Weird behaviour on an index count
Hi there.
I'm running the following code on a NI-2100 master (on the DEFINE_PROGRAM section):
I'm Brazilian, so the names of the variables are written in portuguese. Here goes a quick and basic translation/explanation of what it is supposed to do:
INDICE = INDEX
BUFFERDX is a buffer that is associated on the DEFINE_START section with a device to which I'm sending strings . The device is a programmable logic controller from a local brand, which the company I work for usually uses to control lights and windows on site.
ENVIA_uDX is a function that simply sums the bytes on the strings, attaches the result on the ending of the string and send it to the device
This whole code asks the device for the values of 8 specific variables (one at a time - according to the index value) and updates a touch panel (mvp-7500) with the received answers.
As seen in code, I'm sending the index value to the terminal along with the device's answer related to it. I have had no problems on communication, but had a small problem with the index counting. It counts up to seven with no problem at all, but when it receives the value 8, it's as if it had received no value at all.
The terminal shows something like:
INDICE = 1 , BUFFER = Answer 1
INDICE = 2 , BUFFER = Answer 2
INDICE = 3 , BUFFER = Answer 3
INDICE = 4 , BUFFER = Answer 4
INDICE = 5 , BUFFER = Answer 5
INDICE = 6 , BUFFER = Answer 6
INDICE = 7 , BUFFER = Answer 7
INDICE = , BUFFER = Answer 8
Is there something wrong with that little piece of code?
Thanks in advance and sorry for my lame english.
WAIT 3
IF (ENVIANDO <> 1)
INDICE = INDICE +1
IF (INDICE = 9)
INDICE = 1
CLEAR_BUFFER BUFFERDX
ENVIA_uDX("01,(30 + INDICE), 00")
WAIT 3
SEND_STRING 0, "'INDICE = ', INDICE, ' BUFFER = ', BUFFERDX"
IF(VERIFICA_BUFFER(BUFFERDX))
COMANDO = MID_STRING(BUFFERDX,1,1)
NVARIAVEL = MID_STRING(BUFFERDX,2,1)
VALOR = MID_STRING(BUFFERDX,3,1)
NIVELENV = VALOR
IF(INDICE == 8)
SEND_COMMAND DVTP_BARRA, "'^TXT-3,0,', ITOA(NIVELENV),'?C'"
ELSE
SEND_LEVEL DVTP_NIVEIS, (NVARIAVEL - 30), NIVELENV
INDICE = INDEX
Change:
to
SEND_STRING 0, "'INDICE = ', itoa(INDICE), ' BUFFER = ', BUFFERDX"
$44$05$45
$44$06$45
$44$07$45
$44$45
$44$01$45
$44$02$45
And so on...
Ain't it weird?
