AXR-RF + RTI U1.
u.w.stagger
in AMX Hardware
Hi there!
It's my first time working with AXR-RF.
I read in some threads that here are people who install RTI U1.
Please help.
This is what I do.
1. Take a new U1 , open Integration Designer v 6.2.1.1802. Make a new project with add U1.
Now I have system, that NOT send RF codes.
For make it work adding RP1 in system. Right click on button U1 and select Properties. Set Output Mode: Use device Default(RF Trigger Codes).
2. Open in a Library Browser AMX RF System Codes and assign some code on button.
3. Send project to U1.
4. Push buttons on U1, see flashing red light on AXR-RF, but nothing in Netlinx Notifications.
Both devices works on 433 MHz.
What I'm doing wrong?
Please help.
This is what I do.
You'll need to declare a device in the code for the unit.
Button pushes on the remote will correspond Button_Events on the device to whatever you're set them up to be.
RADIO=238:1:0
CHANNEL_EVENT[RADIO,21] //TEST
ON:
DO_PUSH (MODERO_A14,1400)
SEND_STRING 0,"'RF WORKS'"
With no result.
Device presents in Device Tree
See attachment.
http://img296.imageshack.us/my.php?image=projamxle5.png
It should work? Shold I see channel events in NS Notification?
And from software: You have to program BUTTON_EVENT[] for this.
There are a couple of ways of using RTIs with AMX.
One is to effectively emulate an AMX R2 - this needs no other RTI hardware, you're talking directly to the AMX system via the AMX RF receiver. In this instance you'd use the AMX RF trigger codes
The other is to use an RTI processor like the RP6 and to talk to that and then have it communicate with an AMX master - preferably over 232.
It sounds like you've not got either of those setups in place. Take the RP1 out of the equation and see how you get on.
As I said, AXB-RF presents in Online Tree. Should I see any responces in Netlinx diagnostics, when I push buttons on U1?
You don't need the RF output in Integration Designer to make this work. Have you assigned any AMX code to the button events? It might look counter intuitive but if you're doing this the simple AMX RF system codes route then all you need to do is drag the codes onto a button - you don't need an RP1 in the system
iainshaw, I did what you say, and all works now.
Glad you got it sorted.
Any feedback appreciated.
Thanks.
