I need some help to implement a module for a projector in my program
Hi
I want to use a module for a NEC NP4000 projector, I have downloaded it, but can't figure out have to merge it the rest of my program.
    atc wrote: »
    Hi
    If you downloaded the module from AMX you'll find it has an example project included that shows you how to put the module into your program. You can pretty much just cut and paste the code right into your program.
  • If your having any issues with the module I'm working on an AXI as we speak for the NEC 4000 series.
  • Rod NRod N Posts: 28
    This model projector is dodgy!!
    I have endured a large amount of pain as a result of this model (4000 series) in that it is highly susceptible to power fluctuations. The result being the unit will go into a 'high fan' mode and will only respond after a power reset. Tried three different units and all behaved the same way. They also close IP connections after 90 seconds - not ideal if you prefer to leave your IP connections open.
