Panasonic TH-xxPH10UK Protocol Anyone
Greetings,
Does anyone have the full protocol document for the latest generation of Pansonic plasmas?
Thank you.
  • Is it different then the PF9UK protocol?
    They seem pretty good about putting the protocol in the manual. Here is the page I have from a TH-65PF9UK.
  • There are many more commands beyond those shown in the manual, some of which I need. My inside man at Panasonic has since come through for me. Here is the full protocol if anyone could use it.....
  • Here it is.....
  • Thanks for posting that... now I can talk to the 103" in my basement. ;)
  • krukru Posts: 20
    TurnipTruck, thanks for protocol :)
  • Tuner
    Just in case somebody wants to use this with the TV Tuner module... I received the attached from Panasonic USA, with the following fine print:
    The attached file may also only be applicable to a Panasonic Hospitality models so it may not work in for your unit, which will depend on the firmware revisions of his Plasma D board and Tuner. We cannot confirm because this is not a USA model combination.
  • Thanks, felixmoldovan !
    Very useful manual indeed!
