Help with NEC PX-50XM5A
I working on a system that contains an NI-3100 controller, and an NEC PX-50XM5A plasma monitor. The module I got from the AMX website ( http://amx.com/inconcert/ct/DevMdlDetails.asp?A=Sh&MdlNo=29222&MANNo=679&lk=cb2e5a9015f2460dfdd42dde1f85e103 ) is working. I've tested it with a touch panel connected to the system, and everything seems to be functioning. I can even connect to the controller via telnet and send commands manually (PULSE 41001:1:0,27) that successfully turn the TV/monitor on/off. However, I'm not getting any feedback from the monitor. I have watched the serial actvity lights for the port the NEC monitor is connected to, and the Tx light comes on when I send commands either via button press on the touch panel or manually via telnet, but the Rx light is never active. An example of the error/message I'm getting is below.
I have tried changing the "Protocol Set" from ON to OFF on the TV itself. The AMX documentation for the NEC plasma module states:
Any help would be appreciated. (BTW, I'm really not familiar with what an "AMX Beacon" is.)
>PULSE 41001:1:0,27 Sending Pulse[41001:1:1,27] >(0001686301) com.amx.duet.impl.nec.genericPlasma.dr1_0_0.NecGenericPlasma: No r esponse received for last message sent.
When "Protocol Set" is set to ON, the TV does not respond to any commands (either via TP or telnet), and when set to OFF, responds to all commands perfect. I've double checked with the installers, and they've followed the 3wire RS-232 diagram listed in the module documentation.* Please Note that these devices do support an AMX Beacon; however, it is mutually exclusive to the
RS-232 port on the device. This means that the beacon can be enabled and the RS-232 protocol disabled,
or the beacon can be disabled and the RS-232 protocol enabled. This is done via a menu setting located
under the ?Option 2? menu, called ?Protocol Set?. ?ON? means that the AMX beacon response is enabled,
?OFF? means that the RS-232 protocol is enabled.
If you're commands are getting through but not coming back, it's probably a wire problem.
Another thing you can do is hook up a computer to it and see if you're getting a response.
I can only guess that this is a "magic packet" sent out requesting that DDDP devices identify themselves.
Connect to the screen with HyperTerminal and ensure strings are indeed being received from the screen after you issue a cmd. Ideally using all site cabling.
If strings are being received, Control A Device in NSX and force an RXON to the port after the module is fully up and running - maybe it's been missed in the module.
HTH
As per the NEC documentation:
AMX documentation:
Might the absence of the RTS and CTS pins have something to do with it? Thanks again for the help.
Stick a link on the plasma screen end b/t CTS and RTS and it might be a bit more chatty
Make sure you have some traffic management code in your serial port handler though!
:cool:
