (find_string(time,alarms[1],1)) 	pulse[vdvAlarm,1]
    	if (find_string(time,alarms[2],1)) 	pulse[vdvAlarm,2]
    	if (find_string(time,alarms[3],1)) 	pulse[vdvAlarm,3]
    	if (find_string(time,alarms[4],1)) 	pulse[vdvAlarm,4]
    	if (find_string(time,alarms[5],1)) 	pulse[vdvAlarm,5]
    	if (find_string(time,alarms[6],1)) 	pulse[vdvAlarm,6]
    	if (find_string(time,alarms[7],1)) 	pulse[vdvAlarm,7]
    	if (find_string(time,alarms[8],1)) 	pulse[vdvAlarm,8]
    	if (find_string(time,alarms[9],1)) 	pulse[vdvAlarm,9]
    	if (find_string(time,alarms[10],1))	pulse[vdvAlarm,10]
    This is a COMM version of a module but there is no real AMX device to control.
    PROGRAM_NAME='Alarm Clock'
    (*  FILE_LAST_MODIFIED_ON: 04/05/2006  AT: 09:00:25        *)
    (* REV HISTORY:                                            *)
        $History: $
    dvTP = 10001:1:0
    vdvAlarm = 33001:1:0
    DEFINE_CONSTANT
    DEFINE_TYPE
    integer currTP_alarm_edit
    char time_entered[6]
    DEFINE_LATCHING
    define_module 'AlarmClock COMM' inst1(vdvAlarm)
    data_event[dvTP]  //time in from the TP
      string:
    	  if (find_string(data.text,'KEYP',1))
    		  remove_string(data.text,'KEYP-',1)
    			if ((length_string(data.text) < 3) or (length_string(data.text) > 4))
    			  //no action
    			else
    			  time_entered = right_string("'00',data.text",4)
    				send_command vdvAlarm,"'AlarmSet-',itoa(currTP_alarm_edit),':',time_entered[1],time_entered[2],':',time_entered[3],time_entered[4]"
    				send_command dvTP,"'TEXT',itoa(currTP_alarm_edit),'-',time_entered[1],time_entered[2],':',time_entered[3],time_entered[4]"
    button_event[dvTP,0]
      push:
    	  currTP_alarm_edit = button.input.channel
    DEFINE_PROGRAM
    [dvTP,1] = (currTP_alarm_edit=1)
    [dvTP,2] = (currTP_alarm_edit=2)
    [dvTP,3] = (currTP_alarm_edit=3)
    [dvTP,4] = (currTP_alarm_edit=4)
    [dvTP,5] = (currTP_alarm_edit=5)
    [dvTP,6] = (currTP_alarm_edit=6)
    [dvTP,7] = (currTP_alarm_edit=7)
    [dvTP,11] = [vdvAlarm,1]
    [dvTP,12] = [vdvAlarm,2]
    [dvTP,13] = [vdvAlarm,3]
    [dvTP,14] = [vdvAlarm,4]
    [dvTP,15] = [vdvAlarm,5]
    [dvTP,16] = [vdvAlarm,6]
    [dvTP,17] = [vdvAlarm,7]
    [dvTP,18] = [vdvAlarm,8]
    [dvTP,19] = [vdvAlarm,9]
    [dvTP,20] = [vdvAlarm,10]
    (*                     END OF PROGRAM                      *)
    (*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
    This is the main code that can be changed to a UI Module. You can use whatever you want to make HH:MM. I prefer using the Keypad. Let me know what you think.
    of course to trigger any event you want just add:
    channel_event[vdvAlarm,0]
      on:
        switch (channel.channel)
          case 1: closecurtains()
  • John PaulJohn Paul Posts: 143
    Alarm code review neeeded.
    I have pasted the alarm code below, somehow i am not able to store the time value in the string variable. When i run the code, i get the following in diagnostics . Obviously i am not doing the data conversions properly. I have attached the touch panel layout, so you will know the channel nos . Please guide.
    Line 1 (20:29:41):: GetString - Error 1 Tk=0x0001
    Line 2 (20:29:41):: CopyString (Reference) - Error 1 S=0x0000 D=0x1011
    Line 3 (20:29:50):: GetString - Error 1 Tk=0x0001
    Line 4 (20:29:50):: CopyString (Reference) - Error 1 S=0x0000 D=0x1011
    Line 5 (20:34:34):: GetString - Error 1 Tk=0x0001
    Line 6 (20:34:34):: CopyString (Reference) - Error 1 S=0x0000 D=0x1011
    Line 7 (20:34:42):: GetString - Error 1 Tk=0x0001
    Line 8 (20:34:42):: CopyString (Reference) - Error 1 S=0x0000 D=0x1011
    PROGRAM_NAME='incAlarm'
    dvTPBedRoom1Alarm = 10006:58:2
    define_constant
    MinuteTimeline = 1
    INTEGER nTP_COUNT=3
    integer nHoursMax=12
    integer nHoursMin=1
    integer nMinutesMax=59
    integer nMinutesMin=0
    // TIMELINE IDS
    LONG lPanelRING_TIMEOUT1 = 200 // TIMEOUT FOR TOUCH PANEL RING
    VOLATILE LONG lRING1[] = {2000}
    volatile integer nPanel1AlarmHour= 7
    volatile integer nPanel1AlarmMinute=0
    volatile char sPanel1AlarmPeriod='AM'
    Volatile char sPanel1Alarm []= '7:00 AM'
    Volatile integer nPanel1ShutterEvent=0
    Volatile integer nPanel1LightsEvent=0
    Volatile integer nPanel1AudioEvent=0
    Volatile integer nPanel1CurtainsEvent=0
    Volatile integer nOtherEvent2=0
    Volatile integer nPanel1AlarmSet=0
    Volatile integer nPanel1SnoozeSet=0
    integer nAlarmbtns[]=
    1, //Lights Events
    2, //Shutter events
    3, //Audio Events
    4, //His Table
    5, //Her Table
    6, //Hour up
    7, //Hour down
    8, //Minutes up
    9, //Minutes down
    10, //Period Up
    11, //Period Down
    12, //Period State
    13, //Alarm On/Off
    14, //Snooze On/Off
    15, //Alarm time State
    16, //Hour state
    17, //Minutes
    18, //Alarm Off
    19, //Snooze On
    20
    DEFINE_function char Alarm (integer nAlarmHour,integer nAlarmMinute,char sAlarmPeriod,dev Panel)
    stack_var integer nAlarmPMHour
    stack_var integer sAlarm
    if (nAlarmMinute>=10)
    IF (sAlarmPeriod=='PM')
    nAlarmPMHour=nAlarmHour+12
    send_command Panel,"'^TXT-15,0,',ITOA(nAlarmHour),':',ITOA(nAlarmMinute),' PM'" //Temp display
    }else
    send_command Panel,"'^TXT-15,0,',ITOA(nAlarmHour),':',ITOA(nAlarmMinute),' AM'"
    sAlarm="ITOA(nAlarmPMHour),':',ITOA(nAlarmMinute),':00'"
    }else
    send_command Panel,"'^TXT-15,0,',ITOA(nAlarmHour),':0',ITOA(nAlarmMinute),' PM'" //Temp display
    }else
    send_command Panel,"'^TXT-15,0,',ITOA(nAlarmHour),':0',ITOA(nAlarmMinute),' AM'"
    sAlarm="ITOA(nAlarmPMHour),':0',ITOA(nAlarmMinute),':00'"
    REturn sAlarm
    DEFINE_Call 'Alarm Time' (char sAlarm,integer nAlarmSet,integer nShutterEvent,integer nLightsEvent,integer nCurtainsEvent,integer nAudioEvent,dev Panel,integer nSnoozeSet)
    IF (TIME = sAlarm)
    send_String 0,"'Alarm Time =', sAlarm,' and Time =',Time"
    if (nAlarmSet==1)
    IF (nShutterEvent=1)//Shutter
    do_push(dvTPLutronDiwaniya52,91)
    IF (nLightsEvent=1)//Lights
    do_push(dvTPLutronDiwaniya52,71)
    IF (nCurtainsEvent=1)//Curtains
    do_push(dvTPLutronDiwaniya52,72)
    IF (nAudioEvent=1)//Audio
    do_push(dvTP_AMFMARRAY[5],21)
    wait 10
    do_push(dvTP_AMFMARRAY[5],18)
    // wait 30
    //do_push(virtualTPMBRTangoVolume,292)
    if (Panel==dvTPBedRoom1Alarm)
    IF (TIMELINE_ACTIVE(lPanelRING_TIMEOUT1))
    TIMELINE_KILL(lPanelRING_TIMEOUT1)
    TIMELINE_CREATE(lPanelRING_TIMEOUT1, lRING1, 1, TIMELINE_RELATIVE, TIMELINE_REPEAT)
    nPanel1AlarmSet=0
    IF (nSnoozeSet=1)//Snooze
    SEND_COMMAND Panel,"'^SHO-19,1'"
    }else
    SEND_COMMAND Panel,"'^SHO-19,0'"
    send_command Panel, "'PAGE-[Home]Main Page'"
    send_command Panel, "'@PPN-Alarm Popup'"
    define_start
    DATA_EVENT [dvTPBedRoom1Alarm]// contains real and virtual TP devices
    ONLINE:
    if ([dvTPBedRoom1Alarm,13]==1)
    SEND_COMMAND dvTPBedRoom1Alarm,"'^ENA-1.11&14,0'"
    else{
    SEND_COMMAND dvTPBedRoom1Alarm,"'^ENA-1.11&14,1'"
    BUTTON_EVENT[dvTPBedRoom1Alarm,nAlarmbtns]
    SWITCH(GET_LAST(nAlarmbtns))
    case 1:// Shutter Event
    if ([dvTPBedRoom1Alarm,1]==1)
    [dvTPBedRoom1Alarm,1]=0
    else{
    [dvTPBedRoom1Alarm,1]=1
    nPanel1ShutterEvent=1
    case 2://Lights Event
    if ([dvTPBedRoom1Alarm,2]==1)
    [dvTPBedRoom1Alarm,2]=0
    else{
    [dvTPBedRoom1Alarm,2]=1
    nPanel1LightsEvent=1
    case 3://Audio Events
    if ([dvTPBedRoom1Alarm,3]==1)
    [dvTPBedRoom1Alarm,3]=0
    nPanel1AudioEvent=0
    else{
    [dvTPBedRoom1Alarm,3]=1
    nPanel1AudioEvent=1
    case 4://Curtains Events
    if ([dvTPBedRoom1Alarm,4]==1)
    [dvTPBedRoom1Alarm,4]=0
    else{
    [dvTPBedRoom1Alarm,4]=1
    nPanel1CurtainsEvent=1
    case 5: //
    if ([dvTPBedRoom1Alarm,5]==1)
    [dvTPBedRoom1Alarm,5]=0
    nOtherEvent2=0
    else{
    [dvTPBedRoom1Alarm,5]=1
    nOtherEvent2=1
    case 6://Hours up
    if (nPanel1AlarmHour<nHoursMax)
    nPanel1AlarmHour=nPanel1AlarmHour+1
    send_command dvTPBedRoom1Alarm,"'^TXT-16,0,',ITOA(nPanel1AlarmHour)" //Temp display
    case 7: //Hour down
    if (nPanel1AlarmHour>nHoursMin)
    nPanel1AlarmHour=nPanel1AlarmHour-1
    }else if (nPanel1AlarmHour=nHoursMin)
    case 8:// Minutes up
    if (nPanel1AlarmMinute<nMinutesMax)
    nPanel1AlarmMinute=nPanel1AlarmMinute+1
    if (nPanel1AlarmMinute>=10)
    send_command dvTPBedRoom1Alarm,"'^TXT-17,0,',ITOA(nPanel1AlarmMinute)" //Temp display
    }else
    send_command dvTPBedRoom1Alarm,"'^TXT-17,0,0',ITOA(nPanel1AlarmMinute)" //Temp display
    case 9:// Minutes down
    if (nPanel1AlarmMinute>nMinutesMin)
    nPanel1AlarmMinute=nPanel1AlarmMinute-1
    }else if (nPanel1AlarmMinute=nMinutesMin)
    }else
    case 10://Period up
    off[dvTPBedRoom1Alarm,12]
    case 11://Period down
    on[dvTPBedRoom1Alarm,12]
    sPanel1AlarmPeriod='PM'
    case 13: //Alarm on/off
    if (nPanel1AlarmSet==1)
    [dvTPBedRoom1Alarm,13]=0
    else{
    [dvTPBedRoom1Alarm,13]=1
    nPanel1AlarmSet=[dvTPBedRoom1Alarm,13]
    sPanel1Alarm=''
    sPanel1Alarm= Alarm (nPanel1AlarmHour,nPanel1AlarmMinute,sPanel1AlarmPeriod,dvTPBedRoom1Alarm)
    case 14://Snooze on/off
    if ([dvTPBedRoom1Alarm,14]==1)
    [dvTPBedRoom1Alarm,14]=0
    else{
    [dvTPBedRoom1Alarm,14]=1
    nPanel1SnoozeSet=[dvTPBedRoom1Alarm,14]
    case 18: //Alarm off
    case 19://Snooze on
    wait 6000 'Panel1Snooze'
    send_command dvTPBedRoom1Alarm, "'PAGE-[Home]Main Page'"
    send_command dvTPBedRoom1Alarm, "'@PPN-Alarm Popup'"
    Hold [3,REPEAT]:
    case 6://Hours up
    case 7: //Hour down
    }else
    }else
    TIMELINE_EVENT[lPanelRING_TIMEOUT1]
    SEND_COMMAND dvTPBedRoom1Alarm,"'@SOU-doorbell6.wav'"
    call 'Alarm Time'(sPanel1Alarm,nPanel1AlarmSet,nPanel1ShutterEvent,nPanel1LightsEvent,nPanel1CurtainsEvent,nPanel1AudioEvent,dvTPBedRoom1Alarm,nPanel1SnoozeSet)
    Hey no help needed, i modified the if condition to look for the time to hour and time to minute and stopped storing the time in a variable and viola it started working
