Help with NSI/Leviton IF501
Hello all,
I am having some difficulty getting any control out of my Oxo Merak 6ch dimmer with a NSI IF501. It could be my syntax problem as the NSI documentation is quite parse. Currently for PC/Serial to DMX I am sending something like :
SEND_STRING DMX,"'D001@',DMX_STRING[1],13"
where DMX_STRING[1] is a value between 0-255, and D001 is for Dimmer 1
Also, does anyone know if the DMX input port on the IF501 still works in "PC to DMX" mode? i.e. allow a DMX controller/fader to act as a pass-thru.
Would appreciate any help greatly!
fongslb
fongslb
Be sure your baud rate is correct and all of the jumpers inside the unit are set. As I remember there are two that have to be changed for RS-232 to DMX.
I am using TP bargraphs to reflect levels, so some conversion would be required if its 0-100.
