DEVICE_ID
jjames
Is there a list of what is returned for each device type?
jjames
hmmm...
please elaborate.
I know I could do DEVICE_ID and track it all myself for the ones we use most often, but I was just wondering if there's any documentation that already has this laid out.
Or am I not understanding what DEVICE_ID is? I've never used it and never seen it until I took a gander in the iPort UI module; seems like it could be very useful.
I do like the way it's used in this module and it would make code more plug n play than what I currently do based on dev.number which obviously changes job to job.
IF(DEVICE_ID(iTP) < 256) //Is it a G3 Panel in the array? { SEND_COMMAND iTP, "'TEXT',ITOA(nCHAN),'-',strMSG" //G3 Panels without Unicode Support fnIPort_Debug("'Running fnSEND_VTEXT() for G3 DEV-,',fnDEV_TO_STRING(iTP),', ',strSTRING2,'. Line-<',ITOA(__LINE__),'>'") ; } //NOTE: Unicode not supported on G3 panels ELSE //It must be a Modero Panel and not a G3 panel { IF(DEVICE_ID(iTP) == 322) //Is it an R4 Remote in the array? { fnIPort_Debug("'Running fnSEND_VTEXT() for R4 DEV-,',fnDEV_TO_STRING(iTP),', ',strSTRING2,'. Line-<',ITOA(__LINE__),'>'") ; //Send Nothing - Use Virtual R4 in Main.axs in DEV array for iPort UI devices } ELSE { SEND_COMMAND iTP, "'^UNI-',ITOA(nCHAN),',0,',strSTRING2" //Unicode Modero Panels fnIPort_Debug("'Running fnSEND_VTEXT() for G4 DEV-,',fnDEV_TO_STRING(iTP),', ',strSTRING2,'. Line-<',ITOA(__LINE__),'>'") ; //SEND_COMMAND dvTP,"'^TXT-',ITOA(nCHAN),',1&2,',strMSG" // G4 panels without Unicode } }You'll find it in "AMX Supplemental Product Documentation" -> Device ID Information
Marc, thanks! I looked everywhere except there. I'll have to dig around in there.
And also . . . I want the "Private version" - not the public.
Maybe better NOT to know them?!?! :rolleyes:(j/k)
G'day Jeremiah,
Have you tried DEVICE_INFO, or more specifically DEVICE_ID_STRING?
An NXD-CV5 returns 'NX-CV5' using DEVICE_ID_STRING.
Some older devices don't report fully but everything new that I've checked does.
Cheers
Mush
I am working on a module and was wondering if it was possible to figure out whether the module was defined for use on a NI-700 or a NI-3100 or a NI-4000. From the above, the DEVICE_IDs for the master controllers are all a bit too similar (e.g. NI-2100, -3100, and -4100 are all the same).
When using an IR output (e.g. port 9 on a NI-3100 and port 5 on an NI-2100) for serial control, I need to send additional setup info (set mode data); knowing which controller the device was attached to would help me determine in the module which setup info to send.
Am I making it too hard?
Thx in advance!
Here is what I get from (see attached).
NI4000
NI2000
NI700
They all have the same DEVICE_ID_STRING and there is no difference between the NI2000 and the NI4000 for the DEVICE_ID. Any other ways to allow my code to determine what kind of controller it is on?
PS MANUFACTURER string: interesting to note that AMX is no longer a Corporation and is now an LLC.
Thanks!
>show device 5001 Show Device ----------- Local devices for system #1 (This System) ---------------------------------------------------------------------------- Device (ID)Model (ID)Mfg FWID Version 05001 (00286)NI-3100 (00001)AMX LLC 00383 v1.20.7 (PID=0:OID=0) Serial='N/A',0,0,0,0,0,0,0,0,0, Failed Pings=0 Physical Address=Internal Connection >It lists the correct name here so I don't know why dev_id_string says all 3 unless that command just uses the dev_id to determine the string/s and doesn't just get the string itself directly from the master which it also knows. Makes no sense. And why don't we have dev_id's for the new devices published yet in the newest version of PI.You need to pass the device controller (5001 by default) rather than the master (device 0) to DEVICE_INFO() in order to get the master type. It's really annoying and illogical.
I assume that at some point the firmware used to report master type for device 0 as well as this is what RMS uses - when you look at master types they all appear as 'NI Master', which is completely useless.
@Phreak: thanks for the tip! Used 5001:1:0 for the controllers; see new output below.
Again, the forums prove very helpful. Thanks!
The NI series is an integration of a master and a device controller. If you look at an online tree you?ll see each part, 00000 Master and 05001 NI-xxx. Each has their own firmware. If you expand the 05001 node you?ll see the ports for that device that represent the RS-232 ports, IR ports, etc.
The 5001 device is really what differentiates the NI series not the master.
Less annoying and logical now?
If you?re talking about when I said this:
It was in reference to the original problem which was this: Knowing what type of master is of no use in this case. You need the 5001 device info. That?s all I was trying to say even if I did so badly.
Has anyone been able to get 5001 DEVICE_INFO for a system other than the one the code is running in?
As shown in the attached snapshot I can get master (device 0) info from a system in the URL list but not 5001.
Here is the code:
My bad, teaches me for coming in half way through a thread.
When I think different masters the main factor that comes to mind is processing power and memory available for use (/abuse), device controller and connectivity guff is all done through dynamic devices and abstracted from underlying device controller types. So with that in mind RMS's master type reporting is still uterly useless.
0x0110 Broadband Music Player
0x0125 ADA Suite16 - Does this unit connect directly to a processor for easy control?
maybe this is the i! pclink mediaplayer application?
EDIT:
Nope, just checked it, PCLink mediaplayer is 0x111
08001 (00001)i!-PCLinkMediaPlaye(00001)AMX Corp. 00279 v1.0.13
(PID=0:OID=0) Serial=IIPMP00000000001 Failed Pings=0
Physical Address=IP 172.16.200.26
(00273)i!-PCLinkPlus (00001) 00279 v1.10
(PID=0:OID=1) Serial=0000000000000000
EDIT2:
w00h! check this out:
http://www.smarttvandsound.com/article/8270/
Too bad the www.mypanja.com domain is not working anymore...
I can't seem to find "Device ID Information" under "AMX Supplemental Product Documentation" in AMX-PI ? All I see listed under "AMX Supplemental Product Documentation" is "AXPOWER Power Consumption List"
If they have removed it, anyone have an archived copy of AMX-PI & would care to post the old list?
JL
PS It's been a long year, so I could easily be missing the obvious.
They're weren't all listed in the older vresion of PI either.
[code]
DEFINE_CONSTANT //DEVICE ID's
#DEFINE DEV_ID_CONSTANTS
/////////////////////////////////KEYPADS NO TEXT SUPPORT
DEV_ID_METKP_BEGIN = 169 ;
DEV_ID_MET6N = 169 ;
DEV_ID_MET7 = 170 ;
DEV_ID_MET13 = 171 ;
DEV_ID_METKP_END = 171 ;
/////////////////////////////////KEYPADS MIO DMS TEXT & UNI SUPPORT
DEV_ID_MIO_DMS_BEGIN = 304 ;
DEV_ID_MIO_DMS1 = 304 ; //Mio-DMS Keypad (non-color, non-touch display with buttons)
DEV_ID_MIO_DMS2 = 305 ; //Mio-DMS Keypad (non-color display with touch and slider)
DEV_ID_MIO_DMS3 = 306 ; //Mio-DMS Keypad (color display with touch and slider)
DEV_ID_MIO_DMS4 = 307 ; //Mio-DMS Keypad (color display with touch, slider, and intercom)
DEV_ID_MIO_DMS_END = 307 ;
/////////////////////////////////G3 PANELS
DEV_ID_G3_END = 256 ;
/////////////////////////////////G4 PANELS
DEV_ID_CA15 = 281 ; //NXx-CA15
DEV_ID_CV15 = 282 ; //NXx-CV15
DEV_ID_CA17 = 283 ; //NXx-CA17
DEV_ID_CV17 = 284 ; //NXx-CV17
DEV_ID_7500 = 288 ; //MVP-7500
DEV_ID_8400 = 289 ; //MVP-8400
DEV_ID_CV7 = 290 ; //NXx-CV7
DEV_ID_CV10 = 291 ; //NXx-CV10
DEV_ID_1200 = 294 ; //NXx-1200
DEV_ID_12VG = 295 ; //NXx-1200VG
DEV_ID_15VG = 296 ; //NXx-1500VG
DEV_ID_17VG = 297 ; //NXx-1700VG
DEV_ID_CV5 = 313 ; //NXD-CV5
DEV_ID_7500TC = 314 ; //MVP-7500 with Touch Controller
DEV_ID_8400TC = 315 ; //MVP-8400 with Touch Controller
DEV_ID_CV7TC = 316 ; //NXx-CV7 with Touch Controller
DEV_ID_CV10TC = 317 ; //NXx-CV10 with Touch Controller
DEV_ID_12TC = 318 ; //NXx-1200 with Touch Controller
DEV_ID_12VGTC = 319 ; //NXx-1200VG with Touch Controller
DEV_ID_15VGTC = 320 ; //NXx-1500VG with Touch Controller
DEV_ID_17VGTC = 321 ; //NXx-1700VG with Touch Controller
/////////////////////////////////R4
DEV_ID_R4 = 322 ;
/////////////////////////////////CONT G4 PANELS
DEV_ID_8400i = 323 ; //MVP-8400i
DEV_ID_CV7iTC = 324 ; //NXx-CV7i with Touch Controller
DEV_ID_CV10iTC = 325 ; //NXx-CV10i with Touch Controller
DEV_ID_5200i = 329 ;
DEV_ID_5150 = 329 ;
DEV_ID_5100 = 329 ;
DEV_ID_500i = 331 ;
DEV_ID_9000i = 343 ;
DEV_ID_iPHONE = 347 ;
DEV_ID_iPAD = 348 ;
DEV_ID_iTOUCH = 349 ;
DEV_ID_430 = $6500 ; //presently unknown
DEV_ID_435 = $6501 ; //presently unknown
DEV_ID_435P = $6502 ; //presently unknown
/////////////////////////////////NI MASTERS
DEV_ID_NI2_3_4000_M = 285 ; //NI-2000/3000/4000 (Master)
DEV_ID_NI2_3_4000_D = 286 ; //NI-2000/3000/4000 (Device)
DEV_ID_NI700 = 298 ; //NI-700
DEV_ID_NI2_3_4000 = 299 ; //NI-2000/3000/4000
DEV_ID_NI900 = 312 ; //NI-900
/////////////////////////////////ENT VST - C
DEV_ID_ENVVSTC = $E5 ;
DEV_ID_VIRTUAL = 65534 ;
Sent from my iPad using Tapatalk
