PEX protocol
Hello guys,
I have an istallation with lighting control made with dimmers PED108 from apolloart.cz. The problem that i have is the prorocol....PEX....I cannot find a way to make it work...can you help me?
All I want is to have 4 different presets for 3 dimmers.
Please find attached the PEX protocol from apolloart.
Thank you!
  • jweatherjweather Posts: 320
    What commands are you trying? The protocol looks straightforward, just keep in mind that SOH=$01, STX=$02, ETB=$17. The manual doesn't show a code for ETX, but it's $03.
    The example from the manual for scene 5 on PEE120 in group 1 address 3 is:
    "$01, 'fP13', $02, '5B', $17, $03"
  • It worked!
    Thank you!
  • mpullinmpullin Posts: 949
    This is not to be confused with the PEZ protocol, in which the user fires a relay and the device responds with 1 bit of candy.
  • Nearly ten days and no one said a peep about your post?!?
    Well, Matt - I appreciated it and thought it was funny as hell...
    Thanks Chip, I had forgotten about this post actually
