How does your company charge?
We as a company have been going over how we charge for programming an AMX system.
How are you all doing it?
1. Do you have a per panel or per device charge?
2. How much for extra pieces?(AXB-*** or something)
We have been doing a per panel charge and just absorbing the cost in to that. Then we realized that that would not work on jobs with lots of items but few panels.
On a different note, how do you as a programmer get paid?
I am the sole programmer at my company. I am also the engineer that designs the systems. Works out well for me in that I done have someone else shoveing there ideas down my throut.
I am salary and get bonuses on the programming charge. 10% of the total paid on completion. I am the highest paid emplyee at my shop and I feel that I should be.
We create a bid based upon engineered designs that take into account all the parts-n-pieces needed to get the job done and then even put in a mics. parts budget to catch all the stuff that falls throught the cracks.
With the method you describe, I cannot see how you'd deal with scope creep costs and whatnot.
We do bid labor. That's the part that gets a little sketchy for us. We have to monitor our labor hours very closely to keep us from losing our shirts. Most times we come in about right.
We charge for programming labor by the hour. We estimate the hours on bids. Otherwise, it's time and materials.
We charge by a set forumla that I've come up with. Most of our jobs are large residential so we are able to create custom/cookie cutter systems. When we work with non-conforming jobs we charge $150/hr. Below is the formula
Hours Programming
# of Displays
# of Audio Zones
# of Video Zones
# of Different Sources
# of Home Theater Recievers/Processors
# of Type of Touch panels or Remotes
Lutron (Yes or No) If Yes add 10
HVAC (Yes or No) If Yes add 10
Security (Yes or No) If Yes add 10
Access Control (Yes or No) If Yes add 10
Most jobs end up around around 90-150 hours. I am the Sales/Designer/Programmer I get to see the project through from beginning to end. We have a 2 installers and 2 project managers...I stay very busy.
Such as how many, areas/rooms to be controlled, G4 panels, MIO panels, MIO keypads,
IR sources, RS232 sources, IP sources, CODECS/Cameras, AV switchers, DSP audio, display devices,
lighting, miscellaneous items (password management, communications etc).
It will also calculate discounts for multiple systems of the same type and with or without RMS!
We give the spreadsheet to our customers and they generate their own quote.
Percentage for me seems like it must be a kind of partnership, thought it is not as you are on a salary... Weird... The only situations like that I met were when there was severe lack of skilled labor on the market or they were afraid you leave (same thing basically). Let me guess, Eastern Europe? From what I know, the ways of charging and paying are literally unpredictable there...
