bar graph for audio level
Stewart
We are attempting to redesign our AMX fleet of touch panels to have a similiar look to the ******** ones now all over campus. I have a meeting today where i am to show what i have accomplished as of now ( TP design 3 plus access programming). I am sure I will be asked to design small volume bargraphs as they are in the ******** Tps. Probably also have to mute volume. Is this a huge deal ? Define connect level for bar graphs etc?
nope, it works quite well. If you're using a G3 color panel with the latest firmware you must remember that there are only 21 faders available. (7 per device times 4 devices per panel.)
Many Clients compare ***** panels with older AMX Panels.
These are older tps
AXT-MCP w/PB
The code uses these snippets
CREATE_LEVEL VOLUME,1,PROGRAM_LEVEL
then a system call
SYSTEM_CALL 'VOL1'(TP,56,57,0,VOLUME,1,2,0)
I added in a define connect level
The volume button does not "fill up" on tp
i am missing something
Do i have to do something like this:
SEND_COMMAND TP,"'x',ITOA (NEWVOLUME)"
Sorry for the spotty notes but I am learning as I go. Thanks!!!
I'm not sure what you mean by "fill up". Is the BarGraph moving? I normally use DEFINE_CONNECT LEVEL (dvVOL,1,dvTP,1) this connects level one on the AXBVOL3 to Level 1 on the TP. There is not other coding needed. The system call needs to be below DEFINE_PROGRAM and it basically controlling Volume UP and DOWN. Button 56 is VOL up using channel 1 on the AXBVOL3 box and Button 57 is volume down using channel 2 on the same VOLUME device. The mute button has not been programmed.
Bargraph not moving
perhaps I screwed up the Tp design file and the colors are the same so I could not see the change?
I put the define_connect level here:
DEFINE_LATCHING
DEFINE_COMBINE
(MSP8,MSP8B)
DEFINE_CONNECT_LEVEL
(VOLUME,1,TP,1)
Sytem call is here:
DEFINE_PROGRAM
SEND_LEVEL TP,1,PROGRAM_LEVEL
SYSTEM_CALL 'SLD1' (SLIDE1,TP,44,45,46,47,48,0,0)
If I created a mute button/assigned a channel the system call would set the value to 0 and mute?
Again Thanks for any input. I am off today but brought controller and tp home to test.
From AMX_PI...
SYSTEM_CALL 'VOL1'(TP,56,57,0,VOLUME,1,2,0) needs to be SYSTEM_CALL 'VOL1'(TP,56,57,58,VOLUME,1,2,3) This will give you toggle control of the muting. System calls are located in C:\Program Files\Common Files\AMXShare\SYCs. There you can see what exactly the SYC does. Of course you can use any button you want for muting. I just stuck 58 in there.
I am in Tp design and trying to assign the device number for tp( 128)
in bargraph button properties I keep getting a message that states
This panel only supports devices from 1-1?
huh?
