Integera DTR volume level problem
This is the section of code that handles the volume feedback from the Integra DTR-9.9 that I am using.
The problem is when I do a Hold[1,Repeat]: the volume level updates fine for a second or two then it drops down to a to 0 or 2.
Any ideas on what I am doing wrong?
Active(Find_String(cData,'!1MVL',1)): /// Volume Level
debug("'Found volume level status message'")
Remove_String(cData,'!1MVL',1)
cVol = Left_String(cData,2)
sReceiver.Volume = Atoi(cVol)
Send_Level aTPS,1,sReceiver.Volume
You want to use hextoi() when storing its volume, not atoi().
What probably happens is the volume you're getting back is at something like '27', then goes up to '28', then goes up to '29', then it gets to '2A', which the atoi() function interprets as 2 and not 42.
You are the man, that is exactly what is happening. Thanks for the quick response. I will try changing it and see what happens.
Chris Ondrovic
