problem with EPSON EMP-1825 Projector
We recently replaced EPSON EMP 835 with New EMP-1825 Projector in one of the board room.It is in a remote location and the RS 232 codes for New and old is exactly same, so we didn't update the programming part.Now the problem is ,everything works....except that there is a lag time in controlling the new projector.Any idea?
  • nishadsyd wrote: »
    The protocol may be similar but the 2 projectors respond differently and feedback different information from a common poll PWR?. Take a look at the ESC/VP21 Command User guide from Epson.
    I suspect the old code is looking for specific feedback and is not finding that feedback to cancel default wait times. You can't know for sure without looking at the code.
  • code
    Here is the part of code.Please note that we have 3 projector in this room.Other 2 are EMP-835 and one is EMP-1825
    DEFINE_CONSTANT
    PROJ_ON = 'PWR ON'
    PROJ_OFF = 'PWR OFF'
    PROJ_VIDEO = 'SOURCE 41'
    PROJ_PC1 = 'SOURCE 11'
    DEFINE_CALL 'PROJ1 CONTROL'
    INPUT_PROJ_1 = INPUT
    IF(SYSTEM_1_FIRST_RUN)
    DO_PUSH (dvTP_LIGHTS,LIGHT_50)//DIM LIGHTS
    OFF[SYSTEM_1_FIRST_RUN]
    IF(PROJ1_PWR_STATUS = 0)
    SEND_STRING dvProj_1, "PROJ_ON,$0D"
    DO_PUSH (DVTP,SELECT_SCREEN_DOWN)
    DO_PUSH (DVTP,SELECT_LIFT_DOWN)
    WAIT 250 SEND_STRING dvProj_1, "INPUT_PROJ_1,$0D"
    ELSE SEND_STRING dvProj_1, "INPUT_PROJ_1,$0D"
    DATA_EVENT[dvProj_1]
    ONLINE:
    TIMEARRAY[1] = 5000
    TIMELINE_CREATE (TL_PROJ_RM01_POLL, TimeArray, 1, TIMELINE_RELATIVE, TIMELINE_REPEAT)
    //SEND_COMMAND DATA.DEVICE, 'SET BAUD 9600,N,8,1 485 DISABLE'
    SEND_COMMAND dvProj_1,'SET BAUD 9600,N,8,1 485 DISABLE'
    //SEND_STRING dvProj_1,"'PWR?',$0D"
    STRING:
    RM01_PROJECTOR_BUFFER = DATA.TEXT
    IF (RM01_PROJECTOR_BUFFER = "'PWR=00',$0D,':'")
    OFF [dvTP,SELECT_PROJECTOR_ON]
    ON[dvTP,SELECT_PROJECTOR_OFF]
    IF(LIFT1_POS = DOWN)
    DO_PUSH(dvTP,SELECT_LIFT_UP)
    IF((SIGNAL1 = VIDEO_SIGNAL)OR(SIGNAL1= VGA_SIGNAL))
    IF (RM01_PROJECTOR_BUFFER= "'PWR=01',$0D,':'")
    PROJ1_PWR_STATUS = 1
    IF(LIFT1_POS = UP)
    ON [dvTP,SELECT_PROJECTOR_ON]
    OFF [dvTP,SELECT_PROJECTOR_OFF]
    IF (RM01_PROJECTOR_BUFFER= "'SOURCE=11',$0D,':'")
    CURRENT_INPUT_PROJ_1 = PROJ_PC1
    IF (RM01_PROJECTOR_BUFFER= "'SOURCE=41',$0D,':'")
    CURRENT_INPUT_PROJ_1 = PROJ_VIDEO
    TIMELINE_EVENT[TL_PROJ_RM01_POLL]
    SEND_STRING dvProj_1, "'PWR?',$0D"
    WAIT 5 SEND_STRING dvProj_1, "'SOURCE?',$0D"
    BUTTON_EVENT[dvTP,SELECT_PROJECTOR_ON]
    SEND_STRING dvProj_1,"'PWR ON',$0D"
    DO_PUSH (dvTP,SELECT_LIFT_DOWN)
    DO_PUSH (dvTP,SELECT_SCREEN_DOWN)
    ON[dvTP,SELECT_PROJECTOR_ON]
    OFF[dvTP,SELECT_PROJECTOR_OFF]
    BUTTON_EVENT[dvTP,SELECT_PROJECTOR_OFF]
    SEND_STRING dvProj_1,"'PWR OFF',$0D"
    SIGNAL1 = 0
    WAIT 200 DO_PUSH (DVTP,SELECT_LIFT_UP)
    DO_PUSH (dvTP,SELECT_SCREEN_UP)
    OFF[dvTP,SELECT_PROJECTOR_ON]
  • You have a condition in this code that depends upon the feedback strings from the projector.
    I cannot see that the Epson responds with a CR in it's feedback but the code is looking for a CR. Since the variable PROJ1_PWR_STATUS never goes to 1 the code will constantly turn on the projector and wait 25 seconds to send the input command when ever you change inputs. AMX has a Duet Module that should work with your projectors with a simple command interface. Like channel 255 gives you the power status of the projector.
    I hope this helps.
  • Thanks Ken, let me try this .thanks a lot
