Password and WAKEUP
Hi,
I am trying to get to a point where on WAKEUP of the panel and password screen is presented. The panels are AMX-CP4's.
I was wondering how do I capture the WAKEUP command from the panel and can I put the panel back to SLEEP ??
Ed
  • yuriyuri Posts: 861
    in the project properties you can enable strings to be sent out when entering sleep, wakeup, etc :)
  • Hi,
    Thanks - I got that far thou .. ;) How does one capture these strings ?
    Ed
  • Use the String: element of your TP Data_Event, the panel strings will be in data.text or alternatively you can create a buffer depending on your usage needs...
