Weather module in AMX Home
mvadormvador Junior MemberPosts: 17
Hey guys..
I am using two touch panels in a residential unit.. NXD CV5 and NXT-1200..
Both of them have the AMX home weather modules.. the problem is tat the weather doesnt show up unless I telnet into the master and then ping the touch panels.. once I do tat its fine.. then if they r rebooted for some reason again I have the same problem..
Does anyone know a fix for this issue ??
  • davidvdavidv Junior Member Posts: 90
    Mayor
    I am confused are you using maps from AMX HOME? or are you pulling data and parsing it from the web?
  • mvadormvador Junior Member Posts: 17
    i am parsing the maps frm weather.com
    Mayor
    Copy and paste the file extension that you entered into TPD4 for the dynamic image.
