define latching
What is the significance of this? Is it similiar to define toggling?
I was hoping to mute the picture using one button and then by pressing same button again cause an unmute condition.
perhaps a status variable and some if /elses?
Also in TP design 3 is there a way to have the on properties of a particuliar button have different text then the off properties?
Thanks in advance.
  • Without defining a mutually exclusive, latching and toggle look the same but...Latching needs a successive press of it channel to turn on or off the channel. Toggle channel can be turned off with a mutually exclusive definition.
    (* LATCHING DEFINITIONS GO BELOW *)
    DEFINE_LATCHING
    [dvTP,1]..[dvTP,9]
    (* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
    DEFINE_MUTUALLY_EXCLUSIVE
    ([dvTP,1]..[dvTP,19])
    define_toggling
    [dvTP,11]..[dvTP,19]
  • Sorry I messed that up... The Toggle will clear the feedback on a mutually exclusive channel and the Latch will not.
