A bit of string
I am having a little trouble with some string manipulation. I have a Harman Kardon home theatre amp and I am trying to catch the string from it and displaying which surround mode I am using.
So the HK gives me this in notification:
MPSEND$032$F0VIDEO 2/ OPT 1$00$F1DOLBY DIGITAL $00$F2$C0$00$00$00$C0$...
But only this if I look at the DATA.TEXT and display it on my TP:
But I have to get the DOLBY part of it.. which I can?t see!
Any ideas?
    Thorleifur wrote: »
    Any ideas?
    This might be one of those cases where DATA.TEXT can bite you.
    Perhaps try using the old CREATE_BUFFER method.
    You can still use the data_event to fire the routine. But instead of looking at DATA.TEXT, look at whatever buffer you create.
    Thorleifur wrote: »
    Any ideas?
    ericmedley wrote: »
    I don?t think DATA.TEXT has anything to do with it and I believe the data is all there but the null ($00) in the string is causing the lopped off display. Netlinx is treating the string like a C null terminated string even though it shouldn?t. Netlinx and nulls don?t get along at times and you?re experiencing one of them first hand.
