Home Duet/Cafe Duet
Cafe Duet 1.5?
I am trying to install Cafe Duet with WebUpdate and it shows Duet Platform ver 1.10.198 is ready to install and it is the only appliction listed with all apps being search for. When I try to install it I get a pop-up stating
"Please Make sure you installed the minimum version of Cafe Duet 1.5 and then re-run this setup program."
I can not find Cafe Duet 1.5, anyone know how I can get this version.
  • PhreaKPhreaK Posts: 966
    You have to purchase Cafe Duet. Once you have done so you will be able to update it through webupdate as new versions are released.
  • Cafe Duet has to be purchased. "Duet Platform 1.10.198" is an update to Cafe Duet.
    Both are NOT required to do daily programming, it is the SDK for programming Duet (Java) Module.
    To use the available Duet modules in your code, you should have installed the latest "Duet Runtime Environment". The version you have installed can be checked in NetLinx Studio2 in menu Help->About NetLinx Studio
